PremieRacing 5318 Posted November 13, 2023 (edited) On 11/11/2023 at 5:51 PM, Milutinac said: Epilog je - 182ks i oko 430Nm Sta sam trazio - to sam i dobio ... izricit sam bio da zelim blagi tuning. Pi*ko! Edited November 13, 2023 by PremieRacing 4 Vule, Milutinac, nemanja84bg and 1 other reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted November 13, 2023 To je ono...do pola samo... Sent from my SM-S901B using Tapatalk 2 5 Axic, horvat, knezevic76 and 4 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 13, 2023 Hahaha, ma ajde sta vam je, stiže sutra turbo sa 2.4 Šalim se, a nisam ja toliko bio zagrejan za taj remap chipa, i onda iz toga...tako...nekako - to je to što se mene tiče, malo čačnuta fabrička varijanta bez nekih glavobolja i razmišljanja, ali ipak mnogo zanimljivije za vožnju... živnuo je nekako i imam utisak da sam ga uklopio sada sa kočnicama, vešanjem, gumama itd. 2 PremieRacing and nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 13, 2023 2 hours ago, Bingodalton said: To je ono...do pola samo... Sad ću da te čipujem, al' samo ću da ga prislonim. Nećeš ništa da osetiš! 2 6 nemanja84bg, darkman14, Bingodalton and 5 others reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1311 Posted November 13, 2023 Dobro je nasviran ... pa poleteces covece 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted November 13, 2023 1 hour ago, Milutinac said: Šalim se, a nisam ja toliko bio zagrejan za taj remap chipa, i onda iz toga...tako...nekako - to je to što se mene tiče, malo čačnuta fabrička varijanta bez nekih glavobolja i razmišljanja Da radim, verovatno bih identicno tako postupio. Stvar koja mi je bas isla na *** kod MultiJet, kada sam ih razmatrao tamo pre 6-7 godina, a posle 1.9 motora. Polumrtvi do 2200-2300 rpm pa odatle rokaju . Da mi je cak (doduse samo subjektivno) delovalo da MA benzinac u Sport modu bolje cupa iz tih niskih obrtaja. Konkretno na Bravu. Ono sto sam hteo da priupitam - je li kod dizelasa bese bar Sport 2.0 imao "dugmence umesto City servo" ? Kao Sport T-Jet 150 i MA benzinci? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 13, 2023 47 minutes ago, PremieRacing said: Sad ću da te čipujem, al' samo ću da ga prislonim. Nećeš ništa da osetiš! JOS UVEK NEVIN! Nista se nije desilo majke mi! 2 minutes ago, Ivan said: Ono sto sam hteo da priupitam - je li kod dizelasa bese bar Sport 2.0 imao "dugmence umesto City servo" ? Kao Sport T-Jet 150 i MA benzinci? Jeste jeste, ali konkretno kako i koliko je to uticalo na NM - stvarno ne znam...sad je u sport modu kako god okrenes 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted November 13, 2023 (edited) Imam onaj kompletan servisni kurs za njihove motore, ali iskreno nisam gledao za dizele. Kod mog bivseg MultiAir je dodavalo oko 30 Nm, tj. sa 230 na oko 260 Nm (uz gasenje servo asistencije i reskiji odziv na gas). Kod dizela pretpostavljam da je to vise. Znam i da su se na nekim verzijama MultiJet dijagnostikom igrali sa onim rucnim menjanjem bitova u Bodiju. Pa dugmence za City Servo postane Sport dugme . Ali se ne secam da li se onda na njegovo aktiviranje menja sve isto kao i u OEM varijanti. Edited November 13, 2023 by Ivan Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 13, 2023 Ja da sam hteo da radim remap City tastera - ja bih ga vec odradio Quote Share this post Link to post Share on other sites
Ivan 17680 Posted November 13, 2023 (edited) Ma cisto komentarisem kako su dodavali malo snage, za dzabe . A ne da kazem da nisi trebao, daleko bilo. Sad je to responzivnije kako treba i iz nizih obrtaja. A i zivo zanima me sta bi se sada desilo ako bi remapirao i dugme . Kako bese kod tebe oko DPF, ostavio si ga zivog ili ne? Razmisljam sta da radim po tom pitanju, posto ga ocekivano ubija BG lokal i guzva. Pa ako ne idem na put neko vreme, radim ono sto sam uvek pricao da najvise mrzim - slusam muziku do Aerodroma ili Ugrinovaca i nazad, u 4. brzini . Na plasticnim poluproizvodima znas da to malo drugacije funkcionise, Eolys aditiv itd. Edited November 13, 2023 by Ivan 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 13, 2023 (edited) DPF je umro, davali smo mu 5 godina prosli mesec To je manje - više prvo pitanje koje ti tuner postavi... Kada je DPF tu - izmedju ostalog dolazi do potencijalnih problema oko EGT (Exhaust Gas Temp.), a to nikako ne bih voleo. Kod mene je, makar smatram, bila čista situacija, nema DPF-a, klapne su tu, rade, nista nije pogaseno a da ne prikazuje gresku itd. Turbo ok, dizne, MAF dobar, MAP senzor vecito cist i bez ikakvih naslaga. Dima i pre nisam imao...itd Seo je prvo covek, provozao ga i pre valjaka, i kaze "Dobro je ovo..." Edited November 13, 2023 by Milutinac 2 1 PremieRacing, alfini0507 and horvat reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted December 11, 2023 Dokon pop i jarice krsti... Nisam bas dokon bio, ali sam odavno hteo da se upustim u ovu operaciju, negde sam procitao da moze i da je izvodljivo, pa rekoh da vidimo... 2 sata posla da se sve raspakuje i dodje do ovogа. Pritome mislim da cu drugo uraditi dosta brze, ovde je trebalo malo vremena dok skontam gde sta ide, ged se sta kaci itd. Naravno da može dubinsko da se odradi, i radio sam, ali ni to nije uspelo da izvuce fleke od morske soli npr. Ubačeno sve u mašinu - i sada je kao novo, skroz cisto i mirisljavo Inače - FIAT svaka čast, sedište je vrhunsko, tkanina 10 slojeva nekih, čvrsto, zategnuto, sundjer odličan, rešenja kako šta i gde kači i zateže - svaka čast... E evo ga posle pranja i sklapanja Sve zategnuto i sve na svom mestu kao i pre. Sledeći vikend idemo na drugo sedište... I jedna vikend bonus pikčr 14 city, Ivan, knezevic76 and 11 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 11, 2023 Svaka tebi čast...gde su bili ukućani dok si ovo radio? Nema šanse da su bili kući i da si završio... 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
Vule 795 Posted December 11, 2023 Sve je dobro dok ne staviš felne u sudomašinu kad žena nije kući! 1 5 Sedla, city, ISV_01 and 3 others reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted December 11, 2023 8 minutes ago, PremieRacing said: Svaka tebi čast...gde su bili ukućani dok si ovo radio? Nema šanse da su bili kući i da si završio... Vrlo dobro zapažanje moj Borkoviću Ekipa je bila kod tašte preko vikenda, i ja sam onda mogao da se razmašem propisno 1 minute ago, Vule said: Sve je dobro dok ne staviš felne u sudomašinu kad žena nije kući! A znas kako...vidis onaj meme na netu i pomislis, ma cekaj ovo je skroz izvodljivo... Onda odes do ostave, doneses felnu i skontas da bi lagano stala u masinu od 60cm, a ti imas onu od 45 nazalost. Onda kazes svemujebem, moramo skracivati element za 15cm i kupovati vecu masinu, ali sto da ne... 2 5 Sedla, Vule, Reacher Gilt and 4 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 11, 2023 Pa naravno, to je 'one time investment' Nećeš valjda stalno da kupuješ wheel cleaner-e i da trljaš ručno?!? Quote Share this post Link to post Share on other sites
horvat 6457 Posted December 11, 2023 3 hours ago, Milutinac said: Ubačeno sve u mašinu - i sada je kao novo, skroz cisto i mirisljavo Next step - pranje tepiha Svaka cast. Moram i ja da resavam sedista, al ne znam jos za koji pristup da se opredelim... 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
igor0511 2882 Posted December 11, 2023 Bas lepo sredjeno Mogao si da ubacis i grejace kad si sve vec raskupusao 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Vule 795 Posted December 11, 2023 3 hours ago, Milutinac said: a ti imas onu od 45 nazalost Imam, nažalost A nema ni mesta za širu 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted December 12, 2023 (edited) 19 hours ago, igor0511 said: Bas lepo sredjeno Mogao si da ubacis i grejace kad si sve vec raskupusao Razmisljao sam u tom pravcu. I raspitivao se malo i problem je struja...tj odakle dovuci struju za to, nije bas da moze sa upaljaca da se izvuce... Izgleda da bih morao kupusati sve do panela sa osiguracima ispod haube. Tako da sam...makar za sada...ostavio to po strani. Ako nadjem neko lakse a sigurno resenje - lako cu ja raskupusati donji deo sedista... Edited December 12, 2023 by Milutinac 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted December 12, 2023 Ta sport sedista na slikama uvek deluju lose i prljavo, ko ne zna ne mozes da ga ubedis da nije tako uzivo Sedista sam rasturao kad sam pakovao vozacevo zbog pocepane bocne strane, ok je, nije nesto komplikovano. Za vreme zakljucavanja u momentima dosade sam izvadio i oprao tepih, e to ti vec savetujem da ne radis. Prvo zbog toga sto je ( na stilu makar) zalepljen za izolaciju kod vozaca i suvozaca, zato i stoji onako lepo zategnut, drugo , sto je iz jednog dela ispod table pa bi morao da ga seces.Послато са SM-A307FN помоћу Тапатока 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Ivan 17680 Posted December 12, 2023 On 12/11/2023 at 9:46 AM, Milutinac said: Naftarica u svom prirodnom okruzenju, nice . Bas lep upgrade, jos sporCka crvena verzija. Ovo je Vogel&Noot nadogradnja? 4 7 MS PK, alfini0507, Axic and 8 others reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted December 29, 2023 (edited) On 12/11/2023 at 9:46 AM, Milutinac said: Dokon pop i jarice krsti... Nisam bas dokon bio, ali sam odavno hteo da se upustim u ovu operaciju, negde sam procitao da moze i da je izvodljivo, pa rekoh da vidimo... 2 sata posla da se sve raspakuje i dodje do ovogа. Pritome mislim da cu drugo uraditi dosta brze, ovde je trebalo malo vremena dok skontam gde sta ide, ged se sta kaci itd. Naravno da može dubinsko da se odradi, i radio sam, ali ni to nije uspelo da izvuce fleke od morske soli npr. Ima li neko uputstvo za ovaj poduhvat i dal može da se skine tapacirung bez vađenja sedišta iz auta? Edited December 29, 2023 by Ivan Skinut nepotreban citat Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted December 29, 2023 @knezevic76 - nema sanse, obrtao sam sediste na sve moguce nacine, mozda i najvise bude okrenuto skroz naopako, da naslon za glavu bude dole ali skinuti sediste je najlaksi deo posla, drze ga 4 zvezdasta srafa i treba da se otkaci pojas, i to je to, sediste moze napolje... Ako resis da radis, javi, napisacu ti uputstvo korak-po-korak, generalno ovo uzme najvise vremena To su kopče, kao neke alke, i to je najpipaviji deo posla jer moras da kopču guraš od nazad, da stisneš sundjer i da u alku ubaciš žicu koja se nalazi u tkanini, pa dok ne klikne u alku... Sve ostalo je klasično, zategni, namesti itd. Skida se i airbag sa strane, mora da se skine tj. Drze ga 2 srafa 10-ke, struja mora da se skine i malo je pipavo, trebaju tanke ruke. 2 horvat and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
knezevic76 7020 Posted December 29, 2023 Hvala buraz, ovo što si napisao je skroz dovoljno da sklopim sliku Sent from my SM-A546E using Tapatalk 2 Milutinac and MS PK reacted to this Quote Share this post Link to post Share on other sites
