PremieRacing 5318 Posted November 7, 2017 On 6.11.2017. at 7:18 PM, Sulc said: 1. Dellas 2. skile86 3. marko.jovanovic 4. vvarnica 5. PremieRacing 6. Dragan 7. voodoons 8. Koska 9. Sulc . . . . . Hajde da se skupimo, da nas bude što više je moguće za dobro druženje i da merimo... Upisujte se! On 31.10.2015. at 9:15 PM, cocolo said: 3000 din je merenje po automobilu 2000 din je od 5 do 10 automobila 1500 din je preko 10 automobila Nadam se da ovaj cenovnik još uvek važi, da planiramo... pa ne mora ni preko 10 da nas bude. 5 i više je Quote Share this post Link to post Share on other sites
voodoons 349 Posted November 7, 2017 Ajde da ga merimo Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
radomir.g 334 Posted November 7, 2017 Novaspeed bas voli da odvrne taj momenat.. Kod mene je rezultat dao +70nm, ali se kasnije utvrdilo da je torque limiter bio stavljen na 1000nm (citaj limit off) i turbo vec na 2000 obrtaja na 2.6 bara. Koliko je zdravo zakljucite sami. 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
FantomX 5 Posted November 7, 2017 Culi ljudi za tork limiter, mos' misliti koliko je on bitan u celoj prici... Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 7, 2017 Idemo da se družimo i da usput izmerimo automobile... aj' to skretanje sa teme ostavite za drugi put. Bez namere da vas nerviram, samo pišate po temi. Quote Share this post Link to post Share on other sites
FantomX 5 Posted November 7, 2017 Ma ja ga merio vise puta, uzivajte, mozda svratim da vidim kako bljujete dizel 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted November 13, 2017 Ljudi, moze li sledeca subota? Ima li jos neko da moze da zaokruzimo na 10 i da zovemo ljude da to zakazujemo... Quote Share this post Link to post Share on other sites
Sedla 2576 Posted November 13, 2017 Ja sam zainteresovan, ali na zalost naredne dve subote ne mogu... Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 13, 2017 (edited) 3 hours ago, dellas said: Ljudi, moze li sledeca subota? Ima li jos neko da moze da zaokruzimo na 10 i da zovemo ljude da to zakazujemo... Moze!!! Zovi, zakazuj, pa ko se pojavi... Dosta je i preko 5 a daj Boze da bude 10+ Pod "sledeca subota" nadam se da mislimo i dogovaramo 18.11. Edited November 13, 2017 by PremieRacing Quote Share this post Link to post Share on other sites
dellas 1556 Posted November 13, 2017 Mislio sam na subotu nakon ove, 25.11. Ajde pozvacu ih, pa javljam sta su rekli. Quote Share this post Link to post Share on other sites
Koska 2 Posted November 16, 2017 Ja odustajem od merenja, krlja mi nešto čim stisnem gas ali bih se verovatno pojavio u svakom slučaju jer hoću da se posavetujem sa Milošem koji tamo radi. Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 16, 2017 Dellas, sta se desava...? Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 17, 2017 (edited) Ništa... ja sam sutra u BG, svratim malo do Baneta BB i čekam info za merenje. Pa ako bude, spreman sam! Ako ne, više sreće sledeći put. Ili sledeću subotu Edited November 17, 2017 by PremieRacing Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 30, 2017 Prođe i subota 25.11... Hoćemo li se org. ili jok?! Quote Share this post Link to post Share on other sites
dellas 1556 Posted November 30, 2017 Kontaktirao sam ih, javice mi do kraja dana kada oni mogu i koja je cena. Opcije su najverovatnije ova subota ili sledeca, ajmo ko je za ovu ko za sledecu pa da resimo i to? Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 30, 2017 +1 Quote Share this post Link to post Share on other sites
DraganUS 450 Posted November 30, 2017 Samo sledeca mogu. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
voodoons 349 Posted November 30, 2017 Dodzmeni umro auto, kod majstora je pa ne mogu dok se ne resi..Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
DraganUS 450 Posted November 30, 2017 Ajd sad jedno konstruktivno pitanje. Jel neko video automatica kod njih na dyno-u? Iskreno bojim se da mi ne sjebe menjac ak ne zna da uradi dyno na automatiku. Quote Share this post Link to post Share on other sites
voodoons 349 Posted November 30, 2017 Zašto bi se sjebao menjač?Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
DraganUS 450 Posted November 30, 2017 (edited) Vecina njih radi pull u 3 ili 4 brzini dok kod mene mislim da on sam salte kad dodje u visoke obrtaje u zavisnosti od load-a u vecu brzinu bilo da si u auto ili manual modu. E sad, mislim da u drugoj brzini kad je u manual modu ne salta preko, tako da ako radi pull u drugoj u manual modu, kad zavrsi sa rpm bandom dok ga prebacu u auto mod pa u N on ce sam da isalta u 5 brzinu bez jebemti. E sad, koliko su nasi valjci verodostojni za pull u drugoj brzini. Edited November 30, 2017 by DraganUS Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 1, 2017 (edited) I da sam hteo, nisam te razumeo Ja sam kod Dejana u SCT merio automatika bez ikakvih problema... Može to. Naravno, postoje razlike u menjačima i njihovom načinu rada ali mislim da i kod mene šalta sam kad pipne crveno. Nisam siguran... Sve u svemu, onaj ko se time bavi sigurno zna šta treba. (ili grešim ) Edited December 1, 2017 by PremieRacing Quote Share this post Link to post Share on other sites
voodoons 349 Posted December 1, 2017 Vecina njih radi pull u 3 ili 4 brzini dok kod mene mislim da on sam salte kad dodje u visoke obrtaje u zavisnosti od load-a u vecu brzinu bilo da si u auto ili manual modu. E sad, mislim da u drugoj brzini kad je u manual modu ne salta preko, tako da ako radi pull u drugoj u manual modu, kad zavrsi sa rpm bandom dok ga prebacu u auto mod pa u N on ce sam da isalta u 5 brzinu bez jebemti. E sad, koliko su nasi valjci verodostojni za pull u drugoj brzini.Nema mod za sekvencijalno menjanje brzina? Mada moj DSG sam prebaci i u tom modu kad dođe u crveno..Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
CrackFox 16 Posted December 1, 2017 2 hours ago, PremieRacing said: "Ja sam kod Dejana u SCT merio ..." Jesi zadovoljan uslugom i generalno odradjenim poslom u SCT kod Dejana? Quote Share this post Link to post Share on other sites
dekirs 4819 Posted December 1, 2017 Taj covek ne zna ni EGR da ugasi, a ne da cipuje auto.. Quote Share this post Link to post Share on other sites
