Mijailović P. 3450 Posted August 25, 2023 @nemanja84bg Nešto ovako... 1 nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1311 Posted August 25, 2023 (edited) Moz prodje , mada ovaj neverujem da ima podesavanja neka ozbiljnija , upaljena su mi neka svetla pa bi ih pogasio , americka neka varijanta kao fensi izgleda, citao sam kao samo vcds onaj kao sljaka mada i torque pro nije los i obd eleven i sl. Sta znam treba procitati recenzije pre kupovine ... ali za vcds sam nasao da ima fora da se pogase iako simpa izgleda kad je samo pozicija upaljena , sta znam uvek sam voleo default varijante za bembare imam rheingold i dobar je iskreno jednom ga koristio pa dao ortaku nek se deca igraju Edited August 25, 2023 by nemanja84bg Quote Share this post Link to post Share on other sites
darkman14 5901 Posted October 11, 2023 Pred zimu inflacija na set za reparaciju klapnice 100% Ko maske i asepsol u koroni 3 2 1 3 3 1 Axic, igor0511, Woodoo and 10 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted October 12, 2023 Sorry, nije da te mrzim, nego samo da imaš SVE moguće reakcije na post 11 Mijailović P., darkman14, Nikola031 and 8 others reacted to this Quote Share this post Link to post Share on other sites
Dale 6810 Posted October 24, 2023 2 MS PK and neshtry reacted to this Quote Share this post Link to post Share on other sites
darkman14 5901 Posted November 6, 2023 @totti našao sam nešto šta ti fali od opreme na citrusu Just found this amazing item on AliExpress. Check it out! RSD538.68 40%OFF | Air Conditioning Outlet Air Vent Jewel Cooler Air Conditioner Hose For Man Ball Jewel Cooler Car Air Conditioning Vent https://a.aliexpress.com/_msr68JI 2 9 ostoja, Axic, Woodoo and 8 others reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted November 6, 2023 Sent from my SM-G998B using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17680 Posted January 7 (edited) Natrcah u Lindi, mozda nekome bude interesantno... Stalak za odlaganje felni, za 3 somica. Kaze, za gume do 18'' i 225 sirine. Vidim da pominju i neki dodatni alat (navlaku na cicak, cipove za oznacavanje guma, kesicu za srafove, manometar, merac dubine sare, kljuc) ali ne videh da ima u pakovanju. A i bilo bi bas bagatela da sve to bude u kompletu : Edited January 7 by Ivan Quote Share this post Link to post Share on other sites
Grafit 1073 Posted January 8 Ja sam kupio dva slična stalka pre godinu-dve. Držim na njima 16” i 17” točkove. Dovoljno čvrst nosač, ne ljulja se. Mislim da je tada koštao ispod 2.000 dinara. 1 Nikola 1.6 reacted to this Quote Share this post Link to post Share on other sites
Nikola 1.6 268 Posted January 8 Yup pre je bilo jeftinije(mislim da ima primer na insta stranici "bulja cena"). Burazeru sam uzeo posto on ima tockove, dobar je. Quote Share this post Link to post Share on other sites
igor0511 2882 Posted January 8 Ja uzeo to cudo pre 5-6 godina. Za felne sa Stila je vrh sluzilo. Kada su stigle Leonove 18" na fabrickim felnama bas je bio nestabilan. Ali za te pare je ok Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted January 8 Imao sam i ja taj nosac kada sam kupio 17R na Bravu i stavio celicane na njega...pukao je. Pa kupio jos jedan. I on pukao. A onda video u uputstvu da pise 'Nikako celicne felne sa ruzne ratkapne, a posebno ne od ISV' I tako....cak me ima i u upustvu za uporabo 4 city, Axic, Grafit and 1 other reacted to this Quote Share this post Link to post Share on other sites
Grafit 1073 Posted January 9 16 hours ago, Nikola 1.6 said: Yup pre je bilo jeftinije(mislim da ima primer na insta stranici "bulja cena"). Burazeru sam uzeo posto on ima tockove, dobar je. Mislim da si hteo da kažeš: bila je bolja cena, a sada je bUlja cena. Quote Share this post Link to post Share on other sites
Ivan 17680 Posted January 23 (edited) Natrcah slucajno, sitnica, uzeh da se nadje... "Parkside" komplet od 251 vezice - trenutno u Lindi samo 350 kinti. Ima ih razlicite duzine i debljine: - 160 komada, 100x2.5mm; - 40 komada, 200x4.8mm; - 30 komada, 300x4.8mm; - 10 komada, 200x7.6mm; - 11 komada, 300x7.6mm; Edited January 23 by Ivan 8 shuxx, MS PK, werp690 and 5 others reacted to this Quote Share this post Link to post Share on other sites
nobutado 40 Posted January 24 Ponukan Ivanovim postom, svratih i uzeh ove vezice. Ako je nekom bitno, imaju i bele, ali one nisu UV otporne.Pored toga videh i čitavu paletu sprejeva, između ostalih i skoro pominjani silikonski. Cena nešto ispod 400din...Poslato sa YAL-L21 pomoću Tapatoka 4 knezevic76, Ivan, Misha87 and 1 other reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted January 24 Kada vec piskaramo - videh da jos uvek na akciji imaju i Smart punjace akumulatora. Cena i dalje 2 Vajferta, 6/12V i struja punjenja od 5A: 2 MS PK and Smireni reacted to this Quote Share this post Link to post Share on other sites
OMP 2219 Posted January 25 Koja je razlika izmedju svih ovih masti u spreju tipa litijumska, grafitna, ptfe i sl. kad procitam namenu sve one isto rade i za istu svrhu se koriste???? Ja koristim belu mast a ne vidim da se ona nesto razlikuje od ovih po onim pisanijama . Inace ove vezice sam kupovao i ranije, dobre su Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted January 25 Široka je to tema, ali razlika i te kako postoji. Prvo, sam sastav se razlikuje a zatim , ono najbitnije, svaka ima svoju namenu.Razlikuju se po temeraturi koju trpe, zatim frikcije koje trpe, neke su samo za šarke i slično a druge za visoko frikciine elemente, neke su non-stick kao PTFE. Neke su odlične kao antikorozivna zaštita, neke odlično odbijaju prašinu.....Ima o svemu tome na netu lepo objašnjeno.Npr u mašinstvu se vrlo vodi računa koje masti se za šta koriste, u nekim kućnim varijantama to i nije toliko bitno.Ista priča kao i za ulja, motorna, hidraulička, ulja za centralno podmazivanje............Sent from my SM-A546E using Tapatalk 2 Grafit and nobutado reacted to this Quote Share this post Link to post Share on other sites
OMP 2219 Posted January 26 (edited) I meni je jasno i logicno da se svaka razlikuje i ima razlicitu primenu ali citajuci ono na ambalazi ili na sajtovima deklaracije mahom pise isto ili vrlo slicno na svim a i sto kaze u nekoj kucnoj upotrebi i nije bitno koja je svaka zavrsava posao za ono za sta nama uglavnom treba. Jel u lidlu nemaju bakarnu mast, ovde na slici je nema Edited January 26 by OMP Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted January 26 Za kućnu upotrebu uglavnom sve završavaju posao.Ja lično na poslu, kad treba nešto da podmažem na mašinama, ili neko ulje da dolijem ili zamenim, to je bukvalno čitanje uputstava, ne mogu sve ni da popamtim gde šta ide. A opet, ne sme da se stavi pogrešan lubrikant. Eto havarije od par stotina do par desetina hiljada eura.Sent from my SM-A546E using Tapatalk 1 city reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted January 26 Cepovi Bravo sport felne pa kome treba... 1 1 Ivan and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted January 27 @city Da, samo. Doduse imas i cele felne sa cepovima za 250e na istom sajtu Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted January 27 7 hours ago, city said: 2500 po komadu? U ovlascenom su 2, 3 puta skuplji... Svakako je papreno! Quote Share this post Link to post Share on other sites
city 746 Posted January 27 Dobro je da su mi felne bez tih poklopaca a znake sam platio mislim 1500 sva cetiri, lepo izgledaju. Quote Share this post Link to post Share on other sites
