totti 13165 Posted May 28, 2019 Deco draga, šta će vam bre ovo tandrkanje... 2 bit and horvat reacted to this Share this post Link to post Share on other sites
neshtry 14875 Posted May 28, 2019 E to je taj legendarni zvuk 2 frostysrb and silenci reacted to this Share this post Link to post Share on other sites
neshaoct 9592 Posted May 28, 2019 Čuje se, čuje... 1 neshtry reacted to this Share this post Link to post Share on other sites
Ivan 17680 Posted May 28, 2019 Cini mi se da levi far moze komotno jos gore . 1 horvat reacted to this Share this post Link to post Share on other sites
horvat 6457 Posted May 28, 2019 Zar to nije po 'fabrici' da desni bude malo visi? Share this post Link to post Share on other sites
MS PK 7735 Posted May 28, 2019 Extra! Na malom gasu odlicno, na vecem se cuje da je mali motor al jbg Послато са SM-J330F уз помоћ Тапатока 1 horvat reacted to this Share this post Link to post Share on other sites
horvat 6457 Posted May 28, 2019 Upravo tako! Na vecem gasu onako i nema neke poente, samo je malo glasniji, ali tu do ~4.000 rpm bas ima finu duboku notu Share this post Link to post Share on other sites
MS PK 7735 Posted May 28, 2019 Meni se bas svidja, voleo bi isto tako i kod mene na traktoru Послато са SM-J330F уз помоћ Тапатока Share this post Link to post Share on other sites
Milutinac 5906 Posted May 29, 2019 Meni je to taman kako treba pa nije to 1.3mjet pa da nema ni šta da se čuje a ni zašto... Očekivao sam neku škripu guma 2 frostysrb and horvat reacted to this Share this post Link to post Share on other sites
horvat 6457 Posted May 29, 2019 Hahah, nisam hteo da ometam zvuk izduva nekim drugim zvukovima Share this post Link to post Share on other sites
Milutinac 5906 Posted May 29, 2019 Bojao si se ti da neki kamencic ne udari-tamo-gde-ne-treba-da-udari Share this post Link to post Share on other sites
horvat 6457 Posted May 29, 2019 Ima i toga, moram priznati Share this post Link to post Share on other sites
Ivan 17680 Posted May 29, 2019 11 hours ago, horvat said: Zar to nije po 'fabrici' da desni bude malo visi? Desni kraj snopa svakog LH fara je naravno visi, bilo da je reflektorski ili projektorski far u pitanju, dok se pad ziza steluje identicno na oba (sa sitnim korekcijama kasnije). Hteo sam da ti kazem upravo ovo drugo - deluje mi da levi far ima preveliki pad u odnosu na desni. Uporedi pad snopa oba fara niz ove gredice u garazi gledajuci i kad stoji, a pogotovo kada je trunku "stosovao" u pokretu. Cisto drugarski savet da proveris snop negde na zidu, pad treba da bude 1% (tj. 10 cm na 10m po fabrici, ti to mozes jos malo da korigujes kako ti odgovara, a da ne smetas ljudima koji idu u susret). Ako je potrebno, upuca se lagano za 15-ak minuta. 1 neshtry reacted to this Share this post Link to post Share on other sites
horvat 6457 Posted May 29, 2019 Pogledacu, svakako hocu da menjam sijalice uskoro, pa taman 1 neshtry reacted to this Share this post Link to post Share on other sites
Ivan 17680 Posted May 29, 2019 Cisto drugarski savet za proveru, u cilju da masinica bude tip-top, nadam se da ne shvatas drugacije . Mozda je samo moj utisak, svakako ces sam najbolje videti kako se ponasaju zize kada se budes odmicao od zida. Imas oko procedure (koja je jednostavna) detaljno i ovde kod nas na forumu, ako ti zatreba neki info. Isto vazi i za projektorski i za reflektorski far. Koje sijalice planiras, neki upgrade ili ostajes na klasicnim sa vlaknom? 1 frostysrb reacted to this Share this post Link to post Share on other sites
horvat 6457 Posted May 29, 2019 Pogledacu svakako, nisam do sada ni jednom stao na zid bas da proverim da li ispravno bacaju. Vec sam jednu sijalicu menjao (desnu cini mi se), i moguce da sam mozda cak tom prilikom malo i razdesio. Philips X-treme Vision sam mislio da probam. S obzirom da ne koristim kratka svetla danju, mislim da mogu da idem na sijalice tog tipa... Ksenoni nisu za sada u planu... Share this post Link to post Share on other sites
neshtry 14875 Posted May 29, 2019 @Ivan ja sam postavio pitanje u temi "štelovanje farova" i cvrc. Zadnji post iz 2012. ... Poslato sa POT-LX1 uz pomoć Tapatoka Share this post Link to post Share on other sites
totti 13165 Posted May 29, 2019 Cisto drugarski savet za proveru, u cilju da masinica bude tip-top, nadam se da ne shvatas drugacije .Ja sam ovo shvatio kao da na suptilan način hoćeš da kažeš da mu je auto lomina Sent from my SM-G950F using Tapatalk 3 horvat, dekirs and Ivan reacted to this Share this post Link to post Share on other sites
Ivan 17680 Posted May 29, 2019 26 minutes ago, horvat said: Philips X-treme Vision sam mislio da probam. Identican izbor (navodnih +130%, 3700K, 450h). Mislio sam takodje da ih testiram (H1 su mi cak i prilicno povoljne), nego ove nikako da crknu od kako sam kupio auto . Nedavno sam uradio tehnicki, pa mi je padalo na pamet i da "munem" 4300K ksenon u fabricki projektor, sad su setovi bukvalno bagatela. A i mogao bih da iskoristim H1 sijalice ako bih radio konverziju na Morimoto Mini. Nisam pametan, bukvalno nista nisam modifikovao na autu za ovih godinu i kusur, cista fabrika. Jes' da ima lepu opremu, ali 99% je to upravo zbog zaje*ancije sa ovim novim propisima (kulminiralo mi je guljenjem Llumarki sa prethodnog Stila). Ne zna se ko koga je*e . 3 minutes ago, neshtry said: ja sam postavio pitanje u temi "štelovanje farova" i cvrc. Zadnji post iz 2012. ... Znam sigurno da sam ostavljao detaljno objasnjenje za Sporta u leto prosle godine, stelovanje maglenki nedavno... Pise se tamo? 2 minutes ago, totti said: Ja sam ovo shvatio kao da na suptilan način hoćeš da kažeš da mu je auto lomina Generacijo, zavadio bi i dva oka u glavi . Share this post Link to post Share on other sites
neshtry 14875 Posted May 29, 2019 @Ivan Piše za sporta, meni treba za Punta 2 i za glavni far Poslato sa POT-LX1 uz pomoć Tapatoka Share this post Link to post Share on other sites
danijel55 700 Posted May 29, 2019 12 hours ago, MS PK said: Extra! Na malom gasu odlicno, na vecem se cuje da je mali motor al jbg Послато са SM-J330F уз помоћ Тапатока Snimicu na sledećem skupu ako bude bio jedan decko sa stilom,lepo se cuje bas,1.9jtd u pitanju. 1 MS PK reacted to this Share this post Link to post Share on other sites
Ivan 17680 Posted May 29, 2019 1 hour ago, neshtry said: Piše za sporta, meni treba za Punta 2 i za glavni far Odgovorio sam ti na temi o stelovanju, bacio sam pogled i u eLearn pa sacni. Da ne offujemo kolegi predstavljanje vise. Share this post Link to post Share on other sites
horvat 6457 Posted May 29, 2019 Danas zamalo da nastrada Alfa... srecom nista nije bilo, bas nista ne mogu da vidim ni po laku cak... ni na svom ni na drugim autima sa parkinga firme... Sent from my iPhone using Tapatalk 1 neshtry reacted to this Share this post Link to post Share on other sites
neshtry 14875 Posted May 29, 2019 Kao sneg da je pao... Poslato sa POT-LX1 uz pomoć Tapatoka Share this post Link to post Share on other sites
horvat 6457 Posted May 29, 2019 Ta slika je na oko 2-3 km od firme gde radim Ali eto, nekim cudom se nije nista desilo autima, bas sam gledao i ostale, svi su 'nepovredjeni' Share this post Link to post Share on other sites
