Ivan BG 720 Posted February 6, 2021 Koliko muka, imas ga malo jace od 2 meseca, a poslednjih mesec dana zezancija. Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 6, 2021 Ivan bg@ zezanje je od prvog dana. Uzao sam ga takvog. Vidim zamajac se ne cuje, lanac se ne cuje, pali i gasi bez i najmanjeg trzaja, i na cimanje gasom nema lupanja, ma reko neki nosac do 100e i auto boli glava, kad ono medjutim.... Share this post Link to post Share on other sites
MS PK 7734 Posted February 6, 2021 ....medjutim boli glava bukvalno Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 6, 2021 Al bukvalno... Share this post Link to post Share on other sites
Flex 1778 Posted February 6, 2021 Tacno da ti se zgadi auto, u pm. Nadam se da ces ubrzo resiti. 1 skile86 reacted to this Share this post Link to post Share on other sites
knezevic76 7020 Posted February 6, 2021 Kod BMWa je sve uzdužno postavljeno i auto bi trebao da ljulja levo desno i onda može biti milion stavki Nosači motora Disbalans kardana Disbalans seta kvačila Motor........ Jbg Rešiće se to Share this post Link to post Share on other sites
rkoma1986 1113 Posted February 7, 2021 Hahaha, jes da je F10 u pitanju, ali klip je carski, @dellas hvala za ovo, nisam gledao ranije 1 Bingodalton reacted to this Share this post Link to post Share on other sites
rkoma1986 1113 Posted February 8, 2021 (edited) Ovo sam pokupio sa drugog foruma, jes da je A4 u pitanju ali simptomi koliko sam shvatio dosta slicni tvojima. Pa eto, ako nisi proveravao, da obratis paznju i na to Quote Ukratko, verovatno je ovo što kaže AWT, homokinetički zglobovi do menjača, kada su neispravni auto trese pri ubrzavanju. Nisu skupi i relativno lako se menjaju. Edited February 8, 2021 by neshaoct formatiranje 1 CikaKURE reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 8, 2021 Mislim da to vazi za prednju vucu, u tu grupu mogu da spadaju i krstovi poluosovine, e sad mislim da za zadnju vucu to nije isto... Share this post Link to post Share on other sites
vagenovac 4533 Posted February 8, 2021 Koliko se ja secam da ne skrolam opet kroz temu unazad, ali tebi je problem cak i kada stojis u mestu i turiras sa stisnutim kvacilom. Tako da bih tu otpisao te neke elemente koji dovode do vibracija samo u voznji kada su spojeni tockovi sa motorom. Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 8, 2021 Jeste, oseca se vrlo malo, ali se oseca. Nesto oko motora, ili sam rad, ili dizne ( to idem kasnije da proverim ) dpf je pitanje kako je ugasen pa cemo i to sad proveriti, da precrtamo i to. Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 8, 2021 Update: Auto ostao kod Joce u ProTuning servisu. Komp je izvadjen napolje, kaze covek neko se opasno zaigrao sa mapom i potpuno je unakazio. Ide org mapa nazad, proba, pa nova Tuning mapa kad je vec sve raskupusano. Ako Bog da da to bude resenje, vozimo se na nekih 220ks u buducnosti. 5 Bingodalton, knezevic76, MS PK and 2 others reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 9, 2021 Bezuspesno. Zamolicu moderatore da zatvore i obrisu temu. Hvala. Share this post Link to post Share on other sites
skile86 539 Posted February 9, 2021 Bas mi je zao sto nisi uspeo da nadjes uzrok tog problema. Share this post Link to post Share on other sites
rkoma1986 1113 Posted February 9, 2021 Si resio da ga se resavas? Share this post Link to post Share on other sites
ISV_01 4036 Posted February 9, 2021 Brate, ti stopama Flex-a - puno živaca za auto koji bi trebao biti relativno jednosavan, al mu se baš neće da bude takav. Jel to nisu uspeli mapu da vrate ili ? 1 alfini0507 reacted to this Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 9, 2021 Mapa je stavljena, ali je sve ostalo isto. Promena nema. 99% je do samog kvacila i da ne moze da istrpi tu snagu auta. Bori se ali ne moze da izgura. Vozimo ovako dok ne prokliza, posle reparacija kod Fice za jacu snagu. Nema sta drugo biti. Vibracije u leru su nestale posle odradjenog malog servisa, samo u voznji kad se potopi gas. Namestili smo mapu da kriva obrtnog bude sto laksa za zamajac i to mu je dosta od mene 1 horvat reacted to this Share this post Link to post Share on other sites
vagenovac 4533 Posted February 9, 2021 Cek, a kako je sa originalnom mapom? I zasto je ta druga toliko losa kada je auto linearno ubrzavao i sa njom. Mozda je kriva korpa kvacila ili samo kvacilo, sta kazu kako im izgleda kada si menjao zamajac, jel poplavelo, deformisalo se, bilo sta. Share this post Link to post Share on other sites
Nikola JTD 230 Posted February 9, 2021 Nisam probao org mapu, samo uradjenu, tj prepravljenu po parametrima auta. Mozda bi fabricka to eliminisala ko ce ga vise znati... 3h radi covek mapu, sad da ga ja smaram ajmo ovo ajmo ono ne ide. Kvacilo je fizicki kaze majstor super. Zamajac stari kacio sam link nema ni najmanji trag zagrevanja, ali zagreva se kad proklizava, kad ne proklizava slabo se zagreva pri ubrzanju. Share this post Link to post Share on other sites
vagenovac 4533 Posted February 9, 2021 Na grande punto se centralni ovaj deo razlokao, sigurno je tu imao lufta, kao i zamajac po svim osama. Stoji mi u dvoristu pa je izrdjalo, nije bilo takvo kad je majstor zamenio. Takodje korpa je delovala malo kriva, ali tesko je to snimiti. Kvacilo nemoj reparirati jer ne mogu ovaj centralni deo zameniti, ako je slican sistem, mogu samo obloge zameniti i staviti deblje i od materijala koji ima vise frikcije. Eh da jos jednu stvar koju sam primetio nakon zamene, da punto lakse nekak vergla i pali, ali mozda je samo placebo. Share this post Link to post Share on other sites
danijel55 700 Posted February 9, 2021 Cim budem isao kod ovoga, obavezno cu ga pitati.Mora pravi majstor da zna do cega.Nije mu stigao auto pa nisam ni isao,al prvom prilikom cu ga pitati.Bas bedak. Share this post Link to post Share on other sites
dellas 1556 Posted February 9, 2021 Mora pravi majstor da se prihvati posla i da resi problem...tesko ce ga resiti a da ne vidi auto 2 Ivan BG and bglion reacted to this Share this post Link to post Share on other sites
MS PK 7734 Posted February 10, 2021 On 2/9/2021 at 5:07 PM, Nikola JTD said: Nisam probao org mapu, samo uradjenu, tj prepravljenu po parametrima auta. Mozda bi fabricka to eliminisala ko ce ga vise znati... 3h radi covek mapu, sad da ga ja smaram ajmo ovo ajmo ono ne ide. Kvacilo je fizicki kaze majstor super. Zamajac stari kacio sam link nema ni najmanji trag zagrevanja, ali zagreva se kad proklizava, kad ne proklizava slabo se zagreva pri ubrzanju. Trebao si na kraju da mu odvrnes tu mapu na max i verovatno bi brzo crklo to nesto sto ti pravi problem i eto resenja 5 alfini0507, knezevic76, vagenovac and 2 others reacted to this Share this post Link to post Share on other sites
vagenovac 4533 Posted February 10, 2021 Hahah svidja mi se kako razmisljas Share this post Link to post Share on other sites
