Mijailović P. 3450 Posted February 16, 2020 Lood Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 16, 2020 Samo ti meni daj ideje, pa cete da me se odreknete preko javnog glasila 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Irena HGT 2139 Posted February 16, 2020 Evo, em što voliš bicikle em što će da odgovora za tvoje brzine 3 1 horvat, djomla, MS PK and 1 other reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 Danas poruceni prednji diskovi Akebono standard i plocice za prednje diskove Galfer High Performance iz Slajer-a.. Suma sumarum 13.140 RSD Diskovi - 9.220 Plocice - 4.610 Popust 5% Ima da se iznenade u firmi kad mi stigne paket od cca 10 kila 2 Mijailović P. and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 19, 2020 Bravo! Javi kako rade jedno 200-300km posle montaze po gradu lagano bez zabadanja Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 Bogami ce se nacekamo da vidimo kako rade...po recima mog majstora, stari set bi trebao na zamenu taman na sledeci mali servis, znaci oko NG ili u Januaru sl.godine, ali kako ce devojka krenuti da vozi isto, mozda bude i malo ranije Quote Share this post Link to post Share on other sites
Ivan 17679 Posted February 19, 2020 3 horvat, djomla and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted February 19, 2020 Covek kupi diskove i plocice i nece da montira odmah Skidaj to sa kola bacaj u kantu i metni novo, ko ce cekati toliko za montazu 2 ISV_01 and djomla reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 @Ivan Znam da se svi zivi mucite da mi nabavite felGe da najzad auto mogu nazvati autom, ali stambeni prioriteti su ipak ispred Nista od ulaganja sto nije neophodno, na zalost. Inace, zar ovakve nisu bile iste na GP-u ? @dekirs Do mesa bato, nista se ne baca 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 19, 2020 (edited) Sta ti decko radis??? Cekaj cekaj cekaj, ti si to sada uzeo i neces odmah stavljati??? Zato sto je majstor rekao "TO MOZE JOS"??? Kocnice??? I sta kao onda ces galferu produziti vek trajanja za od februara do kraja godine? Ma daj bre ne zezaj covece i ne zezaj se sa kocnicama! E svasta Ps - ma sve mislim nemoguce. Nisam ja to dobro razumeo... Edited February 19, 2020 by Milutinac 2 ISV_01 and djomla reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted February 19, 2020 Pusti bre ti majstora i moze to da tera. Kad si vec dao pare montiraj to i uzivaj kao sto rece Milutinac. 3 dekirs, djomla and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17679 Posted February 19, 2020 Montiras nove diskove i plocice, a da se ne vide kroz alu-felne. Pa jos ako su diskovi sa nerdjajucim srcem, mis'im stvarno gre'ota ... 3 djomla, ISV_01 and MS PK reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 Jeste, obavezno sam lud da kupim i ne stavim cim pre Reakcije bolje neg sapunanje i nekupovina felgi Sledeca plaTja - oma se menja, de bre put Grcke da idem sa 'jos moz malo' diskovima i plocicama...neka fala. Quote Share this post Link to post Share on other sites
Flex 1778 Posted February 19, 2020 Ne bismo zaboravili nedostatak felni svakako. 2 djomla and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 Vala, sledeci auto ima da ima minimum alu felne, necu preziveti sledece otvaranje teme ovde 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 @Ivan Samo da proverim, kolicina ulja u kocionom sistemu kod Brava je 0.52 ? Jel to kompletna zamena ulja ili samo razlika izmedju zamene diskova i plocia ? Quote Share this post Link to post Share on other sites
Ivan 17679 Posted February 19, 2020 58 minutes ago, ISV_01 said: @Ivan Samo da proverim, kolicina ulja u kocionom sistemu kod Brava je 0.52 ? Jap, ukupna kolicina u sistemu. Ako kupujes Tutelu, to je Top 4, zuta bocica sa plavim cepom, 0.5l je cca 500 kinti. Odradi zamenu i to obavezno ako nisi do sada, posto je kociono ulje izuzetno higroskopno (upija vlagu). Smesan je trosak. Nego prvo proveri u servisu gde menjas - mozda imaju svoje ulje, da ga ne kupujes bez veze. Ranije sam na Stilu kod Nese sipao ATE na masini (izvuce staro, ubaci novo). Goranu sam ostavio Sporta da to odrade odmah uz veliki servis, tako da iskreno nisam ni pitao. 1 1 neshaoct and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 Prosto mi nerealno da je nesto manje od 1L u ovom autu verovatno cu Tutelu da pazarim, me'anicar i ja smo na 'donesi pa cemo pakujemo'. Fala vi na tumacenju Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 19, 2020 On 2/19/2020 at 3:33 PM, ISV_01 said: Jeste, obavezno sam lud da kupim i ne stavim cim pre Reakcije bolje neg sapunanje i nekupovina felgi Sledeca plaTja - oma se menja, de bre put Grcke da idem sa 'jos moz malo' diskovima i plocicama...neka fala. Aaaaa pa dobro je...ipak se onda nismo razumeli ipak si na pravom putu 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 @Milutinac Ne znam ja bato, pitaj ove sa skupa, kazu nesto nisam u vinklu Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 19, 2020 Zbog celicnih??? Pitaj ti njih - ZASTO ONI NEMAJU CELICNE! Obrni situaciju u svoju korist! Uopa 3 1 dekirs, ISV_01, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted February 19, 2020 (edited) 4 hours ago, ISV_01 said: Bogami ce se nacekamo da vidimo kako rade...po recima mog majstora, stari set bi trebao na zamenu taman na sledeci mali servis, znaci oko NG ili u Januaru sl.godine, ali kako ce devojka krenuti da vozi isto, mozda bude i malo ranije Jel sam ja lud ili ovo kapiram kao da nece sad menjati? "Ce se nacekamo da vidimo kakorade...zamena oko NG ili Januar sledece god..." :S Edited February 19, 2020 by dekirs Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 On 2/19/2020 at 3:33 PM, ISV_01 said: Jeste, obavezno sam lud da kupim i ne stavim cim pre Reakcije bolje neg sapunanje i nekupovina felgi Sledeca plaTja - oma se menja, de bre put Grcke da idem sa 'jos moz malo' diskovima i plocicama...neka fala. @dekirs Fabule, radnja odje Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 19, 2020 Šta sve neće čovek da kaže kako bi se zaboravila priča o sapunjanju na zadnjem sedištu... 3 darkman14, Ivan and dekirs reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted February 19, 2020 Bar mu je izribana zadnja klupa do perfekcije Sad ne smem ni u ludilu da kupim Alfu Quote Share this post Link to post Share on other sites
