bglion 401 Posted August 18, 2019 Obično to upozorenje izbacii kad prekines regeneraciju. Odvozis ga malo u obrtajima. Quote Share this post Link to post Share on other sites
Savke011 0 Posted August 18, 2019 Da li neko zna koliko bi kostalo uklanjanje Dpf filtera mehanicki i softversi,zatvaranje i eger ventila i novo mapiranje ? Da se nastima da radi kao da nikad nije ni imao to s.... Da li ima neko u okolini Nisa da to radi kvalitetno ? Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted August 18, 2019 Ima sigurno samo sacekaj juznjake da se jave... DPF u kompletu oko 100tke evro gore dole... EGR ide manje... Quote Share this post Link to post Share on other sites
totti 13165 Posted August 18, 2019 Ima onaj dečko sa foruma što radi mape, al' da me ubiješ ne mogu da mu se setim nadimka odavde Quote Share this post Link to post Share on other sites
MS PK 7735 Posted August 18, 2019 Mladenke? 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
shomispc 832 Posted August 18, 2019 Ili@pittatore Quote Share this post Link to post Share on other sites
totti 13165 Posted August 18, 2019 On 8/18/2019 at 8:59 PM, MS PK said: Mladenke? Taj. Meni sve nešto u glavi bilo Mikele, al' to mu dođe to Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted August 18, 2019 Bas taj... Quote Share this post Link to post Share on other sites
underground79 19 Posted August 18, 2019 (edited) mladenke nije aktivan bas dugo na forumu .. ja sam hteo bas da ga kontaktiram trebao mi je nesto pre nekoliko meseci Edited August 18, 2019 by underground79 Quote Share this post Link to post Share on other sites
shomispc 832 Posted August 19, 2019 Probajte na ARCS Quote Share this post Link to post Share on other sites
dekirs 4819 Posted August 19, 2019 Imam ja broj od Pitatorera, ali koliko znam oni ne uklanjaju DPF fizicki, samo softverski.. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 19, 2019 On 8/17/2019 at 7:43 PM, alfini0507 said: @Milutinac jel gresim? Jok. Sada koristimo samo ČGN! On 8/17/2019 at 7:55 PM, Savke011 said: Iscupao bi ga ja da znam da nece da me zezaju na tehnicki,procita pola ove teme,neki kazu nece bude problema neki oce Ako ti tako nastavi da salje "skrivene" signale, dize nivo mesavine ulja i nafte - imaces veci problem sa kolima nego taj famozni tehnicki pregled sto je 3 djomla, alfini0507 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
Savke011 0 Posted August 19, 2019 5 hours ago, dekirs said: Imam ja broj od Pitatorera, ali koliko znam oni ne uklanjaju DPF fizicki, samo softverski.. Ali mora se i fizicki ukloniti ili moze samo softverski ? 4 hours ago, Milutinac said: Jok. Sada koristimo samo ČGN! Ako ti tako nastavi da salje "skrivene" signale, dize nivo mesavine ulja i nafte - imaces veci problem sa kolima nego taj famozni tehnicki pregled sto je Sledeci put ako upali lampicu za ulje ili za dpf to je to,skidam to sve i kraj. Mozda se do Crne gore izduva,sipacu aditiv u gorivo pa da vidim. Samo da mi ne rokne negde uz put da digne pritisak ulja jel onda ne znam sta da radim.... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 19, 2019 Fizicki + softverski. Jedno bez drugog ne moze. 2 neshaoct and alfini0507 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted August 19, 2019 Bas kao sto kaze kolega, nema poente softverski iskljuciti kada ti u izduvnoj grani imas komad betona koji onemogucava normalan protok izduva... 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted August 19, 2019 On 8/19/2019 at 1:08 PM, Savke011 said: Sledeci put ako upali lampicu za ulje ili za dpf to je to,skidam to sve i kraj. Mozda se do Crne gore izduva,sipacu aditiv u gorivo pa da vidim. Samo da mi ne rokne negde uz put da digne pritisak ulja jel onda ne znam sta da radim.... Nemoj samo da bude kasno Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted August 19, 2019 A šta se dešava kada se fizički skloni dpf ili se jednostavno izbuši dugačkom burgijom? Sonda onda očitava slab pritisak ili šta već pa javlja grešku? Kontam ako je pritisak visok znači dpf je začepljen ili prljav i onda forsira regeneraciju... Quote Share this post Link to post Share on other sites
McSteel 550 Posted August 19, 2019 2 hours ago, Zvezdo said: A šta se dešava kada se fizički skloni dpf ili se jednostavno izbuši dugačkom burgijom? Sonda onda očitava slab pritisak ili šta već pa javlja grešku? Kontam ako je pritisak visok znači dpf je začepljen ili prljav i onda forsira regeneraciju... Da, senzor pritiska očitava premalu razliku na ulasku u DPF i na izlasku, sistem upozorava na neispravan senzor. To je taj deo koji se rešava u softveru (zajedno sa fiksiranjem nivoa začepljenosti DPF). Što se tiče nivoa začepljenosti, čita se i protok i pritisak i temperatura. Čišćenje može da nastupi samo pod dovoljnim pritiskom i temperaturom, zato za uspešno čišćenje nije dovoljno samo "navući" obrtaje, već motor mora biti pod barem minimalnim opterećenjem (turbina mora aktivno da stvara boost i izduvni gasovi da su bogati i dovoljno vreli). Recimo ne bi uspelo čišćenje ako je motor na 3000 rpm ali da je nizbrdia i uz nominalan gas ili čak bez gasa (blago motorno kočenje). 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Savke011 0 Posted August 21, 2019 Danas sam vozio auto do grada i u povratku mi se upali opet lampica za dpf,tj onaj trougao i uzvicnik unutra. Izadjem van grada i poteram ga malo u 3 cu na 5k obrtaja u 4 tu na 4k obrtaja nisam ga spustao nekih 8-10km i ugasi on lampicu potrosnja padne za nekoliko litra ispod. U povratku sam primetio da mi obrtaji vise ne variraju kad se izbaci iz brzine,nekad kad se izbaci skone na 1000+ obrtaja pa se stabilizuje,sad vise to nema i za sad vise nema kad ga izbacim iz brzine da mi na bordu pokazuje po 15-20l potrosnju sad pokazuje 2l kako treba nekad se popne do 3-4 i to je to. Razmisljao sam preventivno da ocistim eger ventil pred more, i kad krenem da mu sipam onaj wyns jaci na full rezervar i mislim da nece vise da pravi problem,ako se tad ne izduva kako treba onda nikad nece. Takodje cu sledece nedelje otici na dijagnostici da mi izmere koliki je procenat zapusenosti dpf-a bas me zanima,samo da pokaze na dijagnostici kako jeste da ne pokaze 50% a on je u stvari 100% pun ? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 21, 2019 Zacepljenost varira. I sve u razmaku od par desetina km...SAmo je pitanje kada odradi regeneraciju da li spusti na tih nekih prihvatljivih 15-20% koliko li vec. I koliko ce brzo da dodje do 100% posle 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted August 21, 2019 Sto kaze kolega, ima i do goriva (u principu jedan od najvecih faktora), stila voznje, cistoce filtera za vazduh i slicno. Uspesnost ciscenja, na zalost, ne mozes nikako proveriti drugacije do dijagnostikom da bi video % ociscenosti filtera. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 21, 2019 Ili sređujte, ili ga čupajte napolje...najgore je da čekate jer od tog čekanja, kad je DPF u pitanju i kad je već počeo da pravi probleme - nema ništa dobro. Ako se vadi napolje, kao što je već rečeno, treba to da se uradi ''kulturno'', da ne ''vrišti'' da nema DPF-a čim se auto pogleda odozdo. 3 alfini0507, MS PK and McSteel reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted August 22, 2019 Znaci ako se vadi bitno da je kulturno i da ne vristi 2 2 Milutinac, neshaoct, ISV_01 and 1 other reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 22, 2019 ...to mi je jasno, ali ovo zagledanje od dole 1 3 McSteel, neshaoct, ISV_01 and 1 other reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted August 22, 2019 Pa jbg, 100 ljudi 100 cudi 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
