Ivan BG 720 Posted August 30, 2019 (edited) Malo sam se ponovio. Edited August 30, 2019 by Ivan BG 11 1 horvat, dekirs, darkman14 and 9 others reacted to this Quote Share this post Link to post Share on other sites
shuxx 10884 Posted August 30, 2019 Šta reći, sve najbolje ti želim, da te lepo služi i da uživaš u njoj vozio sam AR 33, i volim AR, a tek karavane, a tek 159 SW.... bukvalno se okrenem za nekom... moglo bi se reći da AR 159SW ima sve što mi treba... Quote Share this post Link to post Share on other sites
marko.jovanovic 925 Posted August 30, 2019 A Golf? Prevagnula cena? 159ke su jeftine do bola, koštaju ko punto jbt. Quote Share this post Link to post Share on other sites
Ivan 17679 Posted August 30, 2019 Sa srecom, ime . U zdravlju da se vozas ! Quote Share this post Link to post Share on other sites
horvat 6456 Posted August 30, 2019 Nisi napisao koje godiste? Daj jos malo slika Cestitke i da se lepo navozas Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted August 30, 2019 Čestitke Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted August 30, 2019 Čestitke Quote Share this post Link to post Share on other sites
zunto 517 Posted August 30, 2019 On 8/30/2019 at 4:11 AM, Ivan BG said: Malo sam se ponovio. da se u zdravlju i sreci navozas i za bolji promenis Quote Share this post Link to post Share on other sites
totti 13165 Posted August 30, 2019 On 8/30/2019 at 12:38 PM, zunto said: i za bolji promenis To uopšte nije teško 3 skile86, marko.jovanovic and dellas reacted to this Quote Share this post Link to post Share on other sites
Stilisa 313 Posted August 30, 2019 Svaka cast Ivcooo, da se lepo navozate. I nemoj da stedis na slikama Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted August 30, 2019 6 hours ago, horvat said: Nisi napisao koje godiste? Daj jos malo slika Cestitke i da se lepo navozas 2007-mo. Oprema sasvim solidna, kozu nema iskreno nisam je ni hteo, t.j. kola sa kozom nisam ni gledao, a crna boja je bila ako bas mora, i na kraju bas ona. Klapne su skinute, dpf iskljucen softverski, nikakvih dimova nema na auspuhu. Ide lepo, deluje utegnuto, za ovih 130 km koliko sam presao sa njim solidno se pokazala. Idem danas za ŠA pa cu jos malo da vidim kakva je. 8 hours ago, marko.jovanovic said: A Golf? Prevagnula cena? 159ke su jeftine do bola, koštaju ko punto jbt. Nemam pojma, verovatno, nekako mi je bilo vrlo malo prihvatljivo da uzmem neki G5 iz 2005 ili 2006 i da za njega dam jedno 4000e, + alarm, zeder, servisi, registracija (ako je na ime kupca), i sigrno jos nesto, uvek je tako. Stizem na cifru od skoro 5500e za auto star skoro 15 godina. A i realno svidjala mi se uvek 159, sada je mozda zadnji voz da se uzme neka pristojna, kako vreme prolazi bice sve manje i manje dobrih primeraka. Vozicu je jedno dve godine pa onda nesto drugo mladje da uzmem. Hvala svima na cestitkama. 3 dekirs, bit and dach@ reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted August 30, 2019 cestitke Ivane,da uzivas i puno kilometara sa Alfom,a cekamo slike Na forumu svaki dan sve vise Alfi i nemackih auta,sve manje Fiata Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted August 31, 2019 (edited) Ostao sam duzan neku sliku, malo je strokava ali poenta se vidi. Iz ne znam kog razloga nece da prihvati jos par slika. Uglavnom, stakla napred tonirana, pozadi fabricki zatamnjena (videcemo kako ce drugovi organi reagovati kad se sretnem sa njima). Kao celina je dobra i kompletna, i to me je privuklo, koliko vidim nigde nije fabana mada mi to nesto posebno nije bilo ni bitno vise mi je bilo bitno kako je uradjeno. Edited September 1, 2019 by neshaoct formatiranje 2 Axic and darkman14 reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted August 31, 2019 Čestitke!!! Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted September 1, 2019 (edited) Hvala, Hvala. Izgleda da slike vece od 3mb nije moguce postaviti na forum, tek kada sam ih smanjio hoce da ih prihvati. Motor prasnjav, suv, turbo takodje, bas kako trebaju da izgledaju. Edited September 1, 2019 by Ivan BG Quote Share this post Link to post Share on other sites
Martin 799 Posted September 1, 2019 Jel stigla baš iz SM ili okolina? Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted September 1, 2019 Bas SM ali je ja nisam odatle direktno uzeo, sledece nedelje cu da zavrsim prenos na svoje ime i da vratim SM table. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 1, 2019 Čestitam On 8/30/2019 at 5:16 PM, Ivan BG said: ...verovatno, nekako mi je bilo vrlo malo prihvatljivo da uzmem neki G5 iz 2005 ili 2006 i da za njega dam jedno 4000e, + alarm, zeder, servisi, registracija (ako je na ime kupca), i sigrno jos nesto, uvek je tako. Stizem na cifru od skoro 5500e za auto star skoro 15 godina. To sam hteo da kažem između redova i ono kad smo kuckali oko Golfa 5, zato sam pominjao Deltu jer je isti segment kao Golf, nisam znao da u obzir dolazi i veći auto... Quote Share this post Link to post Share on other sites
dekirs 4819 Posted September 1, 2019 Veci, sa manje prostora na zadnjoj klupi Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted September 1, 2019 Ih, ima manje ili tek isto mesta kao kod Brava, a kamoli kod Delte... 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted September 1, 2019 Hvala. Nemam ja neku zamerku na kolicinu prostora na zadnjoj klupi. Ja stajem iza sebe pozadi (visok sam 190 cm), kolega @Axic je sa svojih 197 cm stao iza lika od koga sam uzeo AR 159 (isao je samnom tada po nju), a rekao bih da je prodavac bio neki cm nizi od mene. Mozda nema mesta za tri odrasla putnika na zadnjoj klupi ali za dva sigurno ima. A i realno ja se ne vozim pozadi, vozi se klinac tako da tek za njega ima dovoljno mesta. Quote Share this post Link to post Share on other sites
Axic 20048 Posted September 1, 2019 Istina, dok je bila test vožnja ja sedeo iza vozača i za tih 10-ak minuta dok smo se vozili nisam osetio manjak prostora za noge. Quote Share this post Link to post Share on other sites
totti 13165 Posted September 1, 2019 Pa jbt, valjda ti je dovoljna i jedna sekunda da osetiš 1 Gagy.GM reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted September 1, 2019 Kod Axica mora malo da odstoji 1 Axic reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted September 1, 2019 Dovoljna verovatno al vise veruje drugima koji lupaju nego svojim ocima..i nogama Quote Share this post Link to post Share on other sites
