knezevic76 7020 Posted February 5 Sta ste, s oprostenjem, metnuli napred?ATE diskovi i TRW pločiceNe pricas da je to mesto za ove sto nisu platili jos, nema mrdanja Sent from my SM-A346B using TapatalkObigravao sam oko žice da ga maznem dok ne gledaju Sent from my SM-A546E using Tapatalk 2 1 Reacher Gilt, MS PK and Ivan-Topola reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2186 Posted February 5 6 hours ago, knezevic76 said: lično i personalno me provozao u mom autu da "oslušnemo" nešto. I mene je svojevremeno u mome, i preterao preko onih ležećih u komšiluku u drugoj lagano, a meni nije dobro ... Posle sam se još jednom za*ebao i dao ovom mom da kao pogleda kako se menjač ponaša. Tad je seo za volan, i više vala neće. 3 2 nemanja84bg, MS PK, city and 2 others reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted February 5 Pa kako da čuješ ako ne teraš preko ležećih Elem, Goran je lično i personalno stetoskopom oslušnuo sve ležajeve točkova i poluosovinu do menjača, provozao ga da proveri menjač itd Zamerki nije bilo. Elem, prednji diskovi su prečnika 281mm. Sent from my SM-A546E using Tapatalk 2 nemanja84bg and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted February 14 Nije sport mod, opušteno ubrzavanje, malo zajebano jednom rukom držati volan i šaltati Sent from my SM-A546E using Tapatalk 2 1 Nikola031, nemanja84bg and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Nikola031 944 Posted February 14 Ovo je 3-4-5 brzina, ako dobro vidim prema obrtajima? Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted February 14 Ne, samo 3 i 4Sent from my SM-A546E using Tapatalk Quote Share this post Link to post Share on other sites
nemanja84bg 1311 Posted February 15 (edited) A pesma u pozadini kida pa kaze "nije presa' " by who see Edited February 15 by nemanja84bg 1 stex_pb reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted February 26 Danas uzeh da premerim struju na akumulatoru, sad če mu godinu dana, i taman da vidim kako alternator puni.Struja akumulatora je 12.8v , dakle pun 100%, ali merio sam ga nakon par vožnji od po 2km pa je odstajao jedno 10 minuta. Punjenje alternatora sa upaljenim farovima, ventilatorm itd je 14.05v.Dakle sve je ok.Sent from my SM-A546E using Tapatalk 9 nemanja84bg, stex_pb, Branislav and 6 others reacted to this Quote Share this post Link to post Share on other sites
stex_pb 837 Posted February 27 Oprosti, moram da ispravim. Nije struja nego napon 2 2 Zvezdo, silenci, knezevic76 and 1 other reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted April 7 Samo da dodam, nekako se slučajno uklopio grafit Sent from my SM-A546E using Tapatalk 4 2 Axic, Nikola 1.6, MS PK and 3 others reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted April 7 auto je sjajan 2 1 Reacher Gilt, knezevic76 and shuxx reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted April 7 Sta si ovo met'o od guma napred? Po sari mi deluje neki AS? Pozadi i dalje prepoznajem Dunlopke. Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted April 7 Eee, kakvo je to putešestvije bilooooo....jednom ću detaljno da opišem šta se sve izdešavalo pa sam morao gume da zamenim, samo čekam epilog ove nedelje....Elem, što se guma tiče, razmišljao sam između Danlop AS kao ove koje već imam i Hankook AS. Opredelim se za Hankook. Poručim gume i zakažem menjanje. Pojavim se ja u dogovoreno vreme ali Hankook gume im još nisu stigle iz magacina. Divota. Al kad sam već tu , od izbora koji imaju na stanju i samo Lassa i Laufen. Pogledam malo testove i iskustva ljudi sa tim Laufen modelom, podbrend Hankooka i uzmem njih, poprilično su se dobro pokazale na testovima.Naravno, Laufen nemaju oznaku XL čime sam dobio na udobnosti u vožnji. Nisam ih nešto puno testirao, al za sad su iznad mojih očekivanja. Videćemo kroz malo dalju eksploataciju.Model jeLaufenn G FIT 4S LH71225/45 R17 94WZadnje opušteno mogu još godinu dana da teraju.Sent from my SM-A546E using Tapatalk 3 1 Axic, silenci, Mijailović P. and 1 other reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted April 7 1 hour ago, knezevic76 said: al za sad su iznad mojih očekivanja. Agzara prop'o. 1 5 Ivan-Topola, Nikola 1.6, nobutado and 3 others reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted April 10 Ajde vi što baratate delovimaOE broj za prednji ležaj točka?Ja sam našao neke brojeve, dal je to to?I koji brend uzeti SKF ili FAG ili neki treći@Ivan Sent from my SM-A546E using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted April 10 (edited) @knezevic76 493018151111 Okej sad ozbiljno To je za moj 1.9 8v, ne znam da li zavisi od motorizacije ali iskreno verujem da NE. Ja sam uzeo SKF za zadnji levi pre oko 2g i sljaka odlicno. FAG imam stabilizatore i nemam zamerki. Edited April 10 by ISV_01 1 knezevic76 reacted to this Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted April 10 SKF je ok, barem je bio oduvek. FAG je INA sto se tice lezajeva, inace Schaeffler grupa. U toj prici imas i GSP koji je prilican BUM na trzistu sto se tice kvaliteta i cene pogotovo. Inace delovi trapa koji se sad prodaju pod imenom FAG su u stvari Ruville nekada, neka niza srednja klasa po meni - nikad nisam bio ljubitelj Ruvila jbga. 4 MS PK, knezevic76, nesa 169 and 1 other reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted April 10 Kad sam ukucao moj VIN broj na sajtu Euro07, izbacio mi je ono što se vidi na sliciCena ide od 3500-6000 u zavisnosti od brenda iznad Sent from my SM-A546E using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted April 10 8 minutes ago, MiloshBg said: GSP @knezevic76 Ako ti dovezu ceo autobus, uputi ih na kolegu 1 2 knezevic76, Axic and MiloshBg reacted to this Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted April 10 @ISV_01 Moze, ali neka makar bude pun rezervoar nafte... Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted April 10 Na pekidiju po VIN broju je izbacio, tako da je ovaj sa Euro07 izgkeda tačan Sent from my SM-A546E using Tapatalk Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted April 10 Daj sasiju ako hoces da ti prekratimo muke. Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted April 10 ZFA19800004300695Sent from my SM-A546E using Tapatalk Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted April 10 OE 92403013 Swag 70936967 - 3364 din GSP GK3598 - 2510 din FAG 713 6908 00 - 3830 din To imas u wintu pa biraj. U delmaxu imas SNR R158.54 - 4333 din FEBI 36967 - 3590 din SKF VKBC20039 - 2980 din To je u generali, sta gde ima tj u kojoj MP moras proveriti. 3 shuxx, knezevic76 and city reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted April 10 Ok, hvala, ipak sam ubo dobar OE broj.Elem, nikada nisam koristio taj ePer i slično, sve sam prepuštao majstorima, al kakvo je vreme došlo, moraću i time da se pozabavim, jbg. PS Euro07 je skuplji i od delmaxa i od wintaSent from my SM-A546E using Tapatalk Quote Share this post Link to post Share on other sites
