zalik 15 Posted December 9, 2017 24 minutes ago, DraganUS said: Sent from my SM-J710F using Tapatalk Mislim da nine koeficijent potrefio kako treba ili sta vec ide. Realno tesko da ce izbaciti 30nm vise tek tako. Kad dodjem kuci bacicu pogled na dyno fabricki i uporediti. Sent from my SM-J710F using Tapatalk trebas da vidis prvo stanje mapa mafa korekciju dizni!!!!!!!parametre zadati ostvareni pritisak turba u stocku,onda dalje ....lagano ako hoces to da skockas kako treba,jesi zatvorio agr fizicki?(mislim i softwerski?) Quote Share this post Link to post Share on other sites
dellas 1556 Posted December 9, 2017 Ne znam jel ubacio dobre korekcije i slicno, ja sad gledam na netu, po nekim kalkulatorima bih trebao da imam ravno 150hp. Tacnije na tocku mi je izbacio 122hp sto mu dodje 150 po tim nekim kalkulatorima, ali valjda oni znaju bolje na valjcima. Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted December 9, 2017 (edited) meni se uopste nije svidelo kako to preracunavaju,nesto steluju i sl. nasao sam ovo za svoj auto, tako da se poklapa sa rezultatima http://rototest-research.eu/popup/performancegraphs.php?ChartsID=528 72Ks i 107Nm na tocku. Edited December 9, 2017 by Rile_bg Quote Share this post Link to post Share on other sites
dellas 1556 Posted December 9, 2017 Po ovom tvom ja bih imao jos manje.... Ja sam ovde gledao, ubacio RWD manuelni menjac i snagu sa tocka tj 122 i dobio 150 okruglo. https://www.mk5cortinaestate.co.uk/calculator4.php Quote Share this post Link to post Share on other sites
zalik 15 Posted December 9, 2017 novaspeed i valjci....gde radjena kalibracija tog uredjaja? Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted December 9, 2017 @dellas meni je izbacio 63-4ks na tocku,sto mu dodje po ovom tvom programu ravno sto ti kazes 80ks xD Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted December 9, 2017 @PremieRacing - sta si ti merio i koliko ks? Da vidimo cisto ima li razlike nova vs. Safetovi valjKci... Quote Share this post Link to post Share on other sites
zalik 15 Posted December 9, 2017 safetovi valjci su ok!!!!servisirani kalibrisani,za razliku od traktorskog perpetomobila iz nove Quote Share this post Link to post Share on other sites
DraganUS 450 Posted December 9, 2017 2 hours ago, vagenovac said: To je normalno za 2.4mjet, obicno izbaci manje ks, vise nm, ko zna kako zasto, ali uobicajena pojava sve i sa dpf i kada je mlad auto sa niskom km. Zato u praksi, a i deklarisano ne ubrzava znacajno bolje od 2.0mjet pri punom gasu, ali zato cupa i lepi sa niskih rpm. Izgleda da jeste. Sad sam bas nasao stock vs tunned kod poljaka. 2 hours ago, zalik said: trebas da vidis prvo stanje mapa mafa korekciju dizni!!!!!!!parametre zadati ostvareni pritisak turba u stocku,onda dalje ....lagano ako hoces to da skockas kako treba,jesi zatvorio agr fizicki?(mislim i softwerski?) Nisam nista gledao. MAP, MAf, parametri dizne nista nije dirano ni cisceno. Ocisticu MAF i MAP, pregledati dizne korekciju i na drugi dyno. Mislim da cu u NS gde je Milutin radio jel vidim da je on izbacio fabriku. 5 minutes ago, Milutin-NS said: @PremieRacing - sta si ti merio i koliko ks? Da vidimo cisto ima li razlike nova vs. Safetovi valjKci... Ja iskreno ne znam da li je covek stigao. Bio je u Sremcici, izgubio kljuceve od kola, obijao kola i na kraju krenuo. Ja sam morao da odem za KG da uzmem kadicu tako da @dellas mozda zna da li je stigao. @dellas sta je uradio e60? 1 minute ago, DraganUS said: Izgleda da jeste. Sad sam bas nasao stock vs tunned kod poljaka. Nisam nista gledao. MAP, MAf, parametri dizne nista nije dirano ni cisceno. Ocisticu MAF i MAP, pregledati dizne korekciju i na drugi dyno. Mislim da cu u NS gde je Milutin radio jel vidim da je on izbacio fabriku. Ja iskreno ne znam da li je covek stigao. Bio je u Sremcici, izgubio kljuceve od kola, obijao kola i na kraju krenuo. Ja sam morao da odem za KG da uzmem kadicu tako da @dellas mozda zna da li je stigao. @dellassta je uradio e60? Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 9, 2017 Ja sam danas izmerio debljinu živaca i izdržljivost srca... ceo dan uz k, dobro je da sam se živ vratio kući i sad idem da spavam do sutra. Na merenje sam došao sa ogromnim kašnjenjem kad su svi već otišli i nisam nikoga video i upoznao i jako mi je krivo. Mislio sam da će danas biti extra druženje ali jbg... Btw kod mene izmerena skoro fabrika, što je super (Punto 130ks): Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted December 9, 2017 Kakav sad Punto 130?Sent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted December 9, 2017 (edited) @DraganUS - izbacio meni fabriku, takodje kolegi sibisi. Ja 164...on 163 Edited December 9, 2017 by Milutin-NS Quote Share this post Link to post Share on other sites
dekirs 4819 Posted December 9, 2017 Isto fabrika kod Safeta, 119 sa dpfom.Sent from my SM-G955F using Tapatalk Quote Share this post Link to post Share on other sites
cane 205 Posted December 9, 2017 Meni izbacio 147ks i 320NM sto je skoro fabrika - fali 3ks i 20NM, negde se zagubili ali to je to, sad sam siguran da je zdrav i spreman za remap Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted May 22, 2018 Gurao je ruku tamo gde nije trebalo, a limena zver je to znala da kazni Nesreće na valjcima za testiranje karakteristika automobila nisu retkost, a po pravilu se vezuju uz nedovoljno bezbedno postavljene automobile. Najnoviji video, koji prikazuje jednog neopreznog zaposlenog koji je umalo stradao, zapalilo je društvene mreže. Na valjcima se našla Corvette ZR1, a nesrećni radnik je imao zadatak da metlom očisti točkove od zaostalih kamenčića u gumama. I da, točak je povukao metlu i samog radnika kojem je ruka prošla kroz valjke. Izgleda bolno i zastrašujuće, ali nesrećnik je ipak imao sreće i iz nemilog događaja je izašao nepovređen. preuzeto sa - Auto Blog Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 18, 2019 Ima li interesenata za merenje? Cuo sam da AMSS ima nove valjke i za grupne posete naplacuje mizernih 1000 din po autu 1 dach@ reacted to this Quote Share this post Link to post Share on other sites
SerAlex 37 Posted May 20, 2019 Ja sam zainteresovan ali samo ako bude to uskoro (narednu nedelju, nedelju i po dana), u suprotnom i ovako ide negde na remap pa ce se tamo meriti. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 20, 2019 Mene samo interesuje ZA ŠTA AMSS-u trebaju valjci, i da li bi trebali da se zabrinemo? 2 alfini0507 and horvat reacted to this Quote Share this post Link to post Share on other sites
SerAlex 37 Posted May 20, 2019 Verovatno za vanredni tehnicki kad te pandur zaustavi i ucinis mu se sumljivim. Tesko vidim razlog za bilo sta drugo. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted May 20, 2019 To upravo to i jeste zabrinjavajuce Quote Share this post Link to post Share on other sites
danijel55 700 Posted May 20, 2019 Cekaj,cekaj.AMSS u svim gradovima ili samo u Bg-u? Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted May 20, 2019 Odes izmeris i automatski ti upisu u saobracajnu koliko stvarno ima Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 20, 2019 AMSS Zrenjaninski put Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted May 20, 2019 Izmeris i ima manje ks od deklarisanih i spuste ti cenu osiguranja, al kad bi se zezali Ne mere snagu ni u nemackoj ni svajcarskoj na tehnickom iako zagledaju sve tipa potrosenost metlica brisaca, potrosenosti plocica, rad klime i ventilacije, et felne, klirens auta itd. Quote Share this post Link to post Share on other sites
Stilisa 313 Posted May 20, 2019 I ja sam zainteresovan, samo da se uklopim zbog posla. Ima amss valjke odavno, ali se nije nesto reklamirao Bilo bi dobro da tamo ima i neko krsten da zna da procita mapu, da mozda uvidi neki problem i slicno....ovo "ks-nm", to znam i ja da procitam Ali verovatno koliko para-toliko muzike. Svakako bih isao.... Quote Share this post Link to post Share on other sites
