McSteel 550 Posted November 5, 2019 2 minutes ago, vagenovac said: A-HA! Nece sebi plastidip, a meni predlaze, ccc Tek sad kad si spomenuo vidim da je tebi predložio za front grille... Dobar je predlog btw 2 PremieRacing and vagenovac reacted to this Quote Share this post Link to post Share on other sites
francuz69 995 Posted November 5, 2019 4 hours ago, PremieRacing said: Bravo oko sokolovo... Ucrvenio sam ih za sve pare I rikverac svetlo je crveno, znam da nije po 'zakonu', znam da se sad slabije vidi ali sam hteo da SVE pozadi bude crveno. Jel samo mene podseca na: 1 3 Irena HGT, PremieRacing, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 5, 2019 (edited) 51 minutes ago, PremieRacing said: ...AKO mi se dopadne moja vizija da tablicu premestim na crni deo branika, onda cu morati ponovo i mnogo ozbiljnije da uradim deo gepeka ispod stakla. Uzivo je puno drugacije nego na slici, ne izgleda nikako... Evo samo jos 1 fotka i necu vise , samo da se vidi koliko je lose trenutno u stvari i zasto ce tablica deff morati na svoje std mesto za sada. Edited November 5, 2019 by PremieRacing 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted November 5, 2019 Nije plasti dip bas toliko jak, evo 5 godina kako ga koristim, na stopaljkama 2 godine bez problema, za enterijer super, za drske brisaca onako, ali za branik gde ces verovatno kaciti o nesto - nije bas za preporuku, pogotovu kad krene da se guli, povuces malo jace i ode sa celog branika.. 1 1 PremieRacing and McSteel reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 5, 2019 Aaaaaaaaaa, i zaboravio sam mali ali prelep detalj u enterijeru od danas, simetriju kod menjača...: 3 horvat, McSteel and Boris88 reacted to this Quote Share this post Link to post Share on other sites
McSteel 550 Posted November 5, 2019 5 minutes ago, Danilo1 said: Nije plasti dip bas toliko jak, evo 5 godina kako ga koristim, na stopaljkama 2 godine bez problema, za enterijer super, za drske brisaca onako, ali za branik gde ces verovatno kaciti o nesto - nije bas za preporuku, pogotovu kad krene da se guli, povuces malo jace i ode sa celog branika.. Mala opaska na ovo - ima veze i način nanošenja, i to da li je u pitanju baš Performix-ov originalni Dip ili je neki od alternativnih proizvođača u pitanju (jer je patent istekao). Malo kontraintuitivno možda, ali za branik je bolje naneti (što) tanji sloj, biće manje sklon neželjenom ljušćenju. Pri tome, treba branik temeljno "okupati" alkoholom a onda destilovanom vodom pre "dipovanja" za najbolji učinak. Ako se i pojavi oštećenje, možeš da "okidaš" oko njega pritiskajući prstom gde želiš da se prekine opna, i preprskati samo taj deo i bližu okolinu, i biće ok. Naravno bolje ako se uradi ceo ponovo ili barem veći segment (preko logičke particije branika, oivičene prevojima i ivicama), ali nije striktno neophodno... Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted November 6, 2019 Naravno, samo original iz Amer'ke Pa ako stavi tanak sloj, nece biti tamno, vise ce biti neka tamno siva nego crna (za stopaljke ide bas tanak sloj i ne ljusti se ali nije bas crna boja) 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
McSteel 550 Posted November 6, 2019 1 hour ago, Danilo1 said: vise ce biti neka tamno siva nego crna Misliš, kao i originalna plastika iz fabrike? 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted November 6, 2019 haha ne bas, bice kao sto mu je sad - a to mu ne odgovara 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 6, 2019 12 hours ago, PremieRacing said: Idem sa pokusajima od najblazeg (sredstva za plastiku, Zdrnja kaze keramika se najbolje pokazala) - probamo pa vidimo. Drugi korak je onaj invazivan nacin sa grejanjem, a na kraju mi je opcija farbanje. Folija nikako... Tako daaaaaa, i plastidip je 'farbanje' pa je kao opcija na poslednjem mestu. Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 6, 2019 Nešto sam razmišljao o bivšim automobilima i koje su razlike - šta sam imao, šta sam dobio a šta sam izgubio zamenom pa sam ih uporedio... Prilično interesantno Delta sa najmanje kubika ima najveću snagu i najveći obrtni moment. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 6, 2019 Jedan dizel tu sada fali da "pokvari" kompletan grafikon 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 6, 2019 Ni-ka-ko Quote Share this post Link to post Share on other sites
horvat 6456 Posted November 6, 2019 Alfa 159, 2.4 jtdm 209 ks, karavan, automatik 1 2 dekirs, Zvezdo and Milutinac reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 6, 2019 (edited) P.S. i nisam rekao "nikad", naučio sam od Jamesa da nikad ne kažem nikad... 8 minutes ago, Milutinac said: Jedan dizel tu sada fali da "pokvari" kompletan grafikon Šta će mi dizel sa ovakvom krivom obrtnog momenta Jeltice Možda jedino zbog cene koštanja vožnje... Tu sam već doooobrano primetio razliku u odnosu na Audi sa tng-om Edited November 6, 2019 by PremieRacing 1 horvat reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted November 6, 2019 57 minutes ago, PremieRacing said: i nisam rekao "nikad" cek, ucini mi se da je neko rekao nikad dizel... 2 PremieRacing and McSteel reacted to this Quote Share this post Link to post Share on other sites
McSteel 550 Posted November 6, 2019 1 minute ago, andreja.micovic said: cek, ucini mi se da je neko rekao nikad dizel... Nemoj dolivati (dizel) ulje na vatru 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 6, 2019 7 minutes ago, andreja.micovic said: cek, ucini mi se da je neko rekao nikad dizel... Neeeeee, rekao je "SADA I NIKAD VISE!" 1 2 dekirs, PremieRacing and horvat reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 6, 2019 Stvarno nema potrebe... mislim, za naše potrebe nema potrebe. Ako neko ima potrebe da razume naše potrebe. Po potrebi 1 McSteel reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted November 6, 2019 18 minutes ago, Milutinac said: Neeeeee, rekao je "SADA I NIKAD VISE!" Eh da se tipo isporucuje sa 2.0mjet... pa da se razmotri za koju godinu.. Ovako neki renegade, 500x (koji mi je jako lep ali nepraktican)... 2 MS PK and bglion reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 7, 2019 (edited) Moša... Sinoć dogovorio sve sa nečovekom, rekao da su felne još na autu, nema vremena da ih skine, poslaće još koju sliku danas i onda mi stigne poruka "druže, prodate felne" . Sa takvima nikad nisam bio niti ću biti drug. Idemo dalje, jače i bolje Edited November 7, 2019 by PremieRacing Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted November 7, 2019 P A C O V . . . A C O V . . . 2 djomla and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted November 7, 2019 (edited) A Sei na grafikonu? Fali ti neki koji ide do jedno 7500-8000 Edited November 7, 2019 by YUgisa 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted November 7, 2019 Stvarno nema potrebe... mislim, za naše potrebe nema potrebe. Ako neko ima potrebe da razume naše potrebe. Po potrebi Odma' sam ga se setio Sent from my SM-G950F using Tapatalk 4 dekirs, bglion, PremieRacing and 1 other reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted November 7, 2019 22 hours ago, andreja.micovic said: Eh da se tipo isporucuje sa 2.0mjet... pa da se razmotri za koju godinu.. Ovako neki renegade Lineu su ogranicili na 120 KS max (1.6 Multijet i 1.4 T-Jet). A verovatno ce i ostati tako, i od novih Firefly turbaka, za MY21 najavljuju samo 1.0 T3 (opet 120 KS i skromnih 190 Nm, trocilindras). A imaju i T4 verziju (1.3, 150 KS, 270 Nm) ali izgleda da nije planirana. Kada pominjes Renegade - pricao mi nas Gorance dok sam letos cekao na malom servisu, a nedavno sam imao priliku da se i licno provozam... Facelift 2019, sa T4 1.3 Firefly (180 KS i 285 Nm) - kako taj motorcic ide u toj karoseriji, naopako ... 1 horvat reacted to this Quote Share this post Link to post Share on other sites
