MS PK 7735 Posted March 2 Bravoo Djolee! 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 2 Hvala Mićo !!!! 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
frostysrb 146 Posted March 3 Neka je sa srećom, prelep auto trenutno pored 500 Abarth jedini Fiatov model koji sa zadovoljstvom gledam 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 9 Vikend ,obavezno sredjivanje-čišćenje.... 7 Decak Iz Vode, italiano, Reacher Gilt and 4 others reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2187 Posted March 9 I tako ga trljkaš i usisavaš mu poslednje zrnce peska iz tepiha, i nakon deset godina prodaš nekom Zokiju, koji nakon kupovine krene da ga vozi bez patosnica. 1 2 Djole_M, shuxx and Aurelio reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 9 Baš tako ...ali jbg dok je kod mene neka bude tip top 2 Aurelio and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 20 Od kupovine auto pa do danas odradjen redovan mali servis u ovlašćenom servisu kao i zamena vodene pumpe i seta pk kaisa ,takoreći kompletan veliki servis. Za ovo kratko vreme od kad ga imam zadovoljan sam bas voznjom ,udoban sasvim dobro ,prostora sasvim dobro za nas četvoro ....po gradu bije 8 litara.Jedina nazovi zamerka za sada su rucice iza volana za žmigavce i brisače imam utisak da su malo dalje od volana ....kad dajes zmigavac malo trazis rucicu nije bas odmah do prsta....Inace sve ok nisam se pokajao.Kako kazu ako se ne okrenes za autom kad parkiras nije te kupio a ja se okrenem jedo 2-3 puta minimum A da jedna sitnica koja sledi umesto crvenog znaka 2 Reacher Gilt and Aurelio reacted to this Quote Share this post Link to post Share on other sites
Markoni147 48 Posted March 20 I meni je to bilo prvo što sam primetio, previše udaljena ručica komandi za migavce i brisače. Inače nama je auto stigao bez jednog dela zadnjeg znaka 500X (iz dva dela je). Zvao da pitam koja je cena jer sam mislio sam da kupim, da se ne cimam sa dilerom, ali kada mi rekoše 5500 din. ipak ću se cimati. 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 20 Cekaj koji je to deo znaka ,nisam ispratio tvoje predstavljanje auta ? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted March 21 @Markoni147 Fiat 500X je sada u svojoj temi: https://www.fiat-lancia.org.rs/forum/index.php?/topic/86100-markonijev-fiat-500x/ Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 23 Danas dan idealan za zamenu guma,nije gužva ....Послато са 22101316G помоћу Тапатока Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 23 Vikend ne moze da prodje bez pranja ...Sad moze kiša ...Послато са 22101316G помоћу Тапатока 7 1 Martin, shuxx, Misha87 and 5 others reacted to this Quote Share this post Link to post Share on other sites
Martin 799 Posted March 23 Obavezno kiša!!! 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
Markoni147 48 Posted March 23 Urednog ga držiš, svaka čast. 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted March 31 Malo glanz ... 2 shuxx and moron reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted April 6 (edited) Stigli stikeri pre 15 minuta ... Edited April 6 by Ivan Sredjena slika, skinut TT potpis 4 moron, neshtry, shuxx and 1 other reacted to this Quote Share this post Link to post Share on other sites
Ivan 17685 Posted April 6 (edited) Po meni gre'ota lepiti stikere na relativno nov auto. Cisto estetski, jer stiker nikada ne moze da ima onaj lep 3D efekat slova, kao na fabrickom znaku. Plus ce ti plastificirani stikeri uvek da strce van ravni znaka, nema okvira oko slova, itd... A i u medjuvremenu smo provalili par jeftinih fora za sredjivanje tih bordo Fiatovih znakova, koji vremenom maltene svi podlupe, uvuku vlagu i prljavstinu i ne lice ni na sta (ili prednji razbije kamencic sa puta). Ako ode cela plastika, ima ova fora sa zamenskim znakovima (85 mm, 95 mm, 100 mm, 120 mm) - u ovom mom postu detaljno (tu se dodatno spasava i zadnji mikroprekidac, posto je takav znak 70 EUR): https://www.fiat-lancia.org.rs/forum/index.php?/topic/76043-fiat-nuova-bravo-uputstvo-za-zamenu-zadnjeg-znakaprekidača-za-gepek/&do=findComment&comment=1645640 Ukratko i fotka, stiker vs znak: On 4/22/2022 at 8:20 PM, Ivan said: Cisto kao dodatak, moja stara slika koju sam vec negde kacio - poredjenje ovakvog aftermarket znaka i Petrovog stikera za mikroprekidac od 95 mm: A ako je plastika cela i sredjuje se i menja boja - ima sve lepo objasnjeno u ovom Milutinovom postu. Upravo je i on menjao u crnu boju pozadine, umesto fabricke bordo: https://www.fiat-lancia.org.rs/forum/index.php?/topic/76043-fiat-nuova-bravo-uputstvo-za-zamenu-zadnjeg-znakaprekidača-za-gepek/&do=findComment&comment=1429036 On 2/9/2018 at 10:05 AM, Milutinac said: Edited April 6 by Ivan 3 moron, Lufti and Djole_M reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted April 6 (edited) Sutra cu da probam na autu ,odradjeni su stvarno tip top .....u medjuvremenu par novih slika: Edited April 6 by Ivan Sredjene slike 7 city, moron, Aurelio and 4 others reacted to this Quote Share this post Link to post Share on other sites
shuxx 10907 Posted April 6 COOL garaža 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
Ivan-Topola 329 Posted April 6 2 hours ago, Djole_M said: Sutra cu da probam na autu ,odradjeni su stvarno tip top .....u medjuvremenu par novih slika: Sve pohvale za tretman Drugar je radio Ford Kugu kod ovog decka u Kg, full tretman i licno sam pregledao auto nakon tretmana. Iskreno sve preporuke svima kojima je to potrebno, sigurno ce biti zadovoljni 3 Djole_M, Aurelio and moron reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted April 7 Evo kako su legli stikeri ....ja sam bas zadovoljan Послато са 22101316G помоћу Тапатока 4 Lufti, Mijailović P., Aurelio and 1 other reacted to this Quote Share this post Link to post Share on other sites
neshtry 14885 Posted April 7 Mnogo bolje! 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
Djole_M 150 Posted April 7 Meni se bas dopalo , nekako mi crveni znak štrči na crno belom autu ....Послато са 22101316G помоћу Тапатока 2 Aurelio and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
city 748 Posted April 7 Priznaj da volis crno bele 1 Djole_M reacted to this Quote Share this post Link to post Share on other sites
