Vule 795 Posted October 13, 2022 5 7 Loon123, Dale, Grafit and 9 others reacted to this Quote Share this post Link to post Share on other sites
shuxx 10891 Posted October 13, 2022 .Sent from my SM-A536B using Tapatalk 7 2 neshtry, Loon123, Grafit and 6 others reacted to this Quote Share this post Link to post Share on other sites
Woodoo 23021 Posted October 13, 2022 9 5 Kosta Smosta, Siki97, knezevic76 and 11 others reacted to this Quote Share this post Link to post Share on other sites
shuxx 10891 Posted October 13, 2022 (edited) Edited October 13, 2022 by shuxx 3 Loon123, notalone and Dale reacted to this Quote Share this post Link to post Share on other sites
shuxx 10891 Posted October 13, 2022 Ovo je tuzno. Ali ga ovde stavljamSent from my SM-A536B using Tapatalk 2 knezevic76 and rocket reacted to this Quote Share this post Link to post Share on other sites
Woodoo 23021 Posted October 13, 2022 Ovo je za kuda ide ovaj svet. 3 Dzimbo, Kosta Smosta and shuxx reacted to this Quote Share this post Link to post Share on other sites
Dale 6810 Posted October 13, 2022 1 hour ago, shuxx said: Ovo je tuzno. Ali ga ovde stavljam Sent from my SM-A536B using Tapatalk Prva slika tuzna, druga interesantna. 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
The Punisher 6616 Posted October 14, 2022 Ovaj direktor misli da je ovo 2008. godina gde ima više nezaposlenih nego poslova. On je i dalje u fazonu "ako ti nećeš ima ko hoće", to više ne pali. Može da zaposli Pakistance ako želi 4 Woodoo, Grafit, neshtry and 1 other reacted to this Quote Share this post Link to post Share on other sites
darkman14 5901 Posted October 14, 2022 (edited) Kad smo kod Pakistanaca, kaze mi brat koji radi na Skadarliji da su poceli Egipcane da zaposljavaju po restoranima u BG Edited October 14, 2022 by andreja.micovic 1 1 nemanja84bg and neshtry reacted to this Quote Share this post Link to post Share on other sites
The Punisher 6616 Posted October 14, 2022 Ima Turaka, Albanaca, Indusa, Kineza Juče vidim Glovo dostavu radi crnac 1 1 neshtry and nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
darkman14 5901 Posted October 14, 2022 26 minutes ago, The Punisher said: Juče vidim Glovo dostavu radi crnac Dok ne pocne da radi kao vodoinstalater, miran sam... 9 15 gile smederevo, horvat, Grafit and 21 others reacted to this Quote Share this post Link to post Share on other sites
ortakov 629 Posted October 14, 2022 (edited) Uslovi poslovanja imaju izvesne nedostatke, činjenica je. Nema više poslova "na normu" tj vrlo retko, IT i sl. pa možeš da odrađuješ smenu i da te boli du.e. Ako to ostajanje duže na poslu bude više plaćeno i nije često (bar ne češće od 2 - 3 puta mesečno) onda je ovo vrlo fer ponuda posla. Sa kakvim ljudima sam imao prilike da radim to je zaista za priču. Pri svemu tome, proste poslove ne mogu da obavljaju paralelno, a za "ozbiljnije" zadatke izgube po sat vremena onda cela ova priča i nije nerazumna. Može da nauči svašta korisno - poslovno, što, (očigledno, ako neko "pop....di" zbog idiotskog odnosa prema poslu i nezainteresovanosti) i ne zna šta i kako treba da uradi (pa još i ponavlja greške), normalno je se dereš. Kinezi nose one njihove prutiće i uteruju u stroj, a ovde ne smeš da povisiš ton na nekoga ko može da napravi ozbiljnu štetu ili jednostavno ga boli Q. Na loše poslovanje i loš odnos prema poslu od strane radnika su posebno osetljivi mali poslodavci jer nemaju mogućnost da imaju još zaposlenih, čime bi rasteretili ostale zaposlene (jednostavno takvi uslovi poslavanja u toj grani privrede - oblasti poslovanja), veliki su nameti a generalno nema mnogo posla. I kada još neko hoće nešto da te nauči (ako ne znaš) i ako imaš pristojne uslove za rad (normalne radne prostorije, godišnji odmor prema zakonskim propisima, normalno okruženje na poslu - ljude posvećene onome što se radi) onda tu nije toliko problem ovaj oglas poslodavca. Svi "šegrtski" poslovi su manje - više takvi. Samo što je ovaj bio dovoljno pismen da pokuša da sastavi nešto što će neko, ko hoće da razume, da prihvati i da radi neki posao, koji mu se sviđa ili ne, sve jedno je, ali će ga raditi na najbolji mogući način. Poslodavci umeju da budu loši i to nije retkost, ali ni zaposleni nisu tu da nemaju nikakvu odgovornost. Uostalom, za administrativni posao bi trebalo da se prijavi neko ko je završio barem srednju ekomomsku školu, srednju trgovačku i to neki IV stepen a javiće mu se na oglas barem 85% nekih polusvrešnih studenata/kinja, nekih zanimanja od električara do mašinovođe, koji znaju da koriste internet (instagram i facebook), koji znaju da pošalju e mail (samo sa telefona) pravopis i osnove (poslovne) korespodencije su za njih nešto za šta su "čuli" a učili "davno"... Pre početka posla treba im 30 - 45 minuta da popiju kafu, a posle na svakih 20 - 30 minuta izlaze da "zapale", strane jezike poznaju (google translate) itd. ... I koliko vredit takav radnik, koji, pritom, ne može da ostane nikada duže a ono što mu se govori sluša tek toliko da je čuo? Jeste tužna slika, ali iz više razloga. Edited October 14, 2022 by ortakov 3 nidza, bane1321 and neshtry reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted October 14, 2022 Prezime moje, objasnio 4 1 Loon123, Dzimbo, nemanja84bg and 2 others reacted to this Quote Share this post Link to post Share on other sites
ortakov 629 Posted October 14, 2022 To ne mogu da komentarišem, ako je istina, tj ako je to odgovorio ovaj koji je postavio oglas, onda je u najboljem slučaju bolestan / lud a u gorem, bahat i bezobrazan. Quote Share this post Link to post Share on other sites
Axic 20048 Posted October 14, 2022 3 2 Grafit, dach@, Loon123 and 2 others reacted to this Quote Share this post Link to post Share on other sites
Dale 6810 Posted October 14, 2022 @ortakov jeste u pravu. Sve vise ima problema sa radnicima, mladim pogotovo. I sa srednjom strucnom spremom i diplomirani pravnici, programeri... Kolegi je jedan radnik sa visokom strucnom spremom stavio plasticno kuvalo sa vodom na reso i ukljucio ga, da, reso ukljucio! Mogao pozar da napravi... A da ne pricamo o tome koliko u radu ne mozes da se oslonis na njih. Naravno, ima i majmuna poslodavaca, ali treba cuti i drugu stranu tj sa cime se sve susrecu poslodavci. Oglasa gorepomenutog Dejana je totalno pogresan i bahat svakako. 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Grafit 1073 Posted October 14, 2022 Ne znam da li sam zalutao u ovu rubriku, ali ja bi da okačim... 10 4 neshtry, Woodoo, Mijailović P. and 11 others reacted to this Quote Share this post Link to post Share on other sites
Woodoo 23021 Posted October 14, 2022 7 3 Djuk85, neshtry, knezevic76 and 7 others reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted October 15, 2022 8 Dale, dach@, neshtry and 5 others reacted to this Quote Share this post Link to post Share on other sites
shuxx 10891 Posted October 15, 2022 3 1 Kosta Smosta, nemanja84bg, neshtry and 1 other reacted to this Quote Share this post Link to post Share on other sites
shuxx 10891 Posted October 15, 2022 Pravi oglas, kaze gazda da je odlican auto sa dTi motorom. Mene privukao SKENIK 5 1 neshtry, dach@, nemanja84bg and 3 others reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1311 Posted October 15, 2022 On 10/14/2022 at 10:18 AM, andreja.micovic said: Dok ne pocne da radi kao vodoinstalater, miran sam... Zamisli kad krenu da se bave elektrikom , to ima ekonomski tigar da puca i prsti, ima da sagori ko licna a neka sta fali i propadanje je lepo i zanimljivo ako se prihvati na prav nacin Quote Share this post Link to post Share on other sites
shuxx 10891 Posted October 15, 2022 7 2 alfini0507, dach@, neshtry and 6 others reacted to this Quote Share this post Link to post Share on other sites
shuxx 10891 Posted October 15, 2022 5 1 Mijailović P., Dale, Loon123 and 3 others reacted to this Quote Share this post Link to post Share on other sites
neshtry 14875 Posted October 15, 2022 (edited) @shuxx Ne govore svi francuski…. nemcima se utroba okreće kada čuju bi em dabl ju umesto be em vi Edited October 15, 2022 by neshtry 2 1 nemanja84bg, Kosta Smosta and shuxx reacted to this Quote Share this post Link to post Share on other sites
