mishja 1 Posted August 26, 2018 On 8/25/2018 at 3:39 PM, Danko77 said: Ko to ima koja kinta? Jel se isplati kupovati elm 327 I jer se može raditi kalibracija volana;) sa njime? Koji je dobar uređaj posle elm 327? aj da ti ponovim, kod tebe na puntu ELM nece da radi kad kupujete elm ili kkl nek budu sa ftdi cilom, imam oba i rade perfektno, povezivanje za 3 sekunde Quote Share this post Link to post Share on other sites
vladac81 23 Posted November 13, 2018 Da li je neko instalirao multiecuscan na tablet uredjaju sa windows operativnim sistemom a da je ELM uredjaj na usb kablu? Quote Share this post Link to post Share on other sites
Iggy_pop 1 Posted December 20, 2018 xy mjeseci i jos nisam uspio da nadjem drivere za kkl vag-com 409.1 neko???? Quote Share this post Link to post Share on other sites
djomla 8386 Posted December 20, 2018 (edited) http://www.totalcardiagnostics.com/support/Knowledgebase/Article/View/23/0/how-to-install-vag-com-4091-kkl-cable-on-windows @Iggy_pop pokušaj ovde, javi samo da li si uspeo. Edited December 20, 2018 by djomla Quote Share this post Link to post Share on other sites
Iggy_pop 1 Posted December 25, 2018 (edited) On 12/20/2018 at 9:30 PM, djomla said: http://www.totalcardiagnostics.com/support/Knowledgebase/Article/View/23/0/how-to-install-vag-com-4091-kkl-cable-on-windows @Iggy_pop pokušaj ovde, javi samo da li si uspeo. nisam uspio nagovoriti glupavi XP da povuce sa windows update-a Znaci pod xindows xp dalje od treceg koraka ne mogoh. A nekada davno 6-og maja 2016 sam objavio na stranici 100 ovog posta da sam uspio. Znaci isti laptop, isto xp, isti kabal. tada radilo. Edited December 25, 2018 by Iggy_pop Quote Share this post Link to post Share on other sites
Fiat marea 1.6 0 Posted March 12, 2019 Drugari nemogu nikako se povezem na ecu,osiguraci dobri,zice nisu u prekidu a nece i nece,dijagnostika provereno radi?sta ciniti? Drugari nemogu nikako se povezem na ecu,osiguraci dobri,zice nisu u prekidu a nece i nece,dijagnostika provereno radi?sta ciniti? Quote Share this post Link to post Share on other sites
kakashi 3 Posted March 18, 2019 pokusavam da nadjem krekovanu/registrovanu verziju mes-a i ne mogu nista da postignem osim izgbljenih zivaca...ima li to uopste Quote Share this post Link to post Share on other sites
nkolina20 0 Posted April 2, 2019 (edited) pozzz ljudi radi se o multiecuscan pročitao sam na forumu da su skidali program probavali i sve da im radi kod mene neće nista skidao sam par verzija 3.0, 3.5, 3.6, 3.7, 4.0, uspijem da registrujem program sa crackom koji je ponuđen jednostavno piše da je MES registrovan neće da se spoji ni na jednu opciju pa čak na na can info sa crekovanim verzijama to izgleda ovako prvih 6 slika 1. podešavanje elm-a to je prošlo sve ok. elm mi kupio drugar u Engleskoj modifikovam sa fdti chipom za MES 2.sa free verzijom bilo kojom sa tim istim elm se spaja bez ikakvih problema znači ono što može can info, mislim servis i mogao sam da otvorim neke podatke kilometraža šaljem slike i od free verzija znači očitanje elm je isto i na krekovanim verzijama (na njima neće uopste da se spoji piše failed elm 327 ) a na free MES se spaja bez problema ne znam u čemu je stvar svašta sam probao da li se desilo u međuvremenu da to više neće da radi čak kad sam instalirao program isključio sam wifi reko da ne povueče neku zaštitu prilikom instalacije sa neta to sam posle probao ništa ne pomaže koristim win. 10 sve je uredno očitao com port 6 fdti uredno radi znači sve ok unapred zahvalan na odgovoru Edited April 2, 2019 by nkolina20 Quote Share this post Link to post Share on other sites
djomla 8386 Posted April 2, 2019 Da li si podesio com port i instalirao drivere kako treba? Sent from my 3310 Quote Share this post Link to post Share on other sites
nkolina20 0 Posted April 2, 2019 (edited) koliko se ja razumem mislim da jesam a drivere sam skinuo sa fdti.chip stranice evo slika šta sam radio a i probao sam da spojim na scan master demo sve ok i na free verziju MES na na krekovanu MES ni mrc neće pa neće sad sam opet brisao instalirao neće probao sam znači sa ove stranice fiat-lancia MES 3.7 nće da radi 3.6 ne mogu registrovati sa njenim crackom ali se reg. od MES 3.7 patch nekakav univerzalan ne znam više šta podešen com port na MES sve očita ok brzina sve do spajanja i onda kraj Edited April 2, 2019 by nkolina20 Quote Share this post Link to post Share on other sites
sibonios 43 Posted April 12, 2019 Da li ima vajde od ovog adaptera? Uklonjen je otpornik R2 ali nema komunikacije sa obd-om. Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted July 26, 2019 Konkretno pitanje je: Kako da skinem km na cajgeru? Stavio sam nov cajger na auto (matrix cajger na gp) nisam imao srece da uzmem sat sa manje km nego sto sam presao pa da podignem preko multiecuscan-a. Na satu pise 314 000 a ja sam presao 201 000. Pa neko ako moze da mi pomogne bio bih zavhalan :-D Quote Share this post Link to post Share on other sites
zeljkoci 58 Posted July 26, 2019 To neces moci preko MES-a! Quote Share this post Link to post Share on other sites
Miki.Zvrk 22 Posted July 26, 2019 Ja se ne razumem bas najbolje ali brzo ucim, ukoliko neko mozebda odradi to bilo bi super. Naravmo zanima me koliko to kosta :-) Quote Share this post Link to post Share on other sites
brdaus 28 Posted September 4, 2019 (edited) Pozdrav, veceras probah da ocitam drugarev Stilo 1.9 JTD iz 2004. i naidjoh na more problema. Prikacio sam delphi i uspeo da ocitam i obrisem greska za abs, tablu, i servis ali nece da ocita motor i air beg. Isto to nece sa MES i KKL i elm327 . Sta bi moglo da bude ? Proveravao sam osigurace u autu i svi su ok. Edited September 5, 2019 by Ivan Spojeno Quote Share this post Link to post Share on other sites
Ivan 17682 Posted September 5, 2019 @brdaus Nepotrebno otvorena tema je spojena sa postojecom o dijagnostici . Quote Share this post Link to post Share on other sites
gile smederevo 574 Posted November 14, 2019 Je l ima neko link za MES sa crackom? Ja se ubih trazecui, ali mi ne ide... Quote Share this post Link to post Share on other sites
sibonios 43 Posted December 2, 2019 On 11/14/2019 at 4:34 PM, gile smederevo said: Je l ima neko link za MES sa crackom? Ja se ubih trazecui, ali mi ne ide... NITROFLARE.COM - INTERCHANGEABLE LINKS (124 MB)http://nitroflare.com/view/42C6A031C833F5A/Fiat.Multiecuscan.v3.6.Full.Registered.zip FILEUPLOAD.PW - INTERCHANGEABLE LINKS (124 MB)http://fileupload.pw/ahk5tdws4khn UPLOADED.NET - INTERCHANGEABLE LINKS (124 MB)http://ul.to/sksg56yh MYFILES.ONL - INTERCHANGEABLE LINKS (124 MB)http://myfiles.onl/a32pr9q1jn78 TURBOBIT.NET - INTERCHANGEABLE LINKS (124 MB)http://turbobit.net/boq6ojwuy12x.html 1 stex_pb reacted to this Quote Share this post Link to post Share on other sites
acar 0 Posted December 17, 2019 kupio sam ftdi vag kkl , povezao sam na stilo 1.9 i radi engine, abs, airbag ali nikako nece u body da udje sto mi najvise treba zbog programiranja kljuca, jel moguce da se udje u body sa ovim ftdi vag kkl ili negde gresim? probao sam mes 4.2, 2.2 krekovane. Quote Share this post Link to post Share on other sites
Ivan 17682 Posted February 13, 2020 Posto odavno nisam u prici oko adaptera sa eBay - prosledjujem ovde pitanje koje mi je nas kolega uputio na PM: Naime kupio sam kabel s ebaya i probao bi ga sad upariti s programom, al mi ne ide bas. Mozes li mi ukratko reći mogu li ga prispojiti ili su nekompatibilni? Ovo je kabel: @dodo Evo i ovde, pa isprati odgovore i ukljuci se u diskusiju . Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 13, 2020 (edited) Verovatno je narucen adapter bez tog nekog potrebnog chipa, zato i ne radi... Imam i ja jedan isti takav. Za kantu je... Sad cu iskopati linkove sa Alija Evo ga, ono o cemu pricam se lepo vidi na drugoj slici https://www.aliexpress.com/item/32823514956.html?spm=a2g0o.productlist.0.0.6c73605aE9HWxx&algo_pvid=dc41f7a0-7ef4-4945-b22f-ddb679ef866f&algo_expid=dc41f7a0-7ef4-4945-b22f-ddb679ef866f-31&btsid=0ab50f4415815929172823382ef8e0&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ Posto nisam mogao da cekam onda opet 2 meseca da stigne taj sa chipom uzeo sam od naseg "prijatelja" sa foruma, za skromnih 2500 dinara, sunce me je*lo... Edited February 13, 2020 by Milutinac 2 1 Mijailović P., Ivan and horvat reacted to this Quote Share this post Link to post Share on other sites
Busso156 0 Posted February 20, 2020 (edited) On 5/9/2010 at 10:49 PM, neshaoct said: Običan kabl...koji služi da povežeš komp, sa kompom automobila. Prilikom čipovanja se menja softver, odnosno postojeća (fabrička mapa) u kompjuteru automobila se menja drugom...sa drugačijim parametrima. Ovaj kabl je samo jedan od ''alata'' neophodnih onim ljudima koji se bave čipovanjem... Ali, sam taj kabl ne služi za čipovanje, tj. samo sa njim možeš da se slikaš... Bravo ! Prvi komentar i hvala Bogu pravi i tačan... Eto, makar ne moram da se smaram i objašnjavam ili raspravljam sa nekim pacijentom Ovo je klasika vaćaroška pa lepo namazano - na kraju je ipak neophodna veza imeđu nekog od izabranih Programa i ECU-a a kabl kao prva još uvek je naravno i najbolja veza, makar za moje pojme. Jedina praktično loša strana odnosno hendikep je to da si osuđen na uređaje sa kompatibilnim USB-om, istina je da bi bilo izvodljivo malo proširiti listu kompat. uređ. nabavkom još jednog kabla ( USB>micro USB). U svakom slučaju je potreban dok genije trlja ruke i ubira plodove kupac uz koju psovku kada shvati da je ispao cava može samo sam sebi da se nasmeje i kaže "svaka škola se plaća" Na stranu sada sva zajebancija - istina ima da se naće za cca 15 evra ali isto tako ima ih i mnogo skupljih od ovoga... Ako radi i solidnog je kvaliteta - nije to puno love.... I dobro - koji kabl odnosno "alat" je (još) potreban za čipovanje - odnosno mapiranje ? Edited February 20, 2020 by Busso156 Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 21, 2020 14 hours ago, Busso156 said: I dobro - koji kabl odnosno "alat" je (još) potreban za čipovanje - odnosno mapiranje ? Imamo posebnu temu oko čipovanja, klik na: https://www.fiat-lancia.org.rs/forum/index.php?/topic/36586-chip-tuning-čipovanje/ @zalik @McSteel Quote Share this post Link to post Share on other sites
Dexa313 13 Posted July 18, 2020 Interesuje me da li vako nesto zavrsava poso da se ocitaju kodovi gresaka i da se greske pobrisu . Treba mi za Fiat bravo 2001 god. https://www.silux.rs/proizvodi/dodatna-oprema/elektronika-i-dodatna-oprema/ureaji-za-dijagnostiku-vozila/5247363/ureaj-za-auto-dijagnostiku-icar-obd2-bluetooth?refurl=%2Fproizvodi%2Fdodatna-oprema%2Felektronika-i-dodatna-oprema%2Fureaji-za-dijagnostiku-vozila%3Futm_source%3Dcriteo%26amp%3Bamp%3Butm_medium%3Dretargeting%26amp%3Bamp%3Butm_campaign%3Dlowerfunnel Ako ovo ne valja onda dajte neku preporuku za dijagnostiku koja bi radila s telefonom. Sent from my Mi A1 using Tapatalk . Sent from my Mi A1 using Tapatalk Quote Share this post Link to post Share on other sites
Dexa313 13 Posted July 23, 2020 Dijagnostika mi je stigla i radi na fiatu . Nisam nesto mnogo cackao , procitao kodove gresaka i obrisao. Kasnije cu videti dal radi i na golfu 4 1,6 benzinSent from my Mi A1 using Tapatalk Quote Share this post Link to post Share on other sites
