neshaoct 9592 Posted January 28, 2016 Barem sam brži od Lagune... Quote Share this post Link to post Share on other sites
totti 13165 Posted January 28, 2016 Pa kad nemaš OO da se kačiš sa pravim Quote Share this post Link to post Share on other sites
MS PK 7735 Posted January 28, 2016 Pfff pa normalno da si brzi od lagune i takav Quote Share this post Link to post Share on other sites
Sedla 2576 Posted January 28, 2016 Jok, lažu za 50 kako bih imao kao JTD, i to onaj najslabiji. Nemoj biti toliko surov prema sebi. Quote Share this post Link to post Share on other sites
Ivan-Topola 329 Posted January 29, 2016 Sta mi je sa Stilisom??? Aleksaaaaa!!!! Ako Aleksa ode na merenje,samo zbog onog priveska sto ima,pokazace 150ks! Quote Share this post Link to post Share on other sites
Ticma 537 Posted January 29, 2016 Bilo bi lepo da bude posle 15-tog neki termin Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted January 29, 2016 slazem se sa Ticmom Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted February 15, 2016 trebalo bi da nadjemo jos 3-4 ljudi, da imamo na kraju sigurnih 11 jer se uvek desi da neki ljudi otkazu.. i da se dogovorimo oko termina Quote Share this post Link to post Share on other sites
polaris 7 Posted February 16, 2016 Jel moze auto izvan Fiat grupacije ili ? Quote Share this post Link to post Share on other sites
joshibeast 74 Posted February 16, 2016 (edited) Može naravno.Bio je prošli put Tićma sa Hondom.Ali i Neša sa Stilom Edited February 16, 2016 by joshibeast Quote Share this post Link to post Share on other sites
polaris 7 Posted February 16, 2016 1. Danilo 2. Dellas3. Joshibeast4. Dovla5. Sulc6. Sedla7. munRu8. Ticma9. Sava9210. Sunjalo 8211.polaris Bi;o bi dobro,ako se moze iskombinovati posle 17h jer dotle radim,ali ako ne moze,Boze moj sta da se radi. Quote Share this post Link to post Share on other sites
joshibeast 74 Posted February 16, 2016 Ide se oko 12.Novaspeed ne radi subotom toliko kasno. Quote Share this post Link to post Share on other sites
polaris 7 Posted February 16, 2016 Nadam se da cu uspeti da uzmem slobodan dan,samo da se javi par dana u napred kad je da mogu poslodavcu da kazem. Quote Share this post Link to post Share on other sites
Ticma 537 Posted February 16, 2016 Nesha ko da nije ni bio, nije ni zavrteo valjke Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted February 28, 2016 ima li kakvih novosti oko termina? Quote Share this post Link to post Share on other sites
VladaRS4 6 Posted March 15, 2016 Pozz drugari... gde idete na merenje? Ja planiram sa drugarovim yugom ali mi je najblizi Zrenjanin i dal neko ima iskustva? Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted March 15, 2016 Sta ces se muciti, ima 45-50ks Ima valjda Novo Milosevo kao najblize i najjeftinije. Quote Share this post Link to post Share on other sites
dellas 1556 Posted April 6, 2016 Ljudi hocemo li se skupiti? Quote Share this post Link to post Share on other sites
jevta BG 111 Posted April 12, 2016 Ja sam za... Sad sam video temu...posto trebam da radim mapu taman mi treba pre i posle, a svakako cu kod njih sve da radim... Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted April 12, 2016 Kad vec pisemo o merenju...video sam nedavno da Safe Chip nudi sada i merenje snage, imaju neki dyno na kom to moze da se odradi i valjda je u Novom Sadu. Pise da odmah pored imaju servis, pa pretpostavljam da je tu. 20 EUR je 30 minuta / 3 merenja. Da li neko iz NS ima iskustva sa njihovim valjcima i da li je neko od novosadjana zainteresovan za merenje? Quote Share this post Link to post Share on other sites
zalik 15 Posted April 22, 2016 Imam ja iskustvo sa tim valjcima,moja 2 auta se vrtila na tim valjcima 10 puta ,solidni jako valjci i precizni,radjen i hybrid varijanta stage 3 na njima,bili su u zrenjaninu a pre toga kod Sase u Revochipu godinama vrtili...on je kupio Bapro 4wd i njih prodao,pitanje je samo kako su i da li su ih novi vlasnici kalibrisali nakon toliko godina rada i servisirali Quote Share this post Link to post Share on other sites
marko.jovanovic 925 Posted April 22, 2016 Da nisu to slučajno valjci gde Grande Krnto od Vagenovca baca cca 250ks a u stvari ima cca 200ks? Quote Share this post Link to post Share on other sites
zalik 15 Posted April 22, 2016 ne znam sta ''punto grande kante pune vode'' ili izrazi se kako vec zelis, znam taj dyno odlicno Serp dyno turska proizvodnja ... Pre dve godine je bio tacan jer sam isti auto mjerio na maha dyno ovde u austriji bas zbog tih prica mada je maha jako los uredjaj. Vrhunski dyno testeri su Superflow Dynostar Cartec Dimsport Bapro medju vodecim sve ostalo manje vise kukuruzna sasa... Sta se desilo sa tim valjcima u medjuvremenu pojma nemam, sad je vlasnik Dejan Safechip Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted May 27, 2017 Dostigao 530 konja i pukao Pogledajte kako je B16 motor u Hondi Civic EG, prerađen na turbo dao sve od sebe na valjcima i onda ''digao ruke''...! Ljubitelji Hondi i njihovih fantastičnih atmosferskih motora znaju da je jedini način da zaista izvučete značajniju snagu iz motora da se okrenete natpunjenju, bilo mehaničkom kompresoru ili turbo punjaču. A tako nešto zahteva i ozbiljnije prerade samog agregata. Evo jednog slučaja kada je Honda Civic EG sa B16 motorom ostvarila 531 konjsku snagu na valjcima, pri pritisku punjenja od oko 0.76 bara, pre nego što se motor razleteo. Tačnije, raspalo se crevo rashladne tečnosti, ali su pukle i dve ''košuljice''. Quote Share this post Link to post Share on other sites
