Bingodalton 738 Posted March 23, 2020 9 minutes ago, vagenovac said: Superb slika, steta sti se ne vidi znak pa da pogodim koje marke je vozilo sa slike Marko je to dobro zamaskirao kao sto vidis. Znas model, ali marku ne Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted March 23, 2020 Dobro ljudi, sad vec pocinjem da sumnjam da ste shvatili da je ovo govno preko znaka samo fora 1 djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted March 23, 2020 Odlicno si sakrio, na teškim mukama smo. Da se igramo sa slovo, na slovo? Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
totti 13165 Posted March 23, 2020 Garant neki kome se ne poklapaju segment i platforma Sent from my SM-G950F using Tapatalk 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted March 23, 2020 Klasican C segment 2 vagenovac and totti reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted March 23, 2020 Od kad nisam video crveno na 6000 obrtaja...Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted March 23, 2020 Kvarimo temu o srafovima, al za Totti-ja...Sent from my SM-G960F using Tapatalk 1 totti reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted March 23, 2020 Pa napravi novu Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted March 23, 2020 Bice, samo da obezbedim slike kakve valjaju. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted March 23, 2020 Klasican C segmentGolf xxl Послато са Mi MIX 2 помоћу Тапатока 2 rkoma1986 and Bingodalton reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted March 23, 2020 Da se nadovezem sam na sebe. Sigurnosni sraf sa slike je sa konusnom glavom, a originalni sraf ima radijus. U sustini ne treba da ide konus na radijus. Sumnjam da bi jedan sraf prafio problem, ali samo leziste felne je takvo (za radijus) pa trpi vece naprezanje ako se stavi konusni sraf, sto se i vidi po tragu naleganja na samom srafu. 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted March 30, 2020 Update, zamenjeni sigurnosni srafovi. Ovi imaju radijus i za truncicu su kraci. Fabricki vidim da se pominje dimenzija 26.7mm - 28mm (neki cak i 25mm), bice da je 27mm (mogao sam lepo izmeriti sublerom, sad se setih). Sigurnosni su 26.7mm. 1 Nebek reacted to this Quote Share this post Link to post Share on other sites
Jim9 85 Posted June 19, 2020 Postavih danas sigurnosne na Tipu. Farad Stil bull oko 1600 dinara u Kit Komercu. Ne znam kakvog su kvaliteta ali ih svejedno po preporuci prodavca nisam pretezao, stegnuo rukom koliko sam mogao i to je to. Kontam bolje i da ih dotegnem povremeno neko da mi neki sivonja ošteti ulaz za ključ pneumatskim pištoljem.Malo je cimanje što dolazi samo jedan ključ i ako njega izgubim 6000 je novi. A ne odaje utisak da će izdržati više od dva-tri skidanja stavljanja.Sent from my Mi 9T using Tapatalk Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted June 19, 2020 Da nisu oni zadrzali kljuc pa su u fazonu prodacemo kad izgubi Pa za te pare moze da se uzme univerzalni kljuc i jedno 2 seta novih sigurnosnih Quote Share this post Link to post Share on other sites
Jim9 85 Posted June 19, 2020 Pa može Tako mi rekao prodavac, imaš neki kod u kutiji i kao kad izgubiš oni mogu da po tom kodu poruče novi ali je zadovoljstvo 6000 dinara. Tako da reče pazi gde ga čuvaš.Jel dovoljno ovo rukom što sam stegao? Nisam skakao po ključu i zapinjao ko sivonja.Sent from my Mi 9T using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 19, 2020 (edited) U principu zavisi i od "sifre" i mogucnosti da prokliza. Zategni dobro rukom i to je to, da je sigurno. Uglavnom znaju po servisima, ali ima izuzetaka, pa pripazi da ti to neki strucnjak nekada ne pretegne pistoljem. Uvek je pametno imati dupli kljuc, mada sam davno kupio i jos uvek na vise Fiata vucem isti set (M12x1.25) sa samo jednim kljucem. Ima sigurno deceniju i kusur, samo pripazi gde cuvas. Edited June 19, 2020 by Ivan 1 Jim9 reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted June 19, 2020 Kljucevi za pritezanje tocka i jesu tako napravljeni da prosecna osoba moze propisano da stegne rukama To samo neke klinke od 45kg treba da nagaze Quote Share this post Link to post Share on other sites
nidza 621 Posted June 19, 2020 Apsolutno. Iznenadili biste se koliko je 120Nm u stvari lako zategnuti rukama. Većina nas rukom može da zategne znatno više, i bez gaženja.Sent from my POCOPHONE F1 using Tapatalk Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted June 19, 2020 Najgore je sto to ne znaju ni oni kojima je to posao... Ja coveku namontiram letnji set, pocepa gumu, ode kod vulkanizera, posle kaze da skinem tockove, 3 skinem laganica, cetvrti mi treba preko 1000Nm da popustim, a inace kada je nesto stegnuto na odredjenu meru treba oko 10% manje sile za popustanje. Govorimo o autu gde je deklarisano da se tocak steze na 79Nm... Quote Share this post Link to post Share on other sites
BGMilos 126 Posted June 19, 2020 (edited) Ako se ne varam moment od 100Nm se dobija ako se na krak od 1m deluje silom od 100N ili grubo oko 10kg pretvoreno u težinu? Što znači sa se sa polugom dužine 0.5m i 20kg težine dobija isti moment. Tako da mogu da zamislim kad se neko iskače po ključu koji je moment zatezanja . Edited June 19, 2020 by BGMilos 1 YUgisa reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4033 Posted June 20, 2020 Kad god idem do vulkanizera i kada mi vraća šrafove baš napomem da stegne tako da mogu da odvrnem (jak sam u ruke ali sam lagan, pa naskakanje na polugu/krstasti nema efekta)...jednom mi je neki stegao pneumatskim tako da sam rodio mečku dok sam olabavio šrafove za koje sam više bio zabrinut od sigurnosnog koji je izrađen na strugu u IMT-u pre jedno 25+ godina. Quote Share this post Link to post Share on other sites
moron 3691 Posted June 20, 2020 Pohvalio bih Fiata i sa razloga što uz originalne sigurnosne šrafove isporučuje dva ključa za te šrafove. Pa, jedan držim u kolima, a rezervni na drugom mestu. Neki brendovi isporučuju samo jedan ključ. "Palac gore" za Fiat Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted June 20, 2020 E jbg, sad moram i ja sigurnosne šurafe da turam. tt Quote Share this post Link to post Share on other sites
Ivan 17670 Posted June 20, 2020 KoleZa, prvo 17''/18'' tocak na Sporta, pa sigurnosne . 2 Mijailović P. and Danilo1 reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted June 20, 2020 Da,da... Vidim ima istomišljenika... tt Quote Share this post Link to post Share on other sites
