Zvezdo 1580 Posted September 21, 2021 Ništa gore od crne boje ! Koliko para sam dao kupujući jači Karcher i silne šampone i to bez nekog posebnog efekta imao bih za praonicu narednih 20godina. 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
Ivan 27696 Posted September 21, 2021 1 hour ago, alfini0507 said: Sta znam... Sledeci je definitivno siv... 'Oce to... Tako i ja kazem da cu konacno neku svetliju, pa na kraju uvek natrci primerak i stalno zavrsim sa tamnim bojama . Inace sam odavno prestao da se opterecujem sa tim. Nakanim se da operem auto jednom mesecno bas detaljno spolja - dvoriste, crevo, sve mackalice (nekada prodje i duze, ne racunam zimu kada sperem so). U medjuvremenu vikendom samo prebrisem stakla i signalizaciju (doduse auto uglavnom bude pod nadstresnicom ili u garazi i kuci i na poslu). Ali unutra volim da je kao apoteka i cisto, tu me stvarno ne mrzi da lickam. 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted September 21, 2021 Tako će i biti... Unutra OK a spolja "Dirt style" Sent from my Redmi Note 3 using Tapatalk Quote Share this post Link to post Share on other sites
Vule 963 Posted September 21, 2021 (edited) Samo dobar vosak i jednom nedeljno pod puške Edited September 21, 2021 by Vule 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
MS PK 8836 Posted September 21, 2021 I hemija spere vosak i tako, u krug Послато са SM-A307FN помоћу Тапатока 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 5286 Posted September 21, 2021 Bas hteo da napisem... Ja posle voskiranja ne cackam auto jedno 3-4 meseca, samo voda i to je to, pa ponovo rucno pranje i u krug. 2 alfini0507 and MS PK reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted September 28, 2021 Stigli taman na vreme... A Bosch će "komisijski da se spali..." Sent from my Redmi Note 3 using Tapatalk 1 Martin reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted October 8, 2021 Brisaci rade OK... Kad ima par kapljica hoce i oni malo da skripnu... Kad je lepo nakvasena soferka sve OK...Malo pre na poslu zamenjen filter vazduha... Mozda je stari ipak mogao da potera jos neki kilometar nego ajde da mu olaksamo disanje... Korona je jbga... Kutija filtera lepo usisana pre stavljanja novog... Sent from my Redmi Note 3 using Tapatalk 3 Martin, MS PK and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
danijel55 947 Posted October 9, 2021 Preporuka za motohama metlice,jeftine,brisu odlicno,ne skripe ni najmanje. 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted October 22, 2021 Idemo dalje sa ulaganjima... Ima li neko ideju gde potražiti kvalitetnije solje prednjih amortizera za gdju Cromu? Nesto tipa Lemforder Sent from my Redmi Note 3 using Tapatalk Quote Share this post Link to post Share on other sites
Martin 828 Posted October 23, 2021 Mislim da sam uzimao u Delmaxu. 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
djomla 8492 Posted October 23, 2021 http://www.hemtex.co.rs/ Proveri i ovde. Sent from my 3310 using Tapatalk 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted October 23, 2021 Hvala velika drugari Javnem da li je potraga uspelaSent from my Redmi Note 3 using Tapatalk 2 djomla and Martin reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted October 25, 2021 Našao po 3500RSD/kom Lemforder u lokalnoj radnji... Mislim da i nije toliko losa cena... U drugoj bio neki Magnum za 3400...Jedna okrugla brojka pred sutrasnji tehnički... Držite mi palčeve...Sent from my Redmi Note 3 using Tapatalk 3 Martin, ISV_01 and Djuk85 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted October 26, 2021 https://youtu.be/jpt7D_DO9F8 Idemo dalje do sledećeg tehničkog! EGR & DPF OFF RULES!!! sve u granicama propisanog Sent from my Redmi Note 3 using Tapatalk 3 horvat, djomla and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Ivan 27696 Posted October 26, 2021 6 MS PK, djomla, vicent and 3 others reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted December 1, 2021 Poslednjih mesec i po dana pri prvom jutarnjem paljenju poceo da luduje... ASR not available, hillholder i sl da bi kao vrhunac upalio famozni Check Engine i dve greske koje se nisu brisale po gasenju i ponovnom paljenju... U mirovanju pre paljenja aku je pokazivao 12.6 sto i nije tako lose... Sa ukljucenim potrosacima u radu voltaza je isla od 13.9 do nekih 14.1-2 u zavisnosti od toga sta je sve popaljeno... Aku je bio Fiat origigi sa kojim sam i kupio auto a na kraju se ispostavilo da je proizveden 2017... Za mesec i po dana od kad traje gore navedeni LightShow 2x je punjen ali kako se ispostavilo bezuspesno.... Resih se da odem do lokalne radnje da ga provere... Prikacio ga momak na neki test uredjaj koji je na ful zagrejanom motoru vozenom nekih sat vremena po gradu pokazao oko 12.8V ali i poruku "Battery bad - Replace battery"... Odlucih se za ToplaTop +30 od 78Ah i 750A... LightShow turned off a gore pomenute dve greske se vise ne javise... btw set kvacila sa zamajcem mi je zamenjen ali sam stalno imao utisak da zatrese vise nego sto treba pri paljenju... Toga vise nema... ToplaTop model me jako dobro sluzio u proslom autu, Vectra B 2.0Di sa pa skoro 90% gradske voznje sa kratkim relacijama... Aku je bio star oko 8 god kad je auto prodat i i dalje je palio kako treba... Nadam se da ce i ovaj opravdati ulozeno a ruku na srce malo sa bio neprijatno iznenadjen Fiatovim koji je eto ispustio dusu posle nekih 4 god... Sent from my Redmi Note 9 Pro using Tapatalk 3 ISV_01, Martin and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
MS PK 8836 Posted December 2, 2021 Ih brate, udarna struja kao za kamion I ja sam crvenu toplu zamenio posle 9god beseПослато са SM-A307FN помоћу Тапатока 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted December 2, 2021 Kasno videh da ima i varijanta od 780A To je tek sila...Sent from my Redmi Note 9 Pro using Tapatalk Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted March 5, 2022 Zamenjen levi stabilizator i desni lezaj solje amortizera... Idemo dalje dok smederevske dzade ne naprave novi picvajz... Sent from my Redmi Note 9 Pro using Tapatalk 3 MS PK, Martin and Bokesh reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted March 16, 2022 Odradismo i tzv "mali servis"... Zamenjeno ulje u motoru, filter ulja i filter goriva... Pre zamene motor tretiran sredstvom za ispiranje... Staro ispusteno ulje je bilo Liqui Moli a resih da probam Mannol ulje... Sipano je ovo sa slike... Jel pogresih ili ne? Sent from my Redmi Note 9 Pro using Tapatalk 2 dach@ and Martin reacted to this Quote Share this post Link to post Share on other sites
werp690 1087 Posted March 16, 2022 a filter vazduha? Vidis da smo konstatntno medju najzagadjenijim zemljama na svetu. Mannol je dobro ulje, nisi se zeznuo. Nemci i lose ulje.. Ne ide.. 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted March 16, 2022 Menjao sam ga pre nekih 6 meseci... Valjda mu je dosta jednom godisnje... Ako krene da kaslje menjam ga svakako... Sent from my Redmi Note 9 Pro using Tapatalk 1 werp690 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 2005 Posted March 16, 2022 Dokle vise ta Sahara... Sent from my Redmi Note 9 Pro using Tapatalk 1 2 Reacher Gilt, dach@ and silenci reacted to this Quote Share this post Link to post Share on other sites
dach@ 4906 Posted March 17, 2022 Mannol odlična ulja 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
