vvarnica 2 Posted December 8, 2017 1. Dellas 2. Dragan 3. Cane 4. Ivan Led masters 5. PremieRacing 6. vvarnica Koja tacno OMV pumpa ima ih dve, prva ili druga posle pancevca? Quote Share this post Link to post Share on other sites
vvarnica 2 Posted December 8, 2017 Ok vidmo se tamo u pola dvanaest, plavi stilo. Quote Share this post Link to post Share on other sites
PremieRacing 6311 Posted December 8, 2017 Bravo! Eto, 'jedva se zbrasmo' ekipa ide da ga meri... Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 8, 2017 1. Dellas2. Dragan3. Cane4. Ivan Led masters5. PremieRacing6. vvarnica7. Vlada ( Bravo 20VT)Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
voodoons 355 Posted December 8, 2017 Meni tek sutra stižu nove dizne, biće montirane ali ne smem par dana nigde da se upuštam dok ne utvrdim da je sve ok i da auto radi kako Bog zapoveda.. a došao bih rado iako ovde u NS ima da se odradi merenje za 20€ kako su mi rekli...Sent from my iPhone using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
dellas 1779 Posted December 8, 2017 Dobra ekipa se skupila Quote Share this post Link to post Share on other sites
PremieRacing 6311 Posted December 8, 2017 Eto, a brinuo si Quote Share this post Link to post Share on other sites
danijel55 902 Posted December 8, 2017 Obavezno sutra rezultate da javite Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 8, 2017 Pre ce biti razocarenja nego rezultate. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
danijel55 902 Posted December 8, 2017 Ma nece.Svi koji su ovde odrzavaju svoja vozila,a i ako ide losije nego kao sto je isao kad je kupljen odma se resava problem.Jos vasi automobili,totalni respect. Quote Share this post Link to post Share on other sites
cane 225 Posted December 9, 2017 Ja letos kupio auto, cini mi se da je zdrav, nego se ostrim za chip pa reko da proverim pocetno stanjeSent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
dellas 1779 Posted December 9, 2017 Ista prica,ja kapiram da je na fabrickoj snazi sad ali videcemo. Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 9, 2017 Mene moze samo da sjebe EGR jer nije zatvoren ali je u funkciji kako treba nadam se. Sad videcemo. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
dellas 1779 Posted December 9, 2017 Ja stizem u 15 do 12 na pumpu, vidimo se. Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 9, 2017 Stigao na pumpu. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 9, 2017 Ne bas idealni uslovi za merenje. Hladne mokre gume, itd. Bacicu video kad dodjem kuci. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
Rile_bg 373 Posted December 9, 2017 Ista prica i ovde. Quote Share this post Link to post Share on other sites
YUgisa 3215 Posted December 9, 2017 (edited) A da probate da burnout umesto izgovora? Komentar je humoristicnog karaktera, svaka slicnost sa stvarnim licnostima je slucajna. Edited December 9, 2017 by YUgisa Quote Share this post Link to post Share on other sites
Bingodalton 904 Posted December 9, 2017 Aj kad okacite merenje da napisete i koji je auto u pitanju, fabricka snaga i eventualno obecana remapirana snaga, ako je to radjeno.Sent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
dellas 1779 Posted December 9, 2017 (edited) 320d 110kw 143hp 318nm Taman za chip. Jel hoce jos neko da radi osim nas trojice? Dobicemo neki popust zbog merenja. Edited December 9, 2017 by dellas Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 9, 2017 Kod mene je Croma 2.4 200ps 400nm. Fabrika bez DPFa, bez klapni. Sve ostalo u funkciji. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
Bingodalton 904 Posted December 9, 2017 Kod mene je Croma 2.4 200ps 400nm. Fabrika bez DPFa, bez klapni. Sve ostalo u funkciji. Sent from my SM-J710F using Tapatalk Kod tebe neki konji pobegli u obrtni momenat Verovatno geometrija glavi malo. Sent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 9, 2017 Sent from my SM-J710F using TapatalkKod tebe neki konji pobegli u obrtni momenat Verovatno geometrija glavi malo. Sent from my SM-A510F using Tapatalk Mislim da nine koeficijent potrefio kako treba ili sta vec ide. Realno tesko da ce izbaciti 30nm vise tek tako. Kad dodjem kuci bacicu pogled na dyno fabricki i uporediti. Sent from my SM-J710F using Tapatalk Quote Share this post Link to post Share on other sites
vagenovac 4928 Posted December 9, 2017 To je normalno za 2.4mjet, obicno izbaci manje ks, vise nm, ko zna kako zasto, ali uobicajena pojava sve i sa dpf i kada je mlad auto sa niskom km. Zato u praksi, a i deklarisano ne ubrzava znacajno bolje od 2.0mjet pri punom gasu, ali zato cupa i lepi sa niskih rpm. Quote Share this post Link to post Share on other sites
