MS PK 7734 Posted June 23, 2015 A nista samo nemoj da ti se ponavlja vise Quote Share this post Link to post Share on other sites
rocker87 5 Posted June 23, 2015 A gde su tu još tri rolera, svaki prosečno po hiljadu petsto din? Pa ti vozi dizela. Quote Share this post Link to post Share on other sites
pedjabj 16 Posted June 23, 2015 A gde su tu još tri rolera, svaki prosečno po hiljadu petsto din?Isece me bre... Quote Share this post Link to post Share on other sites
vicent 1263 Posted June 23, 2015 (edited) A gde su tu još tri rolera, svaki prosečno po hiljadu petsto din? Pa ti vozi dizela. Ma, može nam se. To je taman koliko VI date za svećice. Edited June 23, 2015 by vicent Quote Share this post Link to post Share on other sites
rocker87 5 Posted June 23, 2015 I koliko uštedim na 1200 km pošto vozim na plin. Cca mjesec dana. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 23, 2015 To ce se pitas kad reatestiras plin il kad krene da stuca ili trosi ko nenormalan Mante se off-a vise Quote Share this post Link to post Share on other sites
rocker87 5 Posted June 23, 2015 2023. sigurno neću voziti isti auto. Ma neka štuca, vozit ću benzin, nije problem, dok se to ne riješi. S ovom potrošnjom, sve mu je oprošteno. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 23, 2015 Hahaha, eeee a nisi ni svestan kakav te lom mozda ceka posle punta Quote Share this post Link to post Share on other sites
mitros 142 Posted July 9, 2015 (edited) Samo mali servis ruke i delovi oko 4870 rsd......A veliki servis bez malog servisa oko 15300 rsd. Nadam se da se razumemo....ako nesto nije jasno javite se Natasi na 065 2193543. Eto ti sad,sta znaci veliki servis bez malog? Pa zar mali servis nije sadrzan u velikom? Edited July 10, 2015 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 10, 2015 Nije sadržan.Nikad nije ni bio.Promena ulja u motoru i svih filtera = mali servis. Koristi se i pojam redovan servis.Radi se ili jednom godišnje, ili više puta u toku 12 meseci ukoliko se prelazi veći broj kilometara.Promena kaiševa, španera, rolera, pumpe vode = veliki servis.Radi se na znatno većim kilometražama, ili najkasnije posle 5 godina ukoliko se za to vreme ne predje dovoljan broj kilometara.Jedno sa drugim nema nikakve veze.Dobra je praksa po kupovini polovnjaka odmah uraditi oba servisa kako bi novi vlasnik bio sigurniji u auto koji je kupio. Quote Share this post Link to post Share on other sites
mitros 142 Posted July 10, 2015 Nije sadržan.Nikad nije ni bio.Promena ulja u motoru i svih filtera = mali servis. Koristi se i pojam redovan servis.Radi se ili jednom godišnje, ili više puta u toku 12 meseci ukoliko se prelazi veći broj kilometara.Promena kaiševa, španera, rolera, pumpe vode = veliki servis.Radi se na znatno većim kilometražama, ili najkasnije posle 5 godina ukoliko se za to vreme ne predje dovoljan broj kilometara.Jedno sa drugim nema nikakve veze.Dobra je praksa po kupovini polovnjaka odmah uraditi oba servisa kako bi novi vlasnik bio sigurniji u auto koji je kupio.Pa ne znam sad sta da kazem,ja kad sam radio veliki servis kod Mikija u Tim servisu,on je zamenio sve ovo sto si naveo,samo bez vodene pumpa ali sa svecicama.!!!p.s.Znaci veliki se radi najkasnije za 5 godina (ako ne i ranije zbog velike km)? Quote Share this post Link to post Share on other sites
Dovla 9 Posted July 10, 2015 Za svaki auto postoji servisni interval šta se kada menja. Nekada se mali i veliki servis poklapaju, nekada ne. Nekada je ljudima mnogo para da daju za veliki mali servis odjednom pa rade odvojeno. Isto važi i za vreme/kilometražu. Treba da pitaš majstora koji ti radi koliki je servisni interval kod njega za mali, a koliko za veliki servis. Taj interval se daje u km i vremenu pa šta pre nastupi (na primer 15.000km ili godinu dana). Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 10, 2015 Nije sadržan.Nikad nije ni bio.Promena ulja u motoru i svih filtera = mali servis. Koristi se i pojam redovan servis.Radi se ili jednom godišnje, ili više puta u toku 12 meseci ukoliko se prelazi veći broj kilometara.Promena kaiševa, španera, rolera, pumpe vode = veliki servis.Radi se na znatno većim kilometražama, ili najkasnije posle 5 godina ukoliko se za to vreme ne predje dovoljan broj kilometara.Jedno sa drugim nema nikakve veze.Dobra je praksa po kupovini polovnjaka odmah uraditi oba servisa kako bi novi vlasnik bio sigurniji u auto koji je kupio.Pa ne znam sad sta da kazem,ja kad sam radio veliki servis kod Mikija u Tim servisu,on je zamenio sve ovo sto si naveo,samo bez vodene pumpa ali sa svecicama.!!!p.s.Znaci veliki se radi najkasnije za 5 godina (ako ne i ranije zbog velike km)? Sigurno ti nije džabe zamenio ulje i sve filtere, tj. naplaćeno ti je i to. Platio si i mali i veliki servis. Poklopili su ti se termini da se urade oba, ili si hteo da uradiš oba, ili šta već.Veliki servis se radi na 60.000, ili na 80.000, ili na 120.000 kilometara....to je ono što Dovla kaže da sve zavisi od auta do auta. Imaš u vlasničkoj knjižici za tvoj auto propisane servisne intervale. Tu knjižicu imaš postavljenu na forumu.Nije svejedno i da li je prvi veliki servis, ili već neki sledeći po redu jer interval zavisi i od kvaliteta delova koje si stavio (ili je stavio vlasnik pre tebe) radeći prethodni veliki servis.Ali, ukoliko se ne pređe toliko kilometara, onda se veliki servis svejedno radi posle 5 godina. Šta pre nastupi, pređeni kilometri, ili godine. Quote Share this post Link to post Share on other sites
malenobrzo 0 Posted July 22, 2015 Na koliko se radi veliki servs na puntu 1.2 8v 2001?Skoro sam ga uzeo, pise da je radjen pre 33 000 km Quote Share this post Link to post Share on other sites
gorank82 183 Posted July 22, 2015 Kod nas u zemlji na 60000 km u Evropi na 120000 km Quote Share this post Link to post Share on other sites
baron21 7 Posted July 26, 2015 aaaaa poludeo sam od ovog googlanja vise nas punto classic kupljen 2009. 1.2 44kw, klot verzija (bez klime, serva itd), presao 57.000km, pa racunam da bi trebalo odraditi (prvi) veliki i mali servis pre morabeli mi rece da je oko 150e veliki servis, sad gledam na APsportu ( http://www.ap-sport.rs/prodavnica/index.php?dispatch=products.view&product_id=41195 ) izadje po njihovom sve zajedno 14-15k din, e sad koliko se ja (ne)razumem ovde je samo izostavljena pumpa za vodu? da li nju obavezno menjati ili? jel treba jos nesto proveriti? Quote Share this post Link to post Share on other sites
vicent 1263 Posted July 26, 2015 Prvi veliki servis se radi na 80 hkm. Svakako, ne može biti loše da ga uradiš pre GO, ali ja se ne bih žurio. Quote Share this post Link to post Share on other sites
baron21 7 Posted July 26, 2015 Nema veze sto je jul 2009. Godine? Ma kome se jos zuri da daje pare Quote Share this post Link to post Share on other sites
baron21 7 Posted July 26, 2015 sutra cu da odem do servisa pa cu videti sta ce mi reci, zanimljivo je to da u knjizi uopste ne pise kada treba raditi servise... Quote Share this post Link to post Share on other sites
gorank82 183 Posted July 26, 2015 Prva ugradnja kaiševa ni ja ih ne bi dirao iskreno... Quote Share this post Link to post Share on other sites
MS PK 7734 Posted July 26, 2015 A kad bi ih dirao? Proslo je 6god. I da je stajao u mestu pa bi morali da se menjaju Quote Share this post Link to post Share on other sites
gorank82 183 Posted July 26, 2015 (edited) Svako iznosi svoje misljenje, ti bi menjao ja ne bi sigurno, po meni bacanje para... Edited July 26, 2015 by gorank82 Quote Share this post Link to post Share on other sites
baron21 7 Posted July 26, 2015 e ovo me je najvise zbunilo dok sam trazio po netu Quote Share this post Link to post Share on other sites
kakoonobese 43 Posted July 26, 2015 (edited) Cale vozi Astru G 2005. godiste. prvi vlasnik 66000 km......Majstori mu govorili da ne treba da se radi veliki servis a ja da treba.Pitam ja caleta: ako pukne kais i ako se napravi karambol, hoce li tada taj tvoj majstor da plati stetu? I tako je uradio veliki servis.....Kod tebe je znacajno mladji auto, mislim da je sredina negde izmedju: cekaj jos godinu dana i onda menjaj. Edited July 26, 2015 by kakoonobese Quote Share this post Link to post Share on other sites
totti 13165 Posted July 26, 2015 U ovoj temi u postu od 21. Juna imaš da se radi na 90.000 km ili na 5 godina. Po meni je ovo malo sramota za vremenski interval, ali tako je... Quote Share this post Link to post Share on other sites
