Sedla 2576 Posted July 16, 2023 (edited) On 7/14/2023 at 7:40 AM, PremieRacing said: Ma bitno da je lepa sve ostalo se sredi E vala...bukvalno sve da joj oprostiš zbog toga kako izgleda. Juče svratio kod Strahinje, uzeo drugi turbo. Sutra ga nosim u servis na proveru i sredjivanje, pa ako bude sve kako treba sledeći vikend zamena. Usput mi Straja i napunio klimu za dž...sad može Brera da se vozi sa zatvorenim prozorima. Edited July 16, 2023 by Sedla 9 Axic, Mijailović P., Ivan-Topola and 6 others reacted to this Quote Share this post Link to post Share on other sites
werp690 459 Posted July 16, 2023 Ne moze se sve pohvatati. Pored vec cuvene legende foruma majstor Bureta u igru je usao i Strahinja. Bure je dosao tiho i usao u legendu ali ko je Strahinja? 4 Axic, Sedla, Dzimbo and 1 other reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted July 16, 2023 Strahinja je moj drugar i čovek od kojeg sam kupio i 159 i sada Breru. I bratovu 147 Q2 i drugarov MiTo itd itd... 1 werp690 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted July 16, 2023 2 hours ago, werp690 said: Pored vec cuvene legende foruma majstor Bureta Nevidjen majstor , ali kao da ga svi znamo. 5 Axic, werp690, Dzimbo and 2 others reacted to this Quote Share this post Link to post Share on other sites
Ivan-Topola 329 Posted July 16, 2023 Takvu legendu od coveka treba svako da upozna 2 Sedla and werp690 reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted July 16, 2023 Majstore "ne valja" ni u kafani sretati. 3 3 Dale, werp690, Dzimbo and 3 others reacted to this Quote Share this post Link to post Share on other sites
Axic 20048 Posted July 16, 2023 3 hours ago, Sedla said: drugarov MiTo itd itd... Uuh, muškarac i Mito ne ide jedno s drugim. Zna li drugar za kakav je auto proglasen Mito 4 Dzimbo, Quadrifoglio Verde, Sedla and 1 other reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted July 16, 2023 Naravno. Zaebavam ga svaki put kad se sretnemo 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted September 19, 2023 (edited) Edited September 19, 2023 by Sedla 6 1 PremieRacing, Milutinac, Ivan-Topola and 4 others reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2186 Posted September 20, 2023 Brena je Brena, al' dvaput je dvaput. Šta se sad dešava, ipak mora đunta sa sitnijim nutom? 2 Sedla and Quadrifoglio Verde reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted September 20, 2023 Sva sreća pa te vreme služi... 2 Sedla and Dale reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted September 20, 2023 10 hours ago, Sedla said: Drage moje kolege, e bas upravo zbog ovakvih kao sto je nas Sedlic - Alfa i ima reputaciju kakvu ima : 2 3 alfini0507, MiloshBg, Axic and 2 others reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted September 20, 2023 (edited) 15 hours ago, Reacher Gilt said: Šta se sad dešava, ipak mora đunta sa sitnijim nutom? A morao sam da zamenim turbo, već je počeo da pravi probleme. Išao sam jedno veče u Obrenovac, da radim farove na Breri, kod druga Stefana (Xenon Cartel) i terao sam je pun gas,koliko god je moglo. Kao da sam je ukrao, što bi rekli.Međutim u povratku iz Obrenovca je počela sve teže da prima gas, ide kao vezana za drvo. I inda sam prelomio i rešio da konačno ugradim novi turbo koji već mesec dana bleji u garaži i skuplja prašinu. Kad sam skinuo stari turbo, nije imao mnogo lufta i nije puštao ulje, ali se jedva okretao. Probaš da zavrtiš propeler, on se jedva okreće. Kao da je zaribao. Naravno, ne može sve da ide glatko... I još jedno obaveštenje za drugare - nemojte se igrati sa separatorom uljih para ako ne znate. Ili što bi rekli - narani prasiće i ne diraj dugmiće. Umal' nisam uništio motor. Ne mogu da postavim snimak ovde, ali evo dve slike,možda će vam nagovestiti nešto... Edited September 20, 2023 by Sedla 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Axic 20048 Posted September 20, 2023 12 minutes ago, Sedla said: Ne mogu da postavim snimak ovde, ali evo slike,možda će vam nagovestiti nešto... Ako nema ulja ispod Alfe nema ni u njoj? 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2186 Posted September 20, 2023 1 hour ago, Sedla said: već je počeo da pravi probleme 1 hour ago, Sedla said: terao sam je pun gas,koliko god je moglo 1 hour ago, Sedla said: počela sve teže da prima gas, ide kao vezana za drvo 1 hour ago, Sedla said: on se jedva okreće. Kao da je zaribao 1 hour ago, Sedla said: ne može sve da ide glatko... Sedla, Alfa egzekutor, Turbo terminator ! 1 hour ago, Sedla said: narani prasiće i ne diraj dugmiće. Da mi ovo neko drugi rek'o da si ti rek'o ... 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted September 21, 2023 @Reacher Gilt ala si ga sastavio... da pomisli neko da sam neki težak akadžija, iživljavam se na kolima. Inače, ono famozno upadanje u "safe mod" a bez prijavljivanja greške na tabli i na dijagnostici,koje sam više puta pominjao....rešio sam i to. U pitanju je bio *ebeni EGR ventil. Brat @Milutinac će me razumeti. EGR koji je softverski ugašen je pravio sve probleme. Loša elektronika je slala ko zna kakve podatke na ECU, i zbog toga je upadalo u safe. A pošto je ugašeno da ne prijavljuje ništa sa EGR-a, zato i nije izbacivalo nikakvu grešku. 7 MS PK, Milutinac, werp690 and 4 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 25, 2023 Razume razume, ali ne bi da se seca tog perioda Bitno je da si resio...tu ima neki problem jednostavno. Mi smo prikacili dijagnostiku i isli konektor po konektor, cistili, vracali, stavljali itd...i u jednom momentu samo sa greske za protokomer prebaci na gresku EGR-a, ne secam se sada broj sifre, nije ni bitno, ali tu skontamo o cemu se radi... 1 2 Sedla, horvat and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted September 27, 2023 (edited) Zašto bi moralo sve da bude jednostavno? Brera mi nikada neće biti dosadan auto. Jeftin pogotovo. Edited September 27, 2023 by Sedla 3 1 2 MS PK, PremieRacing, Quadrifoglio Verde and 3 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted September 27, 2023 Pa sta je, antena?Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
Sedla 2576 Posted September 27, 2023 99% antena. Nema veze, će ga rešimo. 3 Reacher Gilt, PremieRacing and Ivan-Topola reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted September 28, 2023 Taman u crnu alkantaru... 7 Reacher Gilt, Quadrifoglio Verde, horvat and 4 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 28, 2023 Kad čovek da stigne da se bavi kočnicama od ovakvih gluposti... 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Markoni Bg 74 Posted September 28, 2023 Skini cep i dotegni kljucem ima velika matica na osovini antene , isto problem bio kod mene na 147 posle prve jace kise. 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted September 28, 2023 U slucaju da nisu propali gumeni dihtunzi. Postoji veliki spoljni i obicno jos jedan manji prsten sa donje strane krova. 1 Sedla reacted to this Quote Share this post Link to post Share on other sites
Quadrifoglio Verde 9319 Posted September 28, 2023 Škk...? Otkud Breni antena na krovu? 2 Sedla and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
