italiano 474 Posted May 20, 2021 @Ivan Za one kojima je prtljaznik na prvom mestu ima Tipo karavan 1 shuxx reacted to this Share this post Link to post Share on other sites
Ivan 17677 Posted May 20, 2021 Tacno, ali je vec i najmanji Tipo HB (Type 357) za Compact klasu odlican po tom pitanju... Danasnji modeli se najcesce vrte na 370-380l, a Tipo je u vrhu sa 440l. I prvobitni sedan (Type 356) je imao bukvalno pecinu od 520l (ako se dobro secam). Tako da cak ni Type 358 nije nesto daleko od te cifre. Share this post Link to post Share on other sites
dach@ 4904 Posted May 20, 2021 Čestitke za auto,da se lepo navozaš 1 knezevic76 reacted to this Share this post Link to post Share on other sites
danijel55 700 Posted May 20, 2021 Cestitke i od mene. P.S cekamo oglas od bavarca. 1 knezevic76 reacted to this Share this post Link to post Share on other sites
italiano 474 Posted May 20, 2021 @ivan Ti pricas o standardnoj zapremini. A kad se obore sedista, pa sve do plafona? Share this post Link to post Share on other sites
neshtry 14867 Posted May 20, 2021 Čestitke za novi automobil Isti kao na reklami Share this post Link to post Share on other sites
igor0511 2882 Posted May 20, 2021 @neshaoct a Renegade 1.0 za iste pare i sa bas lepom opremicom? I jos 120ks i brzina vise 3 Axic, neshaoct and moron reacted to this Share this post Link to post Share on other sites
italiano 474 Posted May 20, 2021 @igor0511 Tako je, pod uslovom da svaris izgled ReneGADa 2 knezevic76 and MS PK reacted to this Share this post Link to post Share on other sites
cane 205 Posted May 20, 2021 Prvi put vidim ovaj auto, bas je cool. Neka je sa srecom i da se nauzivate u njemu. 2 Reacher Gilt and knezevic76 reacted to this Share this post Link to post Share on other sites
igor0511 2882 Posted May 21, 2021 (edited) 7 hours ago, italiano said: @igor0511 Tako je, pod uslovom da svaris izgled ReneGADa Meni se bas mnogo svidja Kao G klasa za sirotinju Doduse samo restyling verzija i iskljucivo sa lepsom maskom i LED prstenovima. Prethodni mi je bio onako, nista posebno Edited May 21, 2021 by igor0511 2 Axic and Reacher Gilt reacted to this Share this post Link to post Share on other sites
Dzimbo 1009 Posted May 21, 2021 51 minutes ago, igor0511 said: Meni se bas mnogo svidja Kao G klasa za sirotinju Doduse samo restyling verzija i iskljucivo sa lepsom maskom i LED prstenovima. Prethodni mi je bio onako, nista posebno Nemo se ljutis, ali meni izgleda ko reno cokula. 2 italiano and Reacher Gilt reacted to this Share this post Link to post Share on other sites
italiano 474 Posted May 21, 2021 Renegade je cistokrvni duhovni naslednik Multiple! Alal mu vera! 2 moron and Dzimbo reacted to this Share this post Link to post Share on other sites
igor0511 2882 Posted May 21, 2021 Izvinjavam se domacinu za off, ali lose gledate Ja sam dodao do zakljucka da mi, iz perspektive potreba, treba automobil koji: * Moze koliko-toliko na ivicnjake * ima mesta za putnike * moze da se pristupi zadnjoj klupi i montira nosiljka/sediste za dete * ima pristojno prostora u gepeku * ima dobru opremu bez da mora 30k da se iskesira * moze da se parkira u centru BG Poslednja stavka odseca bas mnogo automobila danas. A Renegade sve to ispunjava i lep mi je. Nazalost sad nema mogucnosti za promenom, ali kada se ukaze, verovatno ce biti favorit u izboru 6 1 italiano, Dzimbo, ivica su and 4 others reacted to this Share this post Link to post Share on other sites
Reacher Gilt 2182 Posted May 21, 2021 (edited) 45 minutes ago, Dzimbo said: Nemo se ljutis, ali meni izgleda ko reno cokula. Cokula? Možda, al' moja (Kneževićeva) cokula ... Inače obožavam da ih nosim, al' ovaj par je za moj ukus prekiseo ... i ja volim nerandže, al' trpim ! Meni je ovaj Tipo prelep, kao i obična varijanta doduše... Tog sam na kratko imao priliku da probam prošle godine, i nije me se nešto dojmio jer je bio klot sa atmo benzincem. Ovaj je sigurno sasvim druga priča. Iako možda tih sto konjova ne zvuči obećavajuće, onih 190Nm po meni su više nego dovoljni za opuštenu vožnju. Uvek može bolje, znam, al' ja sam fasciniran iz koje zapremine motora izlaze ... A kakav je stvarno, to će vlasnik da kaže najbolje kad se slegnu utisci. Edited May 21, 2021 by Rasta 1 Dzimbo reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted May 21, 2021 14 hours ago, igor0511 said: Izvinjavam se domacinu za off, ali lose gledate Ja sam dodao do zakljucka da mi, iz perspektive potreba, treba automobil koji: * Moze koliko-toliko na ivicnjake * ima mesta za putnike * moze da se pristupi zadnjoj klupi i montira nosiljka/sediste za dete * ima pristojno prostora u gepeku * ima dobru opremu bez da mora 30k da se iskesira * moze da se parkira u centru BG Poslednja stavka odseca bas mnogo automobila danas. A Renegade sve to ispunjava i lep mi je. Nazalost sad nema mogucnosti za promenom, ali kada se ukaze, verovatno ce biti favorit u izboru Slično sam razmišljao, ali i žena se nešto pita I reneged joj je ružnjikav, sa druge strane za iste novce koje sam dao za Tipa mogao sam uzeti I renegejda sa istim motorom od 120ks. A opet oba modela obiluju sa prostorom, s tim što mi je tipo ipak estetski malo lepši. 6 ISV_01, Reacher Gilt, igor0511 and 3 others reacted to this Share this post Link to post Share on other sites
igor0511 2882 Posted May 21, 2021 I ima dosta veci gepek sto nije zanemarivo. Ali generalno super kupovina. Milslim da LED farove i digitalnu tablu nema sanse da nadjes ispod 20k nigde drugde. 3 knezevic76, Dzimbo and Reacher Gilt reacted to this Share this post Link to post Share on other sites
Ivan 17677 Posted May 21, 2021 (edited) 2 hours ago, Rasta said: onih 190Nm po meni su više nego dovoljni za opuštenu vožnju. Uvek može bolje, znam, al' ja sam fasciniran iz koje zapremine motora izlaze I prethodne 2 generacije MultiAir (tehnologija od 2010. naovamo, a FireFly je 3. generacija tog sistema) su ti, kad preracunas, izvlacile skoro 70 Njutna po cilindru. T4 FireFly u najjacoj verziji ima 285 Njutna, tako da ti je to otprilike to kao i ranije . Kao i ovih 190 Njutna na T3. Ovde je vise naglasak na drugim stvarima. Alu blok i glava, razmak izmedju cilindara samo 77 mm, tako da je T3 motor tezak samo 93 kg. Za razliku od prethodnika, ubrizgavanje je direktno, preko injektora sa 6 rupa i pritiskom od navodno 200 Bar. MultiAir sistem varijabilnog otvaranja usisa 3. generacije u nekoliko modova, povecava efikasnost u svim rezimima i smanjuje potrosnju. Ono sto je meni interesantno je na sam motor integrisani Intercooler hladjen vodom (za razliku od MA motora, gde je IC klasicno hladjen vazduhom i pozicioniran iza glavnog hladnjaka). Turbo je Mono scroll, mali, sa laganijim krilcima, kako bi na ovako malom motoru mogao efikasno da se zavrti na niskim obrtajima. I ono sto bi trebalo da bude zabavno - elekticni Westgate (za razliku od prethodnog vakuumskog). FireFly motori su sa GPF. Sve u svemu - fokus je na tehnologiji, manjoj potrosnji, emisiji gasova i tezini samog motora. A ne na performansama, jer su i prethodni MA opusteno izvlacili po 170 KS i 270 Njutna iz slicne kubikaze, ali je polako pocela da ih priteze emisija i nove norme. Edited May 21, 2021 by Ivan 3 2 Reacher Gilt, igor0511, shuxx and 2 others reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted May 21, 2021 (edited) Оnо štо sam danas prоveriо a i mnоge verovatno zanima, drugоm ide dо 80 i tu mu je skоrо crvenо za оbrtaje, ima baš zanimljiv zvuk, akо stignem оkačiću i videо. Аli realnо nema pоtrebe takо da se vоzi jer pоvlači iz malih оbrtaja pa takо da ni jednоm nisam imaо pоtrebu da šaltam prekо 4000оbrtaja, štо mi je za benzinca оdličnо, turbо je turbо. Čak ni na autо putu pri preticanju i ubrzavanju. Na autоputu autо, mоtоr, je nečujan, barem dо 130 kоlikо sam vоziо i dоbrо drži put. Penjanje na Begaljičkо brdо ka BGu, оd pоdnоžja dо vrha 130 km/h držaо je na оkо 3000 оbrtaja. Sa druge strane penjanje оd BGa ubrzava оd 80 uzbrdо u četvrtоj dо 130 i tu sam prebaciо u petu. Biо sam sam u kоlima. Baš sam zadоvоljan kakо se taj mali trоcilindraš pоnaša. Za razliku оd bavarca, оvaj ne tera na nekо jurcanje, lepо se krstari u njemu, elastičan je baš. Verujem da kad se оptereti malčice sve tо bude slabije, al stvarnо nemam zamerki. I da, StartStоp mоra da se gasi nakоn svakоg vađenja ključa iz brave. Sistem za čitanje znakоva pоred puta radi bez greške, kakо se prоđe neki znak nakоn sekund оčitavanje bude na displeju. Sistem za držanje trake istо radi оdličnо, par puta sam bez migavca hteо da se prestrоjim i gоspоdin mi je lepо prоdrmaо ruke. Tempоmt nisam kоristiо za sad, ni klasičan ni adaptivni a pоsebnо ne оnaj za оdržavanje rastоjanja, između vоzila, mоram prvо da prоučim uputstvо. I naravnо, оd juče sam tražiо kоmande na vоlanu za muziku i kad sam pоmisliо da nema, malо se razоčaraо, napipaо slučajnо [emоji41][emоji849]. I jedna fоtka kakо se parkira nоv autо na parkingu Edited May 21, 2021 by neshaoct ciril->latin by horvat / slika na FLCS server by neshaoct 18 1 italiano, djole81ar, ISV_01 and 16 others reacted to this Share this post Link to post Share on other sites
Ivan BG 720 Posted May 21, 2021 Cestitam na kupovini novog auta. Nema nista lepse nego kad sednes u nov auto. 2 knezevic76 and italiano reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted May 21, 2021 @Ivan BG vala nema. Danas kupljeni i namontirani sigurnosni šrafovi na felne. Vidim da su gume Bridgestone Turanza, deluju dobro na putu, prvi put vozam taj brend i model. Da ne bude da samo hvalim, moram malo i da kudim, mada ništa strašno. Ceo kokpit I enterijer uopšte je crn! Lepo izgleda al se svako zrno prašine vidi. Ona pijano plastika ispod multimedije je lepak za otiske kao i plastika oko prekidača na vratima. Tamne je boje međutim kad opali sunce otisci vrište. Pretinac ispred suvozača nema osvetljenje, ima rupu iznad za rasvetu al je prazno, nisam video ni instalaciju, cigani . I stoji nekako nisko, da bi se otvorio do kraja moram malo da razmaknem noge jer se nisko spušta. Kad sedim na mestu suvozača smeta mi što se leva noga naslanja na centralnu konzolu, tj onaj deo gde su komade za klimu, sam deo je malo širi, taman toliko da smeta. Kad se povuče sedište skoro do kraja u nazad onda nema problema, jer je noga malo dalje. Mojoj ženi i deci ne udara noga. Sa druge strane kad se namestim (zavalim) na mestu vozača, onako baš komotno, a imam 180cm, mogu sesti iza na zadnju klupu i od kolena do sedišta imam jedno 2-3 cm. Dakle, definitivno ima mesta pozadi. Ispred menjača postoje dva mesta za limenke a ispred njih rupetina za sitnice mada je u doplati na tom mestu bežični punjač za mobilni, između menjača i naslona za ruku dva mesta za flašice i u vratima sa obe strane ima profil za flašicu. Sam naslon za ruku je baš masivan i kad se otvori ima ogroman prostor za odlaganje, baš je dubok. Bilo bi dobro da ima foru da se otvara u dva položaja, jedna plića ostava i jedna duboka. Sve navedeno ima gumirano dno sem ostave ispod naslona za ruku, ono je tapacirano. Inače, pušači paket se doplaćuje 35€, verovatno piksla I upaljač. Da vas još malo smorim sa asistencijama. Kad se pusti volan I auto krene da dodirne belu liniju, sam ga ispravi, a pošto sam hteo da vidim šta će da uradi ako ne diram volan uopšte, posle drugog ispravljanja izbaci obaveštenje preko celog ekrana da vratim ruke na volan uz odgovarajuće psovke. Isto mi se desilo da je lik ispred mene krenuo a ja ga malo pustio da odmakne i onda sam malo brže startovao, lik ispred mene je usporio i sistem je prepoznao opasnost prebrzog približavanja i naravno uz razne psovke izbacio preko celog dipleja BRAKE crvenim slovima. U slučaju da ne stisnem kočnicu na vreme, sam bi počeo sa kočenje. Većina ovih opcija može ili skroz da se ugasi ili da se podešava osetljivost itd. Sutra idemo do Džonija da vidimo za neku zaštitu farbe i laka tipa neka keramika i slično, koliko para itd. Sad dok je nov da ga saluvamo koliko toliko, mada je gospođa odbila moj predlog da tapacirano vrata kao na renou Kaktus ili barem one bove za čamce da držimo sa strane, al jbg, žene je teško razumeti. 10 silenci, nobutado, Reacher Gilt and 7 others reacted to this Share this post Link to post Share on other sites
neshaoct 9592 Posted May 24, 2021 Deo postova je sada ovde: - Nanokeramička zaštita? Share this post Link to post Share on other sites
knezevic76 7020 Posted May 30, 2021 (edited) Urađena keramika Edited June 5, 2021 by neshaoct formatiranje 10 IDzO, Reacher Gilt, silenci and 7 others reacted to this Share this post Link to post Share on other sites
Lufti 690 Posted May 30, 2021 Cestitke na kupovini! Odlicna oprema, moderan automobil, boja mu super stoji, razbija monotoniju srebrne, sive i crne... 1 knezevic76 reacted to this Share this post Link to post Share on other sites
moron 3691 Posted May 30, 2021 Čestitke ! 1 knezevic76 reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted May 30, 2021 (edited) Evo par sličica neposredno nakon nanošenja Edited June 5, 2021 by neshaoct formatiranje 8 1 dach@, djomla, Siciliano and 6 others reacted to this Share this post Link to post Share on other sites
