totti 13165 Posted August 10, 2020 Valja samo napomenuti da je ova "ful digitalna" tabla na Picassu neretko u problemu. Pojave se krugovi u vidu fleka, izgube se pojedini segmenti... nema rešenja osim zamene table, a u ovlašćenom je negde 1100-1200€.Sent from my SM-G950F using Tapatalk 4 1 horvat, djomla, shomispc and 2 others reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 10, 2020 Pročitah da riknjava na 2013 i 2014 serijama Picassa, ne znam da li na "običnoj" tabli ima merač temperature motora, na prvom C4P nema. Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17683 Posted August 10, 2020 13 minutes ago, totti said: nema rešenja osim zamene table, a u ovlašćenom je negde 1100-1200€. Pa onda se vise isplati da ides i pases kazne za prekoracenje brzine . 2 djomla and Axic reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted August 10, 2020 Nije to sad nešto toliko strašno i da se izgubi cela tabla. Izgubi ona par "piksela", s' tim što je taj piksel nekih 0,5-1 cm Sent from my SM-G950F using Tapatalk Sent from my SM-G950F using Tapatalk 3 Woodoo, djomla and neshtry reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 10, 2020 Znači, pored robota, izbegavati i ovo. Sent from my 3310 using Tapatalk 2 1 Axic, totti and Woodoo reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted August 10, 2020 Da, to je to.Mada Picasso ima 3 režima prikaza table, pa može da se promeni ako negde ta fleka smeta. Sent from my SM-G950F using Tapatalk 2 Woodoo and djomla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17683 Posted August 10, 2020 Ili stavis milje. 7 ISV_01, Boris90, Zvezdo and 4 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 10, 2020 Jaooooooooo da se to desilo na FIAT-u ili na AR bilo bi haaaaa zabariii, ne znaju ni ekran da naprave! A ovo, ako se pojave crne rupe na ekranu - promenis prikaz i onda umesto da se ne vidi temperatura ne vidis pola obrtaja, UOPACAAAA! Francuski..polu-proizvod 5 4 dekirs, vagenovac, MS PK and 6 others reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted August 10, 2020 Jel masira ovo cudo jaja, mene to zanima ? 2 4 Ivan, Mijailović P., Nikola 1.6 and 3 others reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted August 10, 2020 A ljute se francuzi kada neko kaze da su skupi za popravke i da ih zeza elektronika Послато са Mi MIX 2 помоћу Тапатока 3 Milutinac, Mijailović P. and djomla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17683 Posted August 10, 2020 Dobro, vidis da se bar ova tabla lako i jeftino resava . 2 3 Mijailović P., dekirs, Axic and 2 others reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 10, 2020 Samo za @dekirs mrsom*da 1 1 knezevic76 and dekirs reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 10, 2020 Nema vise smisla da koristimo jedinicu 1000e = zamajac i kvacilo za 2.0mjet Mislim da je adekvatnije 1000e = jedna tabla za C4 Tipa evo sada: Uuuuu kakvog je Brava danas Ivan postavio na "lepi i zanimljivi oglasi", kupis za njega cak 3 i po table za C4... 4 3 djomla, knezevic76, SalacUE and 4 others reacted to this Quote Share this post Link to post Share on other sites
Ivan 17683 Posted August 10, 2020 (edited) Jeste, ali kod Brava Deki ne moze da bira da li ce da mu masira levo ili desno - gledaj podesavanja, gledaj opcija sto je okacio Djomla. I masira i greje . Edited August 10, 2020 by Ivan 3 Axic, djomla and dekirs reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 10, 2020 3 minutes ago, djomla said: STA JE OVO sunce ih je*lo??? Ja i FRA automobili nikada nismo bili nize na lestvici, nego evo sada... 1 djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 10, 2020 Drzač za meze, podupirač za patq 2 horvat and Axic reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted August 10, 2020 STA JE OVO sunce ih je*lo??? Ja i FRA automobili nikada nismo bili nize na lestvici, nego evo sada...A imaju oni tako po neke budalastine odkad postoje Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 10, 2020 (edited) Znam, ali... brateuuu Ultimativno FRA vozilo - izgled i rucica menjaca iz R4. Razmotriti i izgled DS ajkule, ipak je to najlepsi automobil ikada o_O - felne sa 3 rupe naravno, cak mozda i sa 2...razmotriti. - podupirač za patku iz C4. - volan iz C4, naravno. - sedista iz PUG 206, ona fina sto coveku od 182cm dodju do pola ledja. - bok kola obavezno da ima one panele kao Cactus, to je bas chic, ali da se vrata otvaraju kao na onog PUG 1007. - motor iz clia v6, onaj 3.0 sto obicno izbaci oko 150ks. - ekrancina unutra naravno, kao iz nove 308, sve na njoj da bude, pa sta god zelis da namestis, klimu muziku ili sta god - da moras da gledas 10 sekundi u ekran i tipkas pa ne moras da gledas na put. Korisno! - sta fali jos - samo napakovati od Dijane i to je to. Ultimativno FRA vozilo za siroke narodne mase. Edited August 10, 2020 by Milutinac 6 6 ISV_01, Mijailović P., Jug and 9 others reacted to this Quote Share this post Link to post Share on other sites
neshtry 14883 Posted August 10, 2020 Da ti ne pričam tek o sranjima kod Amera Sent from my motorola one macro using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17683 Posted August 10, 2020 @andreja.micovic 'Si vid'o kako se sa Astrom bump-uje tema iz mrtvih . 3 djomla, darkman14 and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Lufti 690 Posted August 10, 2020 2 hours ago, Milutinac said: Ultimativno FRA vozilo Ovaj post ulazi bez problema u top 3. posta foruma! 2 1 neshtry, Milutinac and djomla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17683 Posted August 10, 2020 Ne znam sta kaze @totti , ali grdno nam se zamerio . Ja sam naucio da vozim na porodicnom Peugeot 305 (i to SR bato, jaca verzija 1472 ccm sa razornih 75 KS ) kojeg je matori kupio polovinom 80-ih. Opet, tamo 2006-7, umalo da kupim 307 2.0 HDi 3v. Bio je atraktivan u svoje vreme, auto godine 4 godine ranije (Laguna i Stildza se klali za drugo mesto te 2002.). Ali je presudio pre svega JTD i eksterijer 3v Stila kada sam ga prvi put provozao. I ostadoh na Italijanima bogami poprilicno. Uostalom, treba da se pripremamo jer jos malo svi zajedno postajemo jedna velika i skladna FCA-PSA porodica . 1 djomla reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted August 10, 2020 Ne znam sta kaze [mention=10479]totti[/mention] , ali grdno nam se zamerio .Ma šta da se brecam na reči čoveka koji vozi Bravo Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17683 Posted August 10, 2020 A zamisli tek kada za sledeci auto bude razmatrao Citroen Tipo ili malo veci Fiat 508 ? 2 totti and djomla reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 10, 2020 Nece nece. To je za mene jeres. Prelazim na "Kamikaza" stranu 23 minutes ago, totti said: Ma šta da se brecam na reči čoveka koji vozi Bravo Bravo je za onu karakondzulu sa mog spiska - INSTITUCIJA! Quote Share this post Link to post Share on other sites
