djomla 8386 Posted January 24, 2020 Ja bi sad sipao Mići u inat Sent from my 3310 using Tapatalk 2 4 Flex, alfini0507, Smireni and 3 others reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 24, 2020 Znas kako, ko se na mleko opece i u jogurt duva 2 djomla and Flex reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 24, 2020 Ma brate..mora da ga ozenimo pod hitno inace mu neka ustanova ne gine Послато са SM-J330F помоћу Тапатока 2 djomla and alfini0507 reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 24, 2020 Što pre, dok se ne pročuje po čaršiji Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
Axic 20048 Posted January 24, 2020 24 minutes ago, djomla said: Ja bi sad sipao Mići u inat Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 24, 2020 Sent from my 3310 using Tapatalk 1 totti reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted January 24, 2020 Samo dospi... 2 djomla and MS PK reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 24, 2020 Vidi sad 'oce i da me zeni covek. Pa malo li je ova muka? Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 24, 2020 Da vidis sta su muke a ne to "fali mi jedan kruzic za max" Послато са SM-J330F помоћу Тапатока 2 bit and djomla reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 24, 2020 Ma ebem ti kruzic kud i pogledah. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17670 Posted January 24, 2020 14 minutes ago, Flex said: Vidi sad 'oce i da me zeni covek. Pa malo li je ova muka? Sto se kaze - sto da tebi bude bolje nego nama ? A i sto Mica kaze, opusti se, mozda nije vozeno, mraz... Licno sam od Shella sipao Helix Ultra 5-40 i trosio ga je max 2 dl na servisnom intervalu, nekada se desavalo da osegne samo trunku. Sve isto kao i Selenia WR. 2 djomla and Flex reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4033 Posted January 25, 2020 Ne cackaj nista dok radi i ima ulja do pola ti sipke. Posle vec kreni po malo da dolivas i licno ne bi nikad dolio do max..bolje malo ispod jer znas da nisi prelio nego na-do max (a kad ono mizerno iznad) pa da bude belaj zbog viska. Premda... Mozda bi i ja sad sipao dok ne izbije na cep u inat mici...ima se moze se Quote Share this post Link to post Share on other sites
bit 937 Posted January 25, 2020 Jaaooo uhhhh Kako se ono kaže kod nas, prvi mačići se u vodu bacaju...Za prvi auto si trebao uzeti neku klotaru iz 80-90, ili nekog yuga beyond 2000 , na godinu dve, pak kad ti posrče ulja ispod minimuma a ti još voziš nesvestan toga, ili nestane vode u rashladnim sistemu ...Buba je kapljala po parkinzima 1l na 1000km, a ford escort u poznim penzionerskim danima trošio 0,5 na 1000km. Koliko je puta ostao i ispod minimuma i ništa ide on i dalje, malo više zvecka i to je signal da dospem .Ne brini oko auta previše, to je limena Kanta.Otvori Haubu jednom mesečno par minuta, pogledaš nivoe, kleme, dospeš vodu za brisače i pedal to the metal Послато уз помоћ ТT 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4033 Posted January 25, 2020 (edited) Nemoguce @bit.. Pa ja otvaram haubu 1/7 dana na svojoj sklopociji. mislim ono, provera da li mi je ulje gde treba, ima li ispod auta (ako nema ispod, nema ni u njemu), da li mi se neka macka uvukla pod kaiseve, cigani da mi nisu drpili alternator i da uopste proverim jel mi motor tu.. Nekako mi tisi svaki put kad ga upalim, sve mislim da mi preko noci stave benzinca mesto mog traktora. Znaci on mora samo cesce proveravati, ipak je to legendarni JTD Edited January 25, 2020 by ISV_01 Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 31, 2020 Da mi ne zamre tema. Sent from my SM-J530F using Tapatalk 4 Mijailović P., Djuk85, ISV_01 and 1 other reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 31, 2020 Nek zamre tema, samo nek ne zamre stilo Послато са Mi MIX 2 помоћу Тапатока 3 1 Axic, Flex, bit and 1 other reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 31, 2020 Jel su ti novi prednji amortizeri?Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 31, 2020 Jok, nista nije dirano od kad je kod mene. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted January 31, 2020 Baš ništa? sa TT 1 djomla reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 31, 2020 Nesto mi visok napred pa zbog togaПослато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 31, 2020 Pa da je malo nizi ne bih ni mogao da ga vozim, vuk'o bih pleh po ulici. Ovo gde je sad parkiran jedva je pleh malo iznad, zlo. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 1, 2020 A meni deluje nizak, to mi je najveci horor bio sa alfom 159, nerealno nizak zadnji prednji kraj, gde drugi auti se penju ili spustaju bez problema ja kacim, a parkirao sam pola metra od bankina kada idem njuskom ili se parkiram u rikverc 1 Flex reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted February 1, 2020 To je to, gde god penjem ekstremno sporo. I tako vrlo cesto zakaci pleh. Neka uvala na putu takodje, mnogo nisko stoji. Bas cu da slikam sutra pleh i lip koliko su od zemlje. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7734 Posted February 1, 2020 Slikaj tocak i krilo da vidimo Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
djomla 8386 Posted February 1, 2020 A mozda su popustile opruge? Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
