darkman14 5900 Posted September 17, 2021 Sad ste i mene bacili u rebus... Ovo je broj dela za deltu 46831042 i to je 251mm (251.5mm) Meni jedino žao što i promer rupa nije 5x98 pa da se može više felni birati, ovako je sužen izbor 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
nstyner 171 Posted September 19, 2021 Lepo ispalo Milutinac svaka cast,bas upada u oko! Sto rece kolega Ivan,nesto nikako da se pokrenem oko doterivanja auta,a celjusti sam planirao jos pre dve godine da sredjujem i da ih bacim u neku mesing-zlackastu boju,mislim da bi ok diskretno cucnule na Merivi! Od kradja kapica sam se resio napokon odkad smo u garazi.... Quote Share this post Link to post Share on other sites
MS PK 7734 Posted September 19, 2021 Kako kociii? Послато са SM-A307FN помоћу Тапатока 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted September 19, 2021 35 minutes ago, nstyner said: Sto rece kolega Ivan,nesto nikako da se pokrenem oko doterivanja auta FLCS pododeljenje "4 banke +" . 2 1 Sedla, nstyner and MS PK reacted to this Quote Share this post Link to post Share on other sites
nstyner 171 Posted September 19, 2021 1 hour ago, Ivan said: FLCS pododeljenje "4 banke +" . Upravo tako! Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted September 20, 2021 11 hours ago, MS PK said: Kako kociii? +1 Quote Share this post Link to post Share on other sites
Ivan 17670 Posted September 20, 2021 Kako... Pretice ga zadnja torzija : 2 alfini0507 and horvat reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 20, 2021 11 hours ago, MS PK said: Kako kociii? Zabada, eto ukratko zabada... Ako za "nešto" sada stisnem kočnicu kao pre - cimne, pritome cima tako i na 80 i na 100 i na 120, ok ne istom jacinom na 80 i 120, nije Zonda ali nisam pre imao to tako bas tako konkretno na vecim brzinama. Sinoc prilazim naplatnoj rampi i reko` sa nekih 100 cu ga pustiti malo duze da se kotrlja i onako bez tog cimanja stisnem maaalo jace, umiri se i osecaj kao da se spusti i bez i trunke neke napetosti i nervoze eto te na 40...luuuud osecaj skroz. Kao kada chipuju kola pa ode potrosnja na 15, e ja tako sada samo zalecem i kocim pritome, imam osecaj da nisu jos plocice nalegne 100%, nije ni realno, danas im je tek 5. dan Jedan lik mi je sa engleske FB bravo grupe rekao da ce biti "Massive difference", posto je on kod sebe vec stavljao 305mm sa Mitoaoaoaaa, i deluje mi da ce biti bas tako, vec sada jeste velika razlika Ono sto mi se vec mota po glavi je da necu moci odoleti da ih ne probam sa nekim bas bas dobrim diskovima 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted September 20, 2021 Donesi svoje, izbusicemo Moze i neki patern, ako ti odgovara I eto skupih diskova Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted September 20, 2021 Pogotovo jer sudeci po slici, patern rupa je vise sminka nego funkcija... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 20, 2021 Nema greske ni sa Brembom (iz njemacke) ni sa Zimmermann-om (iz njemacke)...ajte molim vas PS - bonus pikčr froma lest najt 6 Reacher Gilt, ISV_01, darkman14 and 3 others reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted September 20, 2021 20 minutes ago, Milutinac said: ...Kao kada chipuju kola pa ode potrosnja na 15, e ja tako sada samo zalecem i kocim... Vodi računa o gumama, džabe malo trošiš sa smrdljivim dizelom ako ćeš gume menjati k'o čarape Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 20, 2021 2 minutes ago, PremieRacing said: Vodi računa o gumama, džabe malo trošiš sa smrdljivim dizelom ako ćeš gume menjati k'o čarape Nije jos bilo onakvih momenata kao kada sam probao jeltu Generalno ne ludujem sa kolima i nema vise onakvih momenata kao kada sam bio u HGT fazi, ali lepo je imati takav osecaj na kocenju, isto kao i kada imas vecu rezervu snage, jel nam svima potrebno 200ks, pa nije ali jbg, volEmo tako i ovo moje 2 MS PK and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Vule 795 Posted September 20, 2021 Kako misliš nije? 2 2 Milutinac, Reacher Gilt, PremieRacing and 1 other reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 20, 2021 Kakav ti je utisak što se tiče zadnjih kočnica?Svojevremeno sam radio istu stvar i zadnje su bile mnogo rasterećenije, tj, mnogo više kočione sile na prednjim.Dolazilo je do disbalansa (zadnji kraj bežao pri jačim kočenjima), pa sam kasnije morao da pojačavam i zadnje (da ih uparim sa prednjim).Poslato sa JSN-L21 pomoću Tapatoka Quote Share this post Link to post Share on other sites
horvat 6456 Posted September 20, 2021 Ja mislim da Bravo ima onaj EBD, elektronsku raspodelu sile kocenja, tako da se to ne moze desiti dokle god mu radi ABS. Kad bi izvukao osigurac ili iskopcao jedan od senzora, onda bi mozda bilo veselo Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 20, 2021 Da da da, ima EBD. Sasvim fino se ponasa, nikakvih cudnih momenata za sada, iako stvarno sve sto sam im i radio do sada spada u potpuno redovno/normalno koriscenje ne znam gde su im granice, nije to jos sve naleglo kako treba Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 20, 2021 Upravo se i radi o silama bez aktiviranja ABSa. Recimo, osrednje sile kočenja, ideš 80-90kmh, nailazi blaga leva - desna krivina, zadnje kočnice nedovoljno jake (prednje ujedaju) i dupe kreće u šetnju.Baš sam o tome razgovarao sa momcima iz Slajera. Preporuka je da uz Galfer HP (napred) i na zadnje diskove bar običan Galfer ili Car, jel može da se desi da dupe pretiče nos. Poslato sa JSN-L21 pomoću Tapatoka Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 20, 2021 Nesto smo se toga dotakli na prosloj strani, delta 1.8di (200ks) sa Brembom od 330mm napred, nazad ima 264 disk, naspram mog nazad od 251, tako da nije neka ogromna razlika s obzirom i da delta napred ima vece (330) naspram mojih (305). Nazad imam galfer disk i akebono nove plocice i radi to lepo... Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 20, 2021 Poslato sa JSN-L21 pomoću Tapatoka Quote Share this post Link to post Share on other sites
horvat 6456 Posted September 20, 2021 Ali nije reakcija elektronike tek nakon sto auto prokliza, nego i ranije. Racunar ima input od yaw senzora, ugla volana i brzine svih tockova ponaosob, i spram toga moze da rasporedi silu kako treba. Zato ti auti nemaju 5. cilindar, kao Punto (koji takodje ima ABS, ali tu raspodelu radi mehanicki)... 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted September 20, 2021 Ne pominji mi punto, onaj moj je bio kao yugo, pri naglom kocenju na vecoj brzini eto ga dupe pored mene i jos mi se cini kako ubrzava Послато са SM-A307FN помоћу Тапатока 1 1 horvat and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted September 20, 2021 Gume takodje enormno mnogo znace, ako su nazad odlicne gume, tesko ce da dupe prestize cak i da koci mnogo jace napred. Zbog toga je i neka preporuka da nazad idu bolje gume cak i na prednju vucu jer se tako obezbedjuje stabilnost u krivini, ali je kod nas bitnije krenuti iz mesta nekako, zato smo vidjali zimske specijalitete, napred zimulje, auto krece iz mesta, a kad treba da stane kuku lele Takodje treba uzeti u obzir da je kod ovakvih i slicnih FWD auta maltene 2/3 tezine u nosu, sto znaci da je zadnja osovina duplo laksa od prednje. 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 20, 2021 Ovaj novi STRAAAAŠNI SATANISTIČKI tehnički pregled i nije neki bauk, da vam ja kažem... Bauk je samo cena registracije, umesto da sa godinama pada, ona sve veća, ode danas skoro 38.000...ko želi da čestita - može... Quote Share this post Link to post Share on other sites
darkman14 5900 Posted September 20, 2021 Za šta 38k? Jel tehnički otišao na 7000? Quote Share this post Link to post Share on other sites
