bane1321 6007 Posted April 13, 2021 13 minutes ago, djomla said: pribegao sam sipanju iz kante Al si prvo močao u nju? 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Dale 6810 Posted April 13, 2021 Bas se pitaju komsije sto sipa fantu u auto. 1 djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted April 13, 2021 Jupi, Jupi 2 moron and Dale reacted to this Quote Share this post Link to post Share on other sites
bane1321 6007 Posted April 13, 2021 Next 100% jabuka! 1 djomla reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted April 13, 2021 Sa kompa si kucao? TT izgubio opciju gifova Sent from my SM-G770F using Tapatalk Quote Share this post Link to post Share on other sites
bane1321 6007 Posted April 13, 2021 (edited) Još davno su Francuzi tako skupljali ureu za blue HDI motore: Edited April 13, 2021 by bane1321 2 djomla and Dale reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted April 13, 2021 Nisam ni znao da može gif preko TT-a Pioniri ureizma Sent from my 3310 using Tapatalk 1 Axic reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted April 18, 2021 (edited) Ubačene kamere na mape. I naravno ćuning smajling, štrokave felne i sjajni čepovi Edited April 19, 2021 by Milutinac sredio slike 9 djunis82, IDzO, rkoma1986 and 6 others reacted to this Quote Share this post Link to post Share on other sites
debelizmaj 414 Posted April 18, 2021 Gde skidas mape? Sent from my Redmi Note 9 Pro using Tapatalk Quote Share this post Link to post Share on other sites
djomla 8386 Posted April 18, 2021 @debelizmaj gpspower.net mape, sw update takođe imaš tamo. Sent from my 3310 using Tapatalk 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 10, 2021 Brat Kasper se nije više pojavljivao, a da se slučajno ne pojavi opet, pobrinula se hobotnica sa slike. Sent from my 3310 using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted May 10, 2021 Squiddly Diddly Sent from my SM-G770F using Tapatalk 1 djomla reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted May 10, 2021 Sta je bre ovo, na nova kola!? Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 10, 2021 Crevo Mićo, crevo Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7734 Posted May 10, 2021 Moz misliti kako izgleda onda nesto komplikovanije. Zlatan stilo.. Послато са SM-A307FN помоћу Тапатока 1 djomla reacted to this Quote Share this post Link to post Share on other sites
bane1321 6007 Posted May 10, 2021 Ma kad je Francuz bio auto! 1 1 djomla and MS PK reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 19, 2021 Pošto se "družimo" već par meseci, ajd' da probam da dam neki sud što se tiče Obodina. S obzirom na moj stil i način vožnje, ne kilavim ali i ne divljam, motor i menjač su prava mera, nije kilav, taman je kako treba, fino povuče kad zatreba (naravno, od viška ne boli glava, ali nažalost, nisam imao prilike da probam jaču verziju). Lepo se vozi, šta više (meni lično) uzivancija za vožnju. Menjač (Aisin tf-80sc oznaka) lepo radi, korektno šalta, oseti se ponekad promena, uglavnom iz 1 u 2, ostalo maltene neosetno, prilikom preticanja šalta niže stepen ili dva, ide do crvenog bez problema ako treba, lepo prati doziranje gasa prilikom šaltanja. Potrošnja se vrti oko 7l kombinovane vožnje. Mesta ima solidno, sama kabina je poprilično prostrana, gepek ogroman, može stati šta hoćeš i šta nećeš Izmedju prednjih sedišta ima ostavu u koju može stati brdo svega i svačega, pritom se ta ista ostava može izvaditi i poneti, fioke u prednjim sedištima, pozadi ima dve pregrade u podu. Zadnja sedišta se pomeraju plus imaju mogućnost da se "zavale" unazad. Ono što smara je naravno glupo rešenje klime i većine stvari, sve je preko touch screen-a, nije kriminalno, ali nije baš najsrećnije rešenje. Malo je sve zbrda zdola, ne zamerite. Ako ikom šta znači, mogu dopisati cene servisa koje sam do sad radio, pa se to može spojiti sa prvim post-om, čisto ako je nekom od koristi. Sve u svemu, zadovoljni smo izborom Bele tehnike. Sent from my HRY-LX1T using Tapatalk 11 1 Martin, Milutinac, srdjos and 9 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted May 20, 2021 Kako i ne bi, stvarno ima sve što treba i više. Sad sam skontao da je menjač izgleda isti kao u mojoj Delti. Osetiš li ono 'ubacivanje' u prvu kad staneš na semaforu pa pustiš kočnicu da kreneš? Meni samo to smeta, mada je tako napravljen da bi se čuvao. Izbacuje iz brzine kad stojiš da se rastereti. Inače šaltanje si dobro opisao, čak mi i iz 1 u 2 nije ništa strašno i oseti se samo po nekad a zavisi od desne noge... 1 djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 20, 2021 @PremieRacing Upravo to, zavisi od noge na gasu to prebacivanje 1-2, u većini slučajeva se ne oseti. Obraticu bas paznju na taj momenat sto si opisao, za polazak sa semafora, iskreno nisam primetio nista. To "ubacivanje" se oseti sa gasom ili bez, tipa pustis kocnicu pa dodas gas tek kad krene ( pola sekunde npr) ili odmah stiskas gas?Ako nisam previse konfuzan A menjac bi trebao da je isti i u Delti i kod mene. Sent from my 3310 using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted May 20, 2021 To je sve zbog delimicne pohabanost i odstupanja fabrickog stanja, ali nista ja tu ne bih dirao (osim ulja koje ste vec zamenili). Jer ni kvacilo/zamajac nece biti kao novo posle toliko godina i kilometara, a ni to niko ne menja bez nekih vecih simptoma (tipa da kliza, trese itd.) Oseti se da nije novo, ali to je sve, mislim to je normalno za sve automatike ikad, ne samo aisin, vec i za mercedesov, za jatco, za zf itd. 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Axic 20048 Posted May 20, 2021 10 hours ago, djomla said: ali i ne divljam, 1 3 PremieRacing, Reacher Gilt, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 20, 2021 Ja ulje nisam zamenio, otisao sam do Slavka, pre zamene je Stevan (Slavkov sin) testirao menjač, ustanovio da je sve ok (neće da menja ulje ako nesto ne valja), kad je ispustio malo ulja da vidi u kakvom je stanju, po njegovim rečima, ulje je kako treba, boja itd, tako da mi je savetovao da odlozim bez problema zamenu. Što se njegovih saveta tiče, konkretno za ovaj menjač, ne prija mu "potpisivanje", prilikom polaska, bez jakog/naglog gasa, bez problema držanje na kočnici, više mu "smeta" prebacivanje iz D u N npr na semaforu, prilikom parkiranja na nagibu prvo se povuče ručna pa se prebaci ručica u "P". Prilikom puštanja kočnice na semaforu, ne bi trebalo da bude nikakvih "udaraca". To je od prilike nešto što mi je on rekao. Sent from my 3310 using Tapatalk 1 Dzimbo reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted May 20, 2021 Iskreno ovo mi zvuci neozbiljno Znam da vaze za jedne od boljih na ovim prostorima, verujem da znaju da remontoju menjac odlicno, ali zamisli scenu da odes kod bilo kog obicnog majstora i da kaze da nece da menja ulje u motoru ako nesto ne valja, eventualno izvuce sipku i pogleda boju ulja, pa ako je kako treba onda odlozis zamenu ulja u motoru Ulje se menja kako u motoru, tako i u menjacu da ne dodje do problema, preventivno, a i u nekim intervalima, a ako nisi siguran kada je zamenjeno ulje, bilo u motoru ili u menjacu onda se zameni. Takodje nijednom menjacu na planeti ne prija potpisivanje prilikog polaska 5 Dzimbo, Reacher Gilt, djomla and 2 others reacted to this Quote Share this post Link to post Share on other sites
