igor0511 2882 Posted June 22, 2021 Moj na 3000rpm malo preko 180 po cajgeru 1 Dzimbo reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted June 22, 2021 BMW E87 mi je otprilike isto tako vrteo Share this post Link to post Share on other sites
vagenovac 4533 Posted June 22, 2021 Kod mene je 205kmh na 3000rpm, doduse u 8oj brzini 3 3 Axic, igor0511, ISV_01 and 3 others reacted to this Share this post Link to post Share on other sites
rkoma1986 1113 Posted June 22, 2021 Dobro bre ljudi, pricam o benzincu sa tri cilindra i 1000 kubika, ne lozite se 1 2 shuxx, Grafit and Axic reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted June 22, 2021 Si siguran da je benzinac? 1 djomla reacted to this Share this post Link to post Share on other sites
MS PK 7735 Posted June 22, 2021 On 6/22/2021 at 2:39 PM, rkoma1986 said: Tako je, menjac je sa 6 brzina.. Ali mislim da se moj 2.0 tdi u sestoj vrti na vise obrtaja nisam siguran, provericu prvom prilikom kad izadjem na autoput Nema sanse Share this post Link to post Share on other sites
neshaoct 9592 Posted June 23, 2021 Deo postova je sada ovde: - Fiat Nuova Tipo - podešavanje LED farova 1 Ivan reacted to this Share this post Link to post Share on other sites
Bingodalton 738 Posted June 23, 2021 21 hours ago, vagenovac said: Kod mene je 205kmh na 3000rpm, doduse u 8oj brzini Ali kad ga cipujes, na 205kmh ce biti na 2800rpm Tako znalci kazu 2 vagenovac and Axic reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted June 26, 2021 (edited) Adaptivni u akciji i jedna wide fotka Edited June 27, 2021 by neshaoct prebacio slike na FLCS server 5 Zakeralo, neshaoct, ISV_01 and 2 others reacted to this Share this post Link to post Share on other sites
MS PK 7735 Posted June 26, 2021 Ja ne volim taj adaptivni na a.putu npr., cesto mi se desi da kilavim iza nekog neko vreme a da ne primetim Share this post Link to post Share on other sites
ISV_01 4036 Posted June 26, 2021 1 minute ago, MS PK said: a da ne primetim Pa u sta gledas Mico, zenske guzove pri 80km/h? 3 3 djomla, silenci, Dzimbo and 3 others reacted to this Share this post Link to post Share on other sites
MS PK 7735 Posted June 26, 2021 Gledam negde a on blago usporava i prilagodi se ovom ispred i eto Share this post Link to post Share on other sites
knezevic76 7020 Posted June 26, 2021 Pa ne služi da bi zverao okolo, čak i uputstvu piše NE ZVERATI OKOLO DOK JE UKLJUČEN! Ja ga retko koristim, tj ovo mi je drugi put od kad je auto kod mene. Dobra je stvar upravo zbog držanja rastojanja, a verujem da na dugim putovanjima mnogima može da spasi glavu kad malo refleksi olabave. 2 djomla and Zakeralo reacted to this Share this post Link to post Share on other sites
djole81ar 514 Posted June 27, 2021 On 6/20/2021 at 8:01 AM, knezevic76 said: Ako ga uporedim sa 1.4 iz 500l koji sam vozio desetak dana, tu su negde, možda je 1.0 za nijansu štedljiviji ali je 1.0 definitivno agilniji I lakši za vožnju. Naravno da se oseća razlika većeg obrtnog, i trebalo bi a potrošnja 1.4 Tipo sad se vratio iz CG preko Podgorice, 6.1 po bordu, tu je negde i stvarna. Kad pominješ Bukulju, meni je zanimljivo kod ovog 6-stepenog menjača sa ovim 1.4 da možeš da održavaš neku brzinu i na niskim obrtajima, ubrzanja su sporna svakako, ali na primer ja sam probao izađe uz Bukulju u trećoj, čak i u serpetinama izađe i izvuče, polako ali ubrza... pa koga mrzi da šalta ili je kul tip može tako da ga vozi, naravno uvek možeš i niža druga, ali u mnogim situacijama ako ne žuriš i staloženo voziš i ne moraš. Share this post Link to post Share on other sites
moron 3692 Posted June 27, 2021 On 6/21/2021 at 9:08 AM, Ivan said: Ja upravo napisah da je i kod Tipa sa 5 brzina i kod mene na C635 sa 6 brzina prenosni odnos maltene isti - 0.77 . Zato i napisah da je menjac na Tipu lepo razvucen u toj zadnjoj brzini. A obicno slabije motore sabiju sa menjacima, da delom nadoknade manju snagu kracim prenosima i boljim ubrzanjima. Verujem da su ovde zbog turbo motora mogli malo da se igraju i razvuku brzine, takva igranka je daleko manje primetna nego na atmosfercu npr. (Ono sto se razlikuje je Final drive u diferencijalu i u kombinaciji sa samim motorom se vrti na 600 rpm manje na tih 130 km/h. Kod Compassa je to jos vise izrazeno, ocigledno akcenat nije toliko na medjuubrzanjima vec na nizim obrtajima na putnim brzinama). I meni je fascinanto na kako malim obrtajima se vrti taj Compass u šestoj. Ako je verovati "cajgerima", oko 3.000 rpm pri 150. CRV 1,5T na 3.000 rpm jedva da ima i 130 km/h Slično kao i Tipo Cross 1,0T u petoj pri 130. A navodno je CRV čak i malo brži od tog Compassa ( 208 / 195 km/h ), ali je i razlika pri kojim obrtajima svi ti turbo motori ostvaruju najveću snagu ( Tipo iz naslovne teme i taj Compass pri 5.000 rpm (ako ne grešim), a ta Honda pri 5.600 rpm ). Share this post Link to post Share on other sites
knezevic76 7020 Posted June 27, 2021 (edited) Tipo100ps Compass 140ps Renegade 120ps Honda 173ps Edited June 27, 2021 by neshaoct prebacio slike na FLCS server Share this post Link to post Share on other sites
moron 3692 Posted June 27, 2021 Naravno, maksimalni obrtni momenat je veoma bitna veličina (i meni je tu posebno interesantan Fiatov T4 motor, on, ako ne grešim, ima u nekim varijantama do 280 Nm ), ali, možda i još bitniji je sam oblik dijagrama obrtnog momenta. Share this post Link to post Share on other sites
Ivan 17680 Posted June 27, 2021 1 hour ago, moron said: (i meni je tu posebno interesantan Fiatov T4 motor, on, ako ne grešim, ima u nekim varijantama do 280 Nm ), ali, možda i još bitniji je sam oblik dijagrama obrtnog momenta. Da, u verziji 180. Nista tu kod T4 nije preterano fascinantno sto se tice bas performansi. I u starijim MultiAir iteracijama si iz maltene iste kubikaze, npr. u verziji 140 kod mene imao cca 260 Njutna u Sport modu. U verziji 170 u Giulietti si u Normal modu imao 250 Njutna (znaci maltene gore navedeni torque u Dynamic modu). Plus sto su i MA i MA II izuzetno agilni i iz niskih obrtaja (vec od 1800 rpm), a snaga dostupna kroz pun raspon obrtaja. Napredak ce sigurno biti vidljiv, na papiru pre svega u potrosnji i emisiji gasova. Neosporno moderniji motor, sa 3. generacijom MultiAir elektro-hidraulicnog razvoda, direktno ubrizgavanje sa pritiskom od 200 Bar. Alu blok i glava, samim tim primetno laksi agregat (T3 93 kg, T4 110 kg), manja i ukupna i masa u nosu (dinamicnija voznja), integrisani Intercooler hladjen vodom, potpuno elektricni Westgate (umesto vakuumskog), itd... Pisali smo vec na tehnickim temama. On 6/26/2021 at 1:58 PM, MS PK said: Ja ne volim taj adaptivni na a.putu Ja ni obican ni adaptivni . Vozio sam i po 2000 km autoputem, a da sam ga upalio sve ukupno na par minuta, cisto da protegnem nogu. 2 MS PK and darkmanzr reacted to this Share this post Link to post Share on other sites
moron 3692 Posted June 29, 2021 On 6/27/2021 at 5:02 PM, knezevic76 said: Tipo100ps Compass 140ps Renegade 120ps Honda 173ps Možda je malo neprimereno pitanje ( automobil je još dosta nov i maltene i dalje u fazi razrade ), ali, da li si ga već "terao" preko 5.000 rpm ( tu mu je maks. snaga) ? Vidim da mu je "limiter" na 6.300 i interesuje me ( ako znaš iz iskustva), koliko se "slatko vrti" u obrtajima iznad onih kada razvije maks. snagu ? Pitam zbog situacija u kojima čovek nekada može da se nadje. Npr. nekog preticanja, kada iznenada zatreba još rasta brzine (a ispada da taj motor iznad obrtaja maks. snage ima "rezervu" rasta od još oko 25% kratkotrajno dozvoljenih obrtaja) , a nema vremena da se prešalta u viši stepen prenosa.. Share this post Link to post Share on other sites
knezevic76 7020 Posted June 29, 2021 Pisao sam negde već, u drugoj 80km/h je otprilike 5000 obrtaja, nemoj me držati za reč, nisam se baš fokusirao tada na obrtaje.Ono što je sigurno, ne znam dal će, barem meni, to više ikada zatrebati, jer za ovih pređenih 3000km nisam imao potrebe ići preko 4000 obrtaja.Ako uporedim sa 1.4 motorom iz 500l, ovaj mnogo lakše ulazi u I završava preticanja upravo zbog snage u niskim obrtajima a sa druge strane ne mora u visoke obrtaje upravo zbog turbine da bi se šaltalo a da ne gubi snagu.Послато са SM-A715F помоћу Тапатока 1 MS PK reacted to this Share this post Link to post Share on other sites
moron 3692 Posted June 29, 2021 Znam ja da on zbog turbine veoma lepo "poteže" i iz niskih obrtaja (maltene, kao da je neki dizel), samo me interesovalo šta se dešava u visokim obrtajima, oko i iznad obrtaja gde je maks. snaga. Ima motora koji se prosto "opiru" visokim obrtajima, gube dah već kada pridju obrtajima na kojima je maks. snaga ( a o obrtajima iznad da i ne govorimo ). Ne mislim ja da motor uobičajeno treba forsirati visokim obrtajima (naprotiv), ali, nekada se prosto desi iznenadna situacija i treba se na vreme upoznati sa svojim vozilom (i motorom) i znati kako se taj motor ponaša ako zatreba da se "tera" do npr. oko 6.000 rpm. Tj, da li će on da počne da gubi dah već na 5-5.500 ( pa ga je bolje i prešaltati) ili će prosto bez gubitka ritma da "zalepi" do limitera na oko 6.3.00 rpm. Share this post Link to post Share on other sites
knezevic76 7020 Posted June 29, 2021 To lepljenje u limiter ostavljam nekim drugim vlasnicima da isprobavaju Послато са SM-A715F помоћу Тапатока 2 2 shuxx, Dzimbo, Ivan and 1 other reacted to this Share this post Link to post Share on other sites
moron 3692 Posted June 29, 2021 (edited) Veruj mi da i ja generalno to ne radim "planski", ali, prosto, desi se nekada, neka moja loša procena pre preticanja. I za sva kola koja sam imao (ili imam) iskustveno znam šta sam od njih (u kriznim situacijama) mogao da očekujem "u žutim obrtajima", tj. koja od tih vozila je u cilju što bržeg okončanja preticanja imalo smisla "terati dalje bez šaltanja", a koja nikako. Edited June 29, 2021 by moron 1 knezevic76 reacted to this Share this post Link to post Share on other sites
shuxx 10889 Posted June 29, 2021 @knezevic76 nekada davno, kupio fabiju, majstor instalirao TNG, idemo zajedno do pumpe da napuni, testira. U povratku mi pokazuje kako šta radi, i na jednom pravcu, da gas i dođe do 5000rpm, a meni u mislima pođe pesnica ka njegovoj glavi mislim da nikada je nisam poterao do te cifre, 4-4,5K ok, povremeno što kaže @moron, kada je neophodno kod preticanja. 1 1 Dzimbo and knezevic76 reacted to this Share this post Link to post Share on other sites
ISV_01 4036 Posted June 29, 2021 I mene čudno gledaju što ne vozim Brava preko 3000-3200...jbg, ja do tad sve završim šta sam nameravao 1 knezevic76 reacted to this Share this post Link to post Share on other sites
