ISV_01 4036 Posted July 10, 2021 Danas smo specijalno ulgancani i ulickani 4 silenci, Dzimbo, neshaoct and 1 other reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted July 10, 2021 Ideš u svatove ili si i ti prešao u naš tabor? Quote Share this post Link to post Share on other sites
MS PK 7735 Posted July 10, 2021 Pa ko se jos ozenio u svojim kolima? 2 2 ISV_01, darkman14, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted July 10, 2021 Što jes, jes, udarila me vrućina, al' s' obzirom da se furaju čeličare, sve je za očekivati 2 1 ISV_01, MS PK and Dzimbo reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted July 17, 2021 Ruzne ratkapne u akciji 3 djomla, silenci and neshaoct reacted to this Quote Share this post Link to post Share on other sites
Branislav 722 Posted July 17, 2021 Sve je bila samo sala, felne nikada nisu ni bile kupljene vec samo slika sa googla stavljena, malo da zagolica mastu 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted July 17, 2021 Postoji plan kad treba da se stave... 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted July 17, 2021 Svečano montiranje felni, samo se nadam da neće i -- da bude na "otvaranju" Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted July 17, 2021 Lepo kaze nesa, postoji plan kada se menjaju. Finansijska konstrukcija je takva kakva je, ni ja je ne volim Nije daleko Septembar... Eventualno ranije u Avgustu (manje verovatno). Prvo da napunimo baterije, ova godina je bas za crkavanje po terenu... Svakako moram pre Oktobra, kako god. To je poslednji momenat. Najzad da felne ugledaju svetlost dana i Bravko osvezi izgled.. 2 djomla and silenci reacted to this Quote Share this post Link to post Share on other sites
silenci 2337 Posted July 17, 2021 ma samo polako,sve ce doci na red,cak nemoras ni ove godine,pa na prolece da ih montiras. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted July 17, 2021 A mi smo krivi sto smo te naterali da ih kupis na silu 1 1 ISV_01 and djomla reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted July 17, 2021 Ne bih se usudio da sa iscepkanim obodom gume zalazim u zimski period. 5 godina za AS gumu je po meni sasvim dovoljno da lete u kantu iako sigurno dubina sare je oko 5mm na svim tockovima (zdrav deo gume). Ipak je to kombinovana smesa gume, - 20C/+65C.. Nije po meni to sigurno posle 5 godina nezavisno od proizvodjaca, kao ni ovi sto voze zimski Riken na +65C Jeste Mico, ta ti je kao u Njegosa! Sad sam poceo da gledam i Blisten B4 i pro kit...kud naleteh na te teme po forumu i Yugisu kao poznavaoca i zagovornika Blistena Sve cu pare kod meanicara ostaviti Quote Share this post Link to post Share on other sites
Ivan 17680 Posted July 17, 2021 1 hour ago, ISV_01 said: Svakako moram pre Oktobra, kako god. To je poslednji momenat. Najzad da felne ugledaju svetlost dana i Bravko osvezi izgled.. 1 4 Reacher Gilt, djomla, Mijailović P. and 2 others reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted July 18, 2021 2 Reacher Gilt and silenci reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted July 22, 2021 Uskoro ce i kraci putopis... Cim se dokopam CG. Nista od BG-CG bajsem, na zalost ali bice nesto drugo. 3 Reacher Gilt, Ivan and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted August 19, 2021 D sredim poklopac rezervoara, davno sam obecao jos. Prepakivanje nekog sto su mi poslali za vagen grupaciju (manji prsten od 65mm, kod Brava je 75mm precnik kruga). Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted September 28, 2021 (edited) Za vikend palo verovatno poslednje ovogodisnje voskiranje do proleca, pa su pale 2 ruke. Arexons ultra wax. Najzad se stvorile prilike za gume (Sava As) pa se uzimaju pocetkom sledeceg meseca, no da bude covek baksuz, padne mi neka oceva gajbica na poklopce od felni, pa ce morati potpuna generalna opravka Svi im drzaci popucali na 2 poklopca...sve im @! Sreca, imam zamenske samo za centralnu rupu, ionako cu sa njima da testiram trajnost cepova na parkingu pre nego da stavim fabricke..ako ih bar kradu, da saznam na jeftiniji nacin Bar imam cime da se zanimam sledece nedelje. Stare felge ce u garazu, a jedna felna kao rezevni tocak ce da se koristi, ipak je fabricka dimenzija. Pripreme za 4.ti mali servis i drzim se standardnog.. Ulje Motul 8100 EFE, Filter vazduha i goriva Champion (bio Clean za gorivo pre), ulja Mann i kabine Filtron sa aktivnim ugljem. Menjace se i hladnjak ulja, po savetu majstora stari nije u bas idealnom stanju. Sledece godine (5g) vec v.servis...bas vreme leti. Edited September 28, 2021 by Ivan Sredjene slike 5 silenci, MS PK, Dzimbo and 2 others reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted September 28, 2021 Jel to rucno voskiranje? Krpa i udri? Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted September 28, 2021 @alfini0507 Da da, licno radim takve stvsri, pravi gust i realno najbolje je to sam uraditi, pedantno i natenane. 2 alfini0507 and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted September 28, 2021 Ufff... Verujem da je crnacki posao... Koliko to bude vremenski druze? 2 Reacher Gilt and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2186 Posted September 29, 2021 Ja takav sjaj dobijem kad ga operem s' kevinu šaumu, kak'i vosak, kak'i bakrači ... 2 1 alfini0507, ISV_01 and shuxx reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted September 29, 2021 (edited) @alfini0507 Sta znam, samo voskiranje jednom rukom je oko 40 min, ispod 1h svakako. Prednost kod ovog K2 Ultra Wax (ne, nije Arexons ipak, pogresio sam) je sto se zaista lako nanosi i skida a nije u spreju vec klasicna metalna kutija. I traje poprilicno dugo, u proseku oko 3-4 meseci, zavisno da li ga peres na crevo ili ides na pusku kao i od vremenskih uticaja. Zimu pregrmi i to mi je dovoljno da oko februara imam sledece voskiranje (u januaru retko, niske su temperature ali ni to nije nemoguce ako bude suncan dan). Ipak je ovo vosak ne-premium pa i onaj sto ima godinu dana efekat sam sumnjicav osim ako auto nije najveci deo vremena u garazi. Keramika i sl je nesto drugo zbog adhezionih svojstava. Jednom sam se zezno, nisam gledao kada sam kupovao, kutija je bils zuta i podsecala na Formula 1 (sasvim ok voskovi), ali pisalo Fantastic 1...au brate... Kako sam se orobio dok sam ga izvoskirao, posle sam kanticu sutno u djubre, nikad se nisam tako napatio. Turtle je neka klasika isto je dobra preporuka, koristili smo ga na svim autima sto smo imali, Arexons je isto dobar. Ja sam vise za neke mid budget varijante, one skupe cu mozda nekad probati, ali sada u momentu ocekivanja klinca, nikako. Meni je detaljno pranje (2x kofa i sundjer) uzelo oko 30 min ukupno da ga napenusam, oko 5 min dobrog ispiranja i susenje jelenskom kozom oko 15min. Vosak oko 30-40 min jedna ruka sa sve glancanjem. Mozda moze i brze, ja malo i uzivam, ne radim na normu @Rasta Feri mi ubedljivo najbolje skida stroku, a sa shaumom... Vidis... Edited September 29, 2021 by ISV_01 2 alfini0507 and shuxx reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted September 29, 2021 Klinja na prvom mestu pa sve ostalo... Onda jurim taj K2 da isprobam... Otvoren poziv i dalje stoji kad si u prolazu 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted October 5, 2021 (edited) Da turimo crveno slovo? Sava AllWeather 225/45R17, XL sa zastitom oboda felne, novi ventili. Sara mLogo dobra. 34K skupa. Edited October 5, 2021 by Ivan Sredjene slike i format 11 1 shuxx, Dzimbo, Milutinac and 9 others reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted October 5, 2021 Zato je noćas pao Facebook i sve oko njega 4 7 alfini0507, Milutinac, Reacher Gilt and 8 others reacted to this Quote Share this post Link to post Share on other sites
