Mijailović P. 3450 Posted April 17, 2021 Omatorilo se pa i vid popustio. 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted April 17, 2021 Ali zato frajer sam zameni nosac . Ti kao onaj, kad deda drzi unuka na krilu. E sine, kako smo mi davno na frontu puske preko q**a lomili. A sad nikako, oslabile dedi ruke . 2 Reacher Gilt and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted April 17, 2021 Pa reci ono najbitnije, sumnjivo mi sto ne pricas. Ima li razlike 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted April 17, 2021 Ogromna razlika i baš primetna. Sa starim nosačem je, možda i subjektivno, nekako prednji desni točak više "osećao" rupe i neravnine iako je sve zamenjeno i utegnuto. Sada tog osećaja nema na upravljaču i oba podjednako upijaju i podnose podlogu. Jednostavno bolje je. Stari noač je prilično oslabljen i raskliman mada sam viđao i mnogo lošije u upotrebi. Start i gašenje motora je prvo što mi je skrenulo pažnju. Nije on ni pre toga ljuljao već sad ima onaj "tup" prigušen zvuk u oba slučaja. Moglo je to još siguran sam a, kod mnogih nebi ni bio u opciji za zamenu. Ja to jednostavno ne podnosim. Jbg, polovan auto je polovan auto. Sad čekam da se prolepša vreme pa da montiram kameru za "rikverc" i neke trake DRL da probam na šta će to ličiti. Malo se igramo. 3 MS PK, horvat and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted April 17, 2021 Ako, podetinjio si pod stare dane 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted May 4, 2021 Masakrrrr.... 5 neshaoct, Pluto, Dzimbo and 2 others reacted to this Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted May 4, 2021 Ma, davalo se (opet ) i po gasu 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted May 4, 2021 Jedna od retkih situacija gde je tamnija boja zahvalnija za (ne)održavanje. 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted May 4, 2021 A kad imas turbinu sad.. Послато са SM-A307FN помоћу Тапатока 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Dale 6810 Posted May 5, 2021 On 5/4/2021 at 12:30 PM, Mijailović P. said: Masakrrrr.... Srecom nisi vozio motor 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted May 5, 2021 Nekad voz'o, batalio. Uh, tako kad naletiš u ogroman roj, to samo puca. Quote Share this post Link to post Share on other sites
Dale 6810 Posted May 5, 2021 Ja sam sa maxi skuterom skupljao ovako sl, mogu da zamislim kako je na vecim brzinama na motoru. Quote Share this post Link to post Share on other sites
djomla 8386 Posted May 5, 2021 3 minutes ago, Mijailović P. said: Nekad voz'o, batalio. Uh, tako kad naletiš u ogroman roj, to samo puca. 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Dale 6810 Posted May 5, 2021 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Dale 6810 Posted May 5, 2021 To je sa neta slika, ja srecom imao vizir 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted May 11, 2021 5 vagenovac, Reacher Gilt, djomla and 2 others reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted May 11, 2021 Moze pudla da spava u wheelgapu 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2177 Posted May 11, 2021 Lepotica i zver. E, sad, sad ko je ko ... 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4033 Posted May 11, 2021 Samo da proradi dpf pa kad postane ugljesa 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted May 11, 2021 Mala zna da pozira. DFpfdg šta je to? 1 2 Dale, ISV_01 and djomla reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted May 29, 2021 Nije to tako strašno kako to vagenovac karikira... Nem' ove skupe aparate i objektive al' mirna ruka... 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted May 29, 2021 Ma jbs to sto nemas objektive, apsolutno je nebitno, vidis da je extra i ovako al sto nemas tockove.. to je veliki problem Послато са SM-A307FN помоћу Тапатока 3 Mijailović P., Ivan and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted May 29, 2021 Na vazdušnim točkovima. 1 1 Reacher Gilt and MS PK reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted May 29, 2021 43 minutes ago, Mijailović P. said: Nije to tako strašno kako to vagenovac karikira... Apsolutno se slazem. Kako si to lepo rekao - imas od mene na poklon set distancera . Ako si vec toliko emotivno vezan za 16'' felne. 1 1 MS PK and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
