Milutinac 5906 Posted November 9, 2022 @Ivan - ne ne ne, nije to, ali će biti i TO Ovo sada je nešto drugo, javljam se po tom pitanju samo kada završim... Quote Share this post Link to post Share on other sites
Ivan 17671 Posted November 9, 2022 6 hours ago, Milutinac said: Ovo sada je nešto drugo Poklopci retrovizora ? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2022 Nisu, mada videću sutra sa čovekom, nekad mi kroz glavu proleti kako bi bilo da su crni, ona varijanta da presijava vrišteće onako - - - - - - - - - - - - - - - - - - - - - Smontirano juce sve, meni je to ok... 4 Mijailović P., Reacher Gilt, horvat and 1 other reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted November 10, 2022 Čuj, "ok"....meni ovo odlično izgleda. 2 Reacher Gilt and Milutinac reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted November 10, 2022 Meni se isto svidja, specijalno sto su tako izvucene ka spolja, po obodu. 2 Milutinac and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted November 10, 2022 +1. Neću da kažem da mi se više dopada kako mu stoje ove nego one na kojima je letnji set, al' tako je. Znači, nisam to rek'o. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2022 Aaaaa ne ne ne, tu ne mogu da se složim - - - - - - - - - - - - - - - - - - - - - - - - - Nesto mi se bas svidja u ovoj black/white varijanti 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Ivan 17671 Posted November 10, 2022 5 hours ago, Milutinac said: Nisu, mada videću sutra sa čovekom, nekad mi kroz glavu proleti kako bi bilo da su crni Mo's se dzoramo sa poklopcima retrovizora . Ja tebi crne, ti meni sive. Ne znam samo da li ce pasovati sa traktora na kosacicu i obrnuto . 2 3 horvat, Milutinac, Reacher Gilt and 2 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 14, 2022 @Ivan - vi bih ste malo torka vidim ja - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Završena poseta folija-manu u petak i javljam se sa rezultatima Pošto u poslednje 3-4 godine jednom godišnje poliram farove i sredjujem, ovaj put sam rešio da ih (dosta) trajnije rešim. Jednostavno požute, koliko god se dobro ispolirali i zaštitili, bilo je i voska i keramike, desi se da posle 5-6 meseci naglo popuste...požute i bukvalno im svaki prolazak bilo kakve krpe napravi nekakve tragove E sad... Odradili smo poliranje... i onda bez ikakve zaštite otišli na folije Radi se o PPF foliji, najdebljoj koja može da ide na far, elastična je, ima dobar UV filter, i bitno...kada se zagreje, odnosno na suncu sama sebe može da popravi od oštećenja (ogrebotine i sl.), tj da se zaceli... Kako majstor kaže, nekih 5-7 godina ne bi trebalo da ima bukvalno nikakve promene... Bonus pikčr...ove felne koje ništa ne valjaju i jako su bljak bljak fuj, katastrofa bole me uči oćedispadnu bolje 15 sa ramtkapdnama da si stavio! 12 Reacher Gilt, silenci, skile86 and 9 others reacted to this Quote Share this post Link to post Share on other sites
Sedla 2576 Posted November 14, 2022 (edited) 2 hours ago, Milutinac said: @Ivan Bonus pikčr...ove felne koje ništa ne valjaju i jako su bljak bljak fuj, katastrofa bole me uči oćedispadnu bolje 15 sa ramtkapdnama da si stavio! Edited November 14, 2022 by Sedla 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted November 14, 2022 5 hours ago, Milutinac said: oćedispadnu bolje 15 sa ramtkapdnama da si stavio! Nemo sad da ti postavim sliku, još lagano zarđale Super su ispali farovi. Meni je levi požuteo ko na kevinom citrusu, u katastrofalnom je stanju, ne znam da l da pokušavam uopšte ili da pazarim nove negde ... Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted November 14, 2022 1 hour ago, Reacher Gilt said: da ti postavim sliku, još lagano zarđale Petnaje sa bez ratkapni, tj. Kake ratkapne, ratkapne su za devojčice ... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 15, 2022 14 hours ago, Reacher Gilt said: ne znam da l da pokušavam uopšte ili da pazarim nove negde ... Probaj, može da se desi da ti potraje i duže. Probaj prvo sa voskom kao zaštitiom... 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted November 15, 2022 Pa ne može da škodi ako pokušam, mada ne verujem iskreno ... Desni je u principu OK, ne mora da se dira još, ali levi je katastrofa. Probaću, gore od ovog ne može biti. 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Ivan 17671 Posted November 15, 2022 2 hours ago, Reacher Gilt said: Pa ne može da škodi ako pokušam, mada ne verujem iskreno Zasto ne bi probao, pogotovo ako je far vec los? Nemas sta da izgubis. Imas onaj Sonax set za oko 1600 kinti, sa kojim mogu da se urade 2 kompleta farova (znaci sredjivanje para farova te izadje 800 kinti i malo dobre volje). Turtle Wax je oko 1000 i kusur skuplji i sa vise komponenti - ali neke potrosis do kraja, a nekih ostane, tako da je u principu samo za jedan par farova. Evo kako je ispalo kod mene sa TW, sve sam uradio sam naravno, mada posle godinu i po primecujem da krece pomalo da zucka i popusta, iako je premazano keramikom: On 5/12/2021 at 9:11 PM, Ivan said: Farovi se sa TW suse 24h (sa Sonax par sati), kada se sve "zapeklo" i ocistilo izgleda ovako: I na kraju, meni najbitnije - funkcionalnost. Fotke sa upaljenim 4300K ksenonima, gde se vidi kako je staklo lepo ocisceno. Na nocnoj slici sam efektima pokusao da "ubijem" jacinu ksenon sijalice (vidi se po ubodnoj poziciji sa vlaknom) - kako bi se lepo videlo kako je staklo bez riseva i tackica: 2 silenci and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Axic 20048 Posted November 15, 2022 On 11/14/2022 at 6:05 PM, Reacher Gilt said: Super su ispali farovi Nisu bre ispali, vidis da stoje onako sjajni na svom mestu gde i treba da budu. 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 23, 2023 (edited) Mali upgrade...čisto da se nešto radi, planira i šrafi Papučice su sa Giuliette, smeta malo onaj logo...ne? Idu na pranje, poliranje pa moMtiranje, ima malo šrafljenja i turpijanja, ali bude fino kad se namesti Edited February 23, 2023 by Milutinac 5 Ivan, PremieRacing, horvat and 2 others reacted to this Quote Share this post Link to post Share on other sites
igor0511 2882 Posted February 23, 2023 Ma sto bi smetao, bas ce lepo da legne Quote Share this post Link to post Share on other sites
horvat 6456 Posted February 23, 2023 12 minutes ago, Milutinac said: smeta malo onaj logo...ne? Ako si vozac, a ne sofer, to ces da svakako da olizes brzo hehehe 2 Milutinac and Axic reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 23, 2023 Ma ici ce dole svakako, mora sve lepo da se predje onim skočkom (Scotch brite)...i onda se lepo dobije ovo-ovako Drugarov set, bile su u istom stanju kao moje... 5 igor0511, radomir.g, Dzimbo and 2 others reacted to this Quote Share this post Link to post Share on other sites
igor0511 2882 Posted February 23, 2023 Oba Delta je brutalna, ali menjac je kao piletu (.^.) 3 3 darkman14, Axic, PremieRacing and 3 others reacted to this Quote Share this post Link to post Share on other sites
Ivan 17671 Posted February 23, 2023 (edited) 1 hour ago, Milutinac said: ima malo šrafljenja i turpijanja Kod mene sam samo jednom iz zaje*ancije skinuo alu-papucicu kvacila, a trebalo bi da su sve 3 papucice na navlacenje (za razliku od onih pre restyle gde su sve 3 bile na srafljenje): Odmoriste za nogu (ili kako ga neki zovu nogostop ) ima 3 srafcica i to bi trebalo da je jedino srafljenje celog seta. Kakva je procedura sa tim Skočkom , necim se jos polira ili kako? Mogao bih ove svoje malo da uglancam cisto iz dosade, mada su u skroz OK stanju: PS: Ta verzija papucica i odmorista za restyle Bravo i Giuliettu (koju si i ti pazario) daleko mi lepse izgleda nego one starije alu-papucice pre restyle: Edited February 23, 2023 by Ivan Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 23, 2023 1 minute ago, Ivan said: Kod mene sam samo jednom iz zaje*ancije skinuo alu-papucicu kvacila, a trebalo bi da su sve 3 papucice na navlacenje (za razliku od onih pre restyle gde su sve 3 bile na srafljenje): Greska! Sva sreca u moju korist dva druga su stavljali iste papucice na delte, i tamo je kvacilo i kocnica sire, i imali su turpijanja. Medjutim, upravo sam saznao da bravo ima uze i potpuno su iste kao na Giu...tako da proces ide ovako... -Pranje -Poliranje -Montaza -Vid sto je ljepo -Kraj 8.3cm x 5cm na bravu, kod Delte malo sire... Ovo... ...drug kaze da je dobio samo skočkom. Tako da ću prvo tako odraditi, ako je potrebno malo paste, pozajmicemo od Zdrnje 2 1 Reacher Gilt, Ivan and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Ivan 17671 Posted February 23, 2023 (edited) 9 minutes ago, Milutinac said: -Montaza -Vid sto je ljepo -Kraj Ako smo se dobro razumeli - upravo to i rekoh . Plug&Play (za razliku od onih pre restyle), samo se odmoriste srafi sa 3 srafa. PS: Davno sam nesto gledao, samo ovo odmoriste, i to bez te gume ispod, bilo je kod ovlascenih reda velicine 80-90 EUR . Ne ide zajedno u setu papucica, nego bese ide kao deo poda u Sport opremi. Edited February 23, 2023 by Ivan Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted February 23, 2023 Da, bezobrazna je cena tog odmorista za nogu. Quote Share this post Link to post Share on other sites
