Ivan 17670 Posted March 15, 2023 @bane1321 Koji ste klosari . 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
bane1321 6005 Posted March 15, 2023 Dobro je dok su moderatori verni Talijanima! 3 Dzimbo, Ivan-Topola and Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted March 15, 2023 (edited) Osipamo se, a neki ce biti vidjeni i za trajno banovanje bez obzira na "funkciju" . Edited March 15, 2023 by Ivan 1 1 1 Mijailović P., neshaoct and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
Mihailo92 20 Posted May 13, 2023 (edited) Ćao kolege forumaši, imam u ponudi da uzmem Tipo koji je kupljen krajem 2017. Lounge 1,4 benzin. UConnect je 7", zanima me da li da bih dobio Android Auto moram preko OBD kabla i sve to ili može preko USB-a? I da, da znam koja verzija FW je ona na koju može da se stavi AA? Ukoliko pak mora OBD2 i ti kablovi, molim vas za preporuku, može i u PP, a da može kod nas da se kupi. Edited May 13, 2023 by Mihailo92 Quote Share this post Link to post Share on other sites
PedjaZ 13 Posted May 28, 2023 I posle dve nedelje... Pisalo je vec sve ranije Treba ti obd - tek treci kupljeni mi je proradio. Treba ti i adapter ili ako si vican mozes to resiti i prekidacem pa prekinuti i ukljuciti odredjene veze. pozdrav Quote Share this post Link to post Share on other sites
nebojsa zvezdara 269 Posted June 3, 2023 (edited) On 1/31/2023 at 10:41 AM, nebojsa zvezdara said: Posle nepuna četiri meseca evo ga treći update mapa...@maps. mopar.eu..... tri godine legalno, besplatno, bezbolno, ovaj put 28 minuta.... Uradih i četvrti map update, besplatno sa maps.mopar.eu, bez problema kao i do sada, standardnih 29 minuta trajanja, verzija TomTom 1110... Edited June 3, 2023 by Ivan Sredjen format, izbacen nepotreban citat 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
dukenukem 4 Posted June 18, 2023 (edited) Pozdrav svima, registrovao sam se samo da vam kazem sta sam kupio, jer nisam nasao ove informacije, a mozda nekom budu korisne. Tipo iz 2016, stari radio poceo da zeza, 'files error' kad ubacim usb. Kupim novi usb, isto. I tako ja jedne subote nadjem firmu iz BG (Bezanijska kosa), odem do njih, izlozeno dosta navigacija i ponude mi dve za Tipo, jedna lici na staru, ima dva tockica za volume i stanice, slicno kao stara, a druga ova sa slike. Posto mi se ova vise svidela, a necu da imam CD/DVD u kolima, uzmem ovu iako je bila skuplja, 350E. Odem u servis na Dorcolu, ugradi mi covek sve ok. (ugradnja 30E). Medjutim iako sad imam lep vizuelni prikaz za rikverc, ne radi zvuk za fabricke parking senzore. Zovnem ja pitam jel imaju i to da mi prodaju, oni kazu to ide uz, ali im proizvodjac greskom nije spakovao, odem ja uzmem besplatno taj deo, i prodavac ljubazan, odma otvori tablu na tipu, samo ubaci zvucnik, prikaci ga na konektor i sve super. Drugi problem trepti kilometraza glavna, kazu mora u fiat servis. Odmah odem, reko ako prodje prodje, subota je, u Bogunovic. Decko uze laptop i proba nesto desetak minuta, medjutim kaze ne moze, prijavljuje problem da nedostaje modul (stari radio). Ja reko ajde sta sad, nek trepti, medjutim kad sam stigao kuci, resetovao radio na dugme i ugasio auto, sledeci put je prestala da trepti. Sad me sramota sto mi u Bogunovicu nista nisu naplatili al sta da se radi, ajde redovan sam kod njih revansiracu im se. Sto se samog uredjaja tice odlicno je sto moze da se gledaju filmovi, muzika, dobio sam i IGo navigaciju itd. Procesor je malo slabiji deluje mi, pa mi maps i navigacija rade sporije, to je jedino sto mi malo smeta. Inace sve ostalo je odlicno. Telefon sad moze da prenosi zvuk preko BT znaci moze i tako da se slusa, a moze i sa USB-a. Na srecu mogao je fabricki usb da ostane, a imate i jos jedan kabl u kaseti. Zvuk je odlican, bilo da pustate sa telefona ili uredjaja. Jos jedna mana je sto je mikrofon malo tisi, dobio sam eksterni i primecujem kad nekog zovem da mene slabije cuje. Opet, ako glasnije govorite bice to ok, zato i ima taj eksterni mikrofon, nasao sam da taj interni bas ne radi dobro. Skinuo sam mu sundjer pa i nije tako lose, a kod mene je konkretno izbacen kod volana, mozda je mogao da ide gore u stub ali me mrzi da se vracam u servis da trazim to. Uredjaj ne znam koji je, nigde ne pise proizvodjac ili tako nesto, ali sam pretragom uspeo da nadjem ovako: ac8257 android car. Pokusao sam da udjem u factory settings (sifra je 8888) da probam da pojacam mikrofon, ali jednostavno ta opcija kod mene ne postoji, po tutorijalu koje sam nasao na youtube. Uglavnom ja sam zadovoljan, mana ima ali je mnoogo lepse nego ona stara siva. Edited June 18, 2023 by neshaoct formatiranje 3 1 nebojsa zvezdara, neshaoct, Jim9 and 1 other reacted to this Quote Share this post Link to post Share on other sites
dkoncar 22 Posted June 23, 2023 Pozdrav svima! Nov sam na forumu, pažljivo pregledam teme ali nigde nisam primetio da je neko pominjao gde može da se preuzme novi firmver za multimediju od 5 inča sa navigacijom, kao i da li je moguće apdejtovati mape nakon isteka od 3 godine van ovlašćenog servisa. Ako mi je promaklo, izinjavam se... Quote Share this post Link to post Share on other sites
Mihailo92 20 Posted August 8, 2023 On 5/28/2023 at 9:03 PM, PedjaZ said: I posle dve nedelje... Pisalo je vec sve ranije Treba ti obd - tek treci kupljeni mi je proradio. Treba ti i adapter ili ako si vican mozes to resiti i prekidacem pa prekinuti i ukljuciti odredjene veze. pozdrav Može li ovde ili u PP koji obd provereno radi? Planiram u narednom periodu da čačkam ovo pa da se spremim Sutra ću da proverim verziju firmware-a. Do koje verzije radi ovaj metod? Nikad koliko znam auto nije ažuriran. Quote Share this post Link to post Share on other sites
Edvin 0 Posted August 16, 2023 Dobar dan! Dali neko radi "otljučavanje" android auto opcije za fiat tipo uconnect 7? Quote Share this post Link to post Share on other sites
Mihailo92 20 Posted August 20, 2023 3. dan čačkanja oko android auta i mislim da mi plavi a5 adapter ne radi kako treba jer kad njega priključim ne mogu da uradim proksi do kraja. Koji preporučujete provereno da radi? Može i u PP. Quote Share this post Link to post Share on other sites
PedjaZ 13 Posted August 21, 2023 Malo je glupo da se dopisujemo ovde i na PP Imaj strpljenja na pisanje PP - ono sto je tebi hitno nije i meni Quote Share this post Link to post Share on other sites
zoranzo 18 Posted November 5, 2023 Pozdrav drustvo,jedno pitanje strucno ako neko zna,trenutno sam u nemackoj,nasao sam na oglasima ucconect navigaciju za tipa,moj fiat je iz 2017te i nema navigaciju pitanje je ako kupim ovde navigaciju hoce li raditi bilo koja kad je zamenim sa mojom,ili nece,jel treba nesto dodatno da se gleda,zna li neko Quote Share this post Link to post Share on other sites
nebojsa zvezdara 269 Posted November 6, 2023 Original NAV Uconnect neće da radi kod Tebe, ne gađa Ti se Tvoj postojeći 2017 ISO hard wiring izvod (najdeblji, veliki džek) sa ubodima na novom NAV Uconnectu, plus nemaš postojeći GPS izvod, velika zajebancija,.... Jedino je rešenje android multimedija sa CAN-om + rikverc kamera, ali i tu budi oprezan šta kupuješ...ima ih OK na KP... Pozdrav, Nebojša 1 zoranzo reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted November 6, 2023 On 3/15/2023 at 7:29 PM, bane1321 said: Dobro je dok su moderatori verni Talijanima! U skladu sa vremenom, i forum će promeniti umesto flcs u stelantisgroup kako bi se moderatori namirili 2 city and bane1321 reacted to this Quote Share this post Link to post Share on other sites
zoranzo 18 Posted November 6, 2023 2 hours ago, nebojsa zvezdara said: Original NAV Uconnect neće da radi kod Tebe, ne gađa Ti se Tvoj postojeći 2017 ISO hard wiring izvod (najdeblji, veliki džek) sa ubodima na novom NAV Uconnectu, plus nemaš postojeći GPS izvod, velika zajebancija,.... Jedino je rešenje android multimedija sa CAN-om + rikverc kamera, ali i tu budi oprezan šta kupuješ...ima ih OK na KP... Pozdrav, Nebojša Hvala puno na odgovoru,informacije zlata vredne Jel ima neka multimedija koja moze da dodje na mesto uconnecta?jel moze neka preporuka ako neko zna Quote Share this post Link to post Share on other sites
Ivan 17670 Posted November 6, 2023 (edited) 5 hours ago, nebojsa zvezdara said: ne gađa Ti se Tvoj postojeći 2017 ISO hard wiring izvod (najdeblji, veliki džek) sa ubodima na novom NAV Uconnectu, plus nemaš postojeći GPS izvod, velika zajebancija Kako za koga , sve smo mi to entuzijasti provaljivali i resavali sami. Potrebno je samo malo kefala, spretnosti, hakovanja i fabricke dokumentacije. Ubacivao sam fabricku navigaciju i na bivse Stilo (ConnectNav+) i na Nuova Bravo (poslednja verzija InstantNav). Na poslednju ubacivali zadnje mape Evrope sa detaljnom Srbijom, konvertovali instalacije sa ISO konektora na FAKRA, razvlacili instalaciju za GPS antene, resavali Code, vezu sa Blue&Me, peglali dijagnostikom da do zadnjeg detalja sve to bude kao fabricki... https://www.fiat-lancia.org.rs/forum/index.php?/topic/65115-fiat-stilo-naknadna-ugradnja-connectnav-uredjaja-navigacije/ https://www.fiat-lancia.org.rs/forum/index.php?/topic/64656-fiat-nuova-bravo-promena-jezika/&do=findComment&comment=1616605 Ali trenutno je za novije modele "problem" sto isti ti forumski entuzijasti uglavnom (zbog ovako tanke ponude Fiata) nazalost polako ali sigurno odose na druge brendove. Tako da bih @zoranzo preporucio da mozda najbolje da kontaktira Zecu, ako se ide bas na OEM varijantu. Covek profesionalno radi upravo sa uConnect uredjajima, pa najbolje da ga kontaktira licno za informaciju iz prve ruke. Ima i svoju temu na forumu: https://www.fiat-lancia.org.rs/forum/index.php?/topic/76786-naknadno-ugrađivanje-navigacije-ili-multimedije-za-fiat-500500l500x-blue-me-moduli-za-fca-grupaciju-vozila/ Ove aftermarket Kineze vec valja dosta njih. Koga zanima, interesantno je pogledati po turskim portalima sta sve Turci rade sa njihovim Aegeama, posto ih tamo ima na svakom cosku. Realno ima i dosta kica, ali se moze iskopati i lepih ideja. Edited November 6, 2023 by Ivan 1 zoranzo reacted to this Quote Share this post Link to post Share on other sites
zoranzo 18 Posted November 7, 2023 Ivane hvala za takodje za pomoc,kontaktiracu Zecu Quote Share this post Link to post Share on other sites
nebojsa zvezdara 269 Posted November 8, 2023 On 11/6/2023 at 8:41 PM, zoranzo said: Jel ima neka multimedija koja moze da dodje na mesto uconnecta?jel moze neka preporuka ako neko zna Imaš kineske androide tipske baš za Tvoj auto (ako je kod Tebe dashboard Uconnect), šraf na šraf, džek na džek...vidi na KP... Pozdrav Quote Share this post Link to post Share on other sites
zoranzo 18 Posted November 8, 2023 to na KP su sve starije mmedije od moje,ovakva je moja Quote Share this post Link to post Share on other sites
nebojsa zvezdara 269 Posted November 10, 2023 Te na KP nisu starije nego su dash board tip (ugradnja sa prednje strane konzole, ne odozgo)... Ovakve kao Tvoje (ugradnja odozgo) nisam istraživao, ali sam ih viđao na netu; istražuj, nema druge,... Pozdrav... 1 zoranzo reacted to this Quote Share this post Link to post Share on other sites
trendel 8 Posted November 11, 2023 Pogledajte ovo što su Italijani ugrađivali. Ugradnja odozgo. 1. Ugradnja - https://www.youtube.com/watch?v=tC2owmuSdGg 2. Prikaz - https://www.youtube.com/watch?v=GOzedhC4A1I 3. Uređaj - https://www.aliexpress.com/i/4001290115513.html - https://www.youtube.com/watch?v=1n34Ou-YJg0 - https://www.youtube.com/watch?v=j4wWQtUQtLs 1 zoranzo reacted to this Quote Share this post Link to post Share on other sites
nebojsa zvezdara 269 Posted November 19, 2023 (edited) NAV update/maps.mopar.eu/Fiat Tipo 1.0 LIFE 7HD NAV Live GPS Live: Evo, od oktobra 2022. kada sam uzeo novi auto, šesti po redu TomTom NAV update (serial number 11020), uspešno kao i do sada, 29 minuta,...besplatno 3 godine, tj. do oktobra 2025. Pozdrav svima... Edited November 19, 2023 by nebojsa zvezdara Quote Share this post Link to post Share on other sites
PedjaZ 13 Posted January 2 (edited) On 4/6/2022 at 6:13 PM, PedjaZ said: Andreja Znam za to ali jos malo dodas i imas android tipskog kineza. Sandro88 Guglaj AAAD fermata auto Nisam probao jer AAAD ima ogranicenje downloada jedne aplikacije mesecno ili plati. Ivane Za fantomsko napajanje znam jos od mikrofona Zato sam rekao da je interno na plavi povezano napajanje (onaj mali linerni regulator sa 8 nožica) + ostale komponente oko ulaza. Ako štede, ne bi toga bilo. Da mogu videti unutrasnjost nekog NAV pa da se vidi sta on ima a ovaj nema. Isto i za parking kameru. Po ovome šta sve sadrži (bar za ono poznato), ništa se ne bavi obradom analognog video signala tako da su za parking kameru verovatno u pravu kada kažu da ne može ali me interesuje šta će tu antena za GPS ako zvanično nije NAV. 43340Q1 Quad-Output Power Supply 92540E ? Dual N-channel 40 V, 29 mΩ logic level MOSFET CSR G0531 B01AGBL ? RF IC SST 39WF1602 IC: FLASH memory; 1Mx16bit; 70ns; BGA48; parallel; A2C11980300 7EA18 HBBSY ? Memorija, verovatno fleš LVC16374A 16-Bit Edge-Triggered D-Type Flip-Flop With 3-State Outputs D78F1843A ? uC NXP SAF7751HV/205 Audio DSPs TDA75610LV pojačalo 4 x 45 W I2C MCIMX6U6AVM08AC ARMR CortexR-A9 800MHz 29F8G08ABACS NAND FLASH memorija M29W256GL 256Mb: 3V Embedded Parallel NOR Flash 6YE17 D9PZQ DDR3L Memory IC 4Gb 800MHz 6YE17 D9PZQ DDR3L Memory IC 4Gb 800MHz Ovaj ARM ima 3 USB-a - ali je Fiat samo jedan iskoristio, ima LAN, ima svasta nesto ali naravno - ne koristi se. Evo kako su neki još veći zaluđenici dodavali UBS na nekom tamo ruteru pozdrav Mozda ce nekoga zanimati... Za rikverc kameru se brine ADV7182 (10-Bit, SDTV Video Decoder with Differential Inputs) koji je zalemljen na ploci, a nema ga kod NORVC modela. Treba probati da li ce se dobiti funkcija rikverc kamere lemljenjem delova i omogucavanjem opcije u MES-u. Kada se uporede modeli bez GPS-a, postoje oni kod kojih nedostaje 8Gb fles memorije (nije zalemljena - 29F8G08ABACS) i oni koji je imaju ali opet je napisano da nemaju GPS. Ostalo gotovo da nema razlike. GPS signal (plava boja) ide do nepoznatog integralca (verovatno GPS frontend - CSR G0531 B01AGBL) - ovo je fotografija mog uconnect-a "bez GPS-a" koji ima fles memoriju. Ima sve sto treba da ima, a opet nije GPS model. E sada, ovde je cudno da su ustedeli na jeftinom AD konvertoru za rikverc kameru, a ostavili GPS frontend i flesh memoriju koji se takodje ne koriste. Koja je razlika izmedju GPS i NAV modela? rikverc: gps: Edited January 2 by PedjaZ 1 knezevic76 reacted to this Quote Share this post Link to post Share on other sites
Mihailo92 20 Posted January 6 Uspešno uključen AA, konačno Kao što sam i mislio, problem je bio plavi adapter. Da li ste vi, koji ste naknadno omogućili AA, ažurirali firmware nakon te procedure, i da vam je AA ostao omogućen? Takođe, da li je potrebno da svaki inkrementalno ažuriram ili mogu na poslednji odmah? Quote Share this post Link to post Share on other sites
