Ivan 17447 Posted February 22, 2020 @ISV_01 je upropastio kupoprodaju. Da ne kazem uprskao . 1 1 Axic and djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8385 Posted February 22, 2020 Oćeraš ga na dubinsko i milina Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted February 27, 2020 Danas nova ulaganja u 159-ku. Quote Share this post Link to post Share on other sites
Ivan 17447 Posted February 27, 2020 Sminka ili kobra? 1 Ivan BG reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted February 27, 2020 Metlica brisaca na gepek vratima. Cirka 1300 rsd, komplet sa nosacem. Quote Share this post Link to post Share on other sites
Ivan 17447 Posted February 27, 2020 Sto si menjao celu metlicu? Neki problem ili... ? Licno menjam samo gumice brisaca, kada im dodje vreme. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted February 27, 2020 (edited) Nije bilo potrebe, osim sto je gumeni deo dotrajao, nije neki trosak a fabrika je fabrika. Probao sam par puta to sa zamenom gumica (na nekim kolima koja sam ranije imao), pa ih ili nisam vracao kako treba ili profil gumice nije bio odgovarajuci. Edited February 27, 2020 by Ivan BG Quote Share this post Link to post Share on other sites
Ivan 17447 Posted February 27, 2020 Da, ima ih par tipova... Samo pogledas sta ti je na autu i uzmes to isto , nema potrebe menjati celu metlicu. A zamena je boza. Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted March 18, 2020 (edited) Na zapadu nista novo, samo da ne fasuje(mo) Covid - 19. Pali, radi, ide....za sada. Edited March 18, 2020 by Ivan BG 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted May 2, 2020 Slabo se vozimo ovih dana, provozao sam je jutros posle 11 dana, dodjem sa posla oko 17h, policijski cas krece u 18h (do skoro je bio od 17h), nemam kad da je vozim, cak sam se i zamslio hoce li upaliti, dugo stajala bez voznje ili paljenja u mestu, naravno upalila je kao da je ugasena pre sat vremena. Nesto se mislim da je zamenim za nesto drugo, posto supruzi nije "legla", kaze dugacka je niska napred, relalno vozila je samo jednom, tako da ce verovatno pasti zamena za nesto novije, kompaktnije, za lakse manevrisanje po gradu. Trenutno se po oglasima zanimam za Fiat 500L, po dimenzijama kraci je od AR 159 za citavih 52 cm, klrens mu je vislji i uopste prednji branik je napred znatno vislji. Ne bih uzimao ispod 2014-tog godista, videcemo sta ce biti na kraju. Trenutno, za ovo vreme koliko je kod mene nemam sta da zamerim svojoj 159-ci. 1 Martin reacted to this Quote Share this post Link to post Share on other sites
Ivan 17447 Posted May 2, 2020 Moje saucesce . 2 1 Axic, djomla and darkman14 reacted to this Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 2, 2020 Onda ne menjas auto, vec..... Sent from my LYA-L29 using Tapatalk 6 McSteel, MS PK, Mijailović P. and 3 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted May 2, 2020 Konacno, glas razuma.. Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Boris90 367 Posted May 2, 2020 Mozda Djulijeta ako ti ne smeta dosta nekvalitetniji enterijer u odnosu na 159 Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted May 23, 2020 Nije rec o Alfi ali da pomenem i ova dva auta. Ja sam razduzio sluzbenu Hondu a supruga sluzbenu Daciju. Supruga je prosla bolje, te je dobila Skoda Fabia (trenutno zamenska ali uskoro stize bas njena), a ja sam dobio Fiat Pandu, oba auta su u kombinaciji Benz+TNG. Sto se Pande tice vozim je skoro mesec dana i osim toga sto je mala i moze se parkirati svuda drugih prednosti nema, zvucna izolacija ne postoji, 1.2 u kombinaciji sa TNG-om ne ide nikako, poskakuje na neravninama, sedista su pravljena za nekoga ko je visok max 170cm (kratak sedalni deo), bocna potpora je nikakva....pretprecu je nekako od ponedeljka do petka. Vikendom ne mogu da se nacudim kako auto moze da ide (AR 159), a opet pondeljak mi treba da se naviknem da stiskam gas i da se nista ne desava. Sto se Fabie tice, juce je dosla pa je rano za neke utiske. Alfa je definivno na prodaju, pa ako nekoga zanima mozemo pricati. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted May 23, 2020 Otvori temu u podforumu, postavi slike i cenu i reseno, koga interesuje Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted May 30, 2020 Vikend na Zlatiboru. 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted June 1, 2020 On 5/23/2020 at 1:49 PM, MS PK said: Otvori temu u podforumu, postavi slike i cenu i reseno, koga interesuje Otvorena tema u odeljku oglasi. Inace dosli danas sa Zlatibora bez ikakvih anomalija, put nisam osetio. Bas mi je zao sto je moram zameniti za nesto manje. Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted July 6, 2020 Ostavio sam danas 159-ku kod majstora. Primetim u subotu kad sam je upalio neko sitno skripanje ispod haube, u prvi mah pomslih da nije zamjac (ne kazu dzabe da je u Srba veci strah od zamajca nego od promaje), bio sam pored kola sa strane menjaca, dignem haubu i vidim da je negde iz pravca remenica. Bio sam u dilemi da li je iz PK kruga ili je do spanera ispod remenica bregastih osovina. Uglavnom upalim je danas, vidim na bordu ikonicu akumulatora, podignem haubu i bi mi jasno, alternator, taman je on tu visoko sa zadnje strane motora. Kako god, ostavih je majstoru, pa ce je sutra ili u sredu resavati, rece mi odmah alternator ti se cuje. Mozda je samo lezaj, mozda se "nekako" PK kajis olabavio mada sumnjam da je to moguce, videcemo, svakako cu mu reci neka pretrese alternator. Sad za subotu sam joj i tehnicki zakazao, da produzim registraciju. Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted July 9, 2020 Problem resen. Remenica alternatora je bila problem, zamenjena je novom (INA) i sve fercera kako treba, zamenio sam i PK kajis, nisam hteo da se vraca stari. Usput sam rekao majstoru da je pretrese posto u subotu ide na tehnicki pregled i produzetak registracije. 1 1 Martin and neshaoct reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted July 9, 2020 @Ivan BG Je l' zovu ljudi za oglas, ima li interesovanja? Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted July 9, 2020 Nude zamene po nekim nebuloznim cenama, npr. PUG 207, 1.4 benz, 2008-mo, 5v po ceni od 3500e.....stare Fabije, AR 147 sa pocetka proizvodnje (bilo je i mladjih), MB E klasu karavan iz 2003.....i tako svasta nesto. Produzicu joj registraciju sad u subotu, pa je mozda skinem sa oglasa, a mozda je i ostavim ali sa vecom cenom. Sve sam blize tome da je ne prodajem uopste. 2 knezevic76 and silenci reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted July 9, 2020 Ma da, nema razloga auto u takvom stanju i opremi davati budzašto... 2 Ivan BG and darkman14 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17447 Posted July 10, 2020 I onda cesto onaj ko je resio da ide na upgrade, dodje do toga da kupi neki lep auto koji istrci na oglasima, da se ne bi prodao. I uglavnom na kraju za svoju prodaju popusti pod navalom ponude i cena krseva . Pogotovo vazi za sve ove nase narodne automobile. A ko (kao ti) ne zuri i ne zanimaju ga neblozne menjaze za konzerve, drva i sl. , moze i lepo da prodje. 1 Ivan BG reacted to this Quote Share this post Link to post Share on other sites
Ivan BG 694 Posted July 11, 2020 Prosla na tehnickom 1:1. Razlike u silama kocenja: Napred 0% Nazad 1% Rucna 1% Svi brojevi (motora prvenstveno) se vide kako rece ovaj sa tehnickog "iz aviona" nema nikakvih dilema, rece odlican auto. Total cena registracije 34650.00 din sa polisom na premijski stepen 4. Quote Share this post Link to post Share on other sites
