Axic 20048 Posted February 29, 2016 Onda ce biti Clash of the titans. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 29, 2016 40 minutes ago, Axic said: Ovaj Milutin sve prati. Pa kako cu zaraditi ovu forumsku platu? Quote Share this post Link to post Share on other sites
joshibeast 74 Posted February 29, 2016 Evo, sada je priznao da je plaćenik koji agituje protiv JTD-a Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 29, 2016 `Ajde bre, vidite da sam smirio u poslednje vreme, skine mi sa plate 5% svaki put kada spomenem JTD (evo upravo ode jos 5) Quote Share this post Link to post Share on other sites
Markobgd 609 Posted February 29, 2016 (edited) Pa ti nisi samo figurativno na gubitku što ne voliš JTD već stvarno osećaš posledice Edited February 29, 2016 by Markobgd slovna greška Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 29, 2016 Dobro, dobroooo, ovo si lepo smislio Quote Share this post Link to post Share on other sites
Dezurni 399 Posted February 29, 2016 Zato je Marko kupio benzinca Da umanji štetu Quote Share this post Link to post Share on other sites
Markobgd 609 Posted February 29, 2016 Ravnoteža u kosmosu mora da se uspostavi Quote Share this post Link to post Share on other sites
Deki mjet 0 Posted February 29, 2016 Ja sam juce skidao i cistio egr i blokirao ga bakarnim limom na 1.3 mjet, drugi auto, al da je zeznuto skinuti, zeznuto je Quote Share this post Link to post Share on other sites
Axic 20048 Posted February 29, 2016 @Deki mjet Stavio plocicu bez rupica i nije napravio problem ? Quote Share this post Link to post Share on other sites
Deki mjet 0 Posted February 29, 2016 Da, bez ikakvih rupica. Ocisti odmah i senzor na usisnoj, verovatno je i on prljav. I cev od interkul. do usisne, meni je bila haos, puna nekih naslaga, poput smole Quote Share this post Link to post Share on other sites
Axic 20048 Posted February 29, 2016 MAP senzor sam ocistio jesenas, IC za sad necu dirati ali me cudi za plocicu da ti nije upalilo ni check engine ili da je upao u safe mode. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted February 29, 2016 (edited) Upaliće, sutra-prekosutra. Tako je meni bilo kad sam zatvorio prvi put bez rupica Edited February 29, 2016 by Markobgd Quote Share this post Link to post Share on other sites
Dezurni 399 Posted February 29, 2016 Kao što na minusu pali, tako mu i treba vremena da shvati promenu Quote Share this post Link to post Share on other sites
Deki mjet 0 Posted February 29, 2016 Pa cim upali, vozim da ga soft. gasim. Danas sam imao malo duzu voznju, dva puta Obrenovac-Beograd, i sve okej radi. I od kako sam ocistio sve to, auto mnogo lepse radi i ravnomernije ubrzava, nema kao knedlu pri ubrzavanju Quote Share this post Link to post Share on other sites
Mc Shok 0 Posted February 29, 2016 On 2/28/2016 at 7:08 PM, ivan.ik said: Sinko turi tu pločicu i uživaj. Samo gledaj da je lim bar 1 mm debeo. sutra sutra Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 29, 2016 23 hours ago, Markobgd said: Negde sam već rekao gomila ljudi "čipuje" auta ne bi li dobili 10~15~30ks a garantujem da su toliko ako ne i više izgubili prljavim usisom koji neće da očiste a operacija ih košta koliko i to "čipovanje" (čast izuzecima) Tačno. Sledi detaljnije. 23 hours ago, Markobgd said: ...ja sam nakon čišćenja grane ostavio EGR otvoren i u funkciji iako sam lično vaduo govna iz grane. Mislim da to više nego dovoljno govori o mom mišljenju na temu istog. Kasnije sam ga pritvorio sa bušnom pločicom da probam vidim da li će se izgubiti povremeno posustajanje na sekundu pri ubrzanju Upravo ovo povremeno posustajanje je najbolji pokazatelj da nešto sa EGR-om nije u redu. Kod mene je prvo bilo povremeno, kratkotrajno. Onda sve češće (od npr. 10 davanja gasa do patosa, 9 puta posustane). Tokom vremena se povećavao i opseg broj obrtaja koliko to posustajanje traje, tj. nije više bilo tako kratkotrajno u samo 200-300 obrtaja raspona. Još jedan simptom, koji sam kasnije video da pominju i po stranim forumima, je teže paljenje. Teže u smislu da ponekada neće da upali iz prve. Samo to. Dakle, ne da duže vergla, da se muči ili sl. nego jednostavno vidiš da neće da upali pa makar do sutra držao ključ i verglao. Vratiš, pa ponovo i upali bez problema. Meni je jedno 2 puta u par meseci odbio da upali iz prve, ali baš zato što je bilo toliko retko nisam ni pridavao poseban značaj tome. Sve sam to planirao da prijavim na redovnom servisu koji je ionako išao za par meseci, tako je i bilo. Check engine lampicu ne treba gledati kad je ovo u pitanju. Meni EGR nije radio nekoliko meseci kako treba, ali lampice nije bilo. Upalio ju je jednom na leru, dok sam stajao na semaforu, i to kad je mali servis već bio zakazan. Ugasio ju je sutradan. Ali, dobro je što je ostala u memoriji. Kada je očitana, videlo se da je prijavio količinu vazduha kao problem. Pomislio bi neko da i nije tako loše kada turbo motor ima više vazduha. Problem je što u izduvnim gasovima nema kiseonika. Oni su, kao što znamo, produkt sagorevanja i kiseonika tu više nema. I sva ta masa vazduha se ubacivala nazad u usis kroz stalno otvoren EGR, ali nikako nije mogla da pomogne sagorevanju, nego je samo odmagala jer je inertan gas u pitanju. Prilikom redovnog servisa, kada je završeno sa uljem i filterima, krenulo se po toj grešci. Ispostavilo se da je EGR bio 100% otvoren. Uvek. Stalno. Bez obzira na režim vožnje, uvek otvoren skroz. Napunio se sa garaži (čađ), ona blokirala osovinicu koja treba da otvara/zatvara EGR kako je predviđeno, i on ostao tako zaglavljen, otvoren. Posledica je da je u usisnoj grani stalno bila znatno veća količina (masa) vazduha nego što treba da bude, pa je eto posle više meseci takve vožnje, jednom to uspeo i da prijavi (onaj check engine). Otprilike duplo veća, npr. ako je tražena masa 315, imao je 600, pa i malo preko toga. Sve se to videlo na Examineru. Skinut EGR, očišćen, vraćen nazad. Kad god se to uradi, ne mora da znači da će da proradi EGR. To što je fizički otklonjena prepreka da osovinica radi, ne znači da će stvarno i početi da radi. Tada (ako i dalje ne radi) je jedini lek pločica, tj. zatvaranje jer niko ne kupuje nov EGR jer košta nekoliko prosečnih plata u SRB. Pogledano na Examineru, radi EGR. Provozan auto, bolje ide, odnosno kraće traje (manji raspon obrtaja) to posustajanje, ali je i dalje bilo prisutno. Ponovo skinut EGR i pogledan sam početak usisne grane, oni kanalići na njenom početku: Ovako je taj deo izgledao: Izduvano kompresorom sve ka napolje, oduvana garež sve ka šoferci. Ponovo montiran EGR, proban auto i posustajanja više nije bilo. Ovo su parametri nakon svega toga, ler, zagrejan motor: Vidi se da je tada EGR poluotvoren. Nakon 2 nedelje skinuta i očišćena usisna grana kako se inače radi. EGR je pre ovoga skidan i čišćen nekih 35.000 kilometara ranije. Faktički mu je trebalo nekih 30k vožnje da krene da pravi problem. Dakle, kako bi se sprečilo da se EGR zaglavi, otprilike na svakom drugom servisu (20-25.000 kilometara) bi ga trebalo skinuti i očistiti. Naravno, neće mu ništa smetati da to bude i prilikom svakog malog servisa. To za one slučajeve gde EGR nije već blokiran pločicom. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted February 29, 2016 Morao je da upali grešku ako je zaglavio EGR. Kad je zatvoren EGR primetio sam daleko veću količinu (masu) vazduha od tražene, baš kako si ti naveo ali kad ti je bio zaglavljen EGR. Inače dok je EGR bio otvoren tražene mase i dobijene su bile ujednačene. Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted February 29, 2016 Auto je otišao u servis tako što nijedna lampica nije sijala. Ni mesecima pre toga ništa, jedino tih nekih 24 sata je sijala neposredno pred servis, gde je prijavio upravo količinu vazduha, ali je i to sam ugasio posle dana. EGR je pokazivao otvorenost 100% bez obzira na to da li je ler, da li je na punom gasu. Uvek otvoren 100%. Izmerena masa vazduha se kretala oko 500, 600, nekada i preko 600. 1 hour ago, ivan.ik said: Inače dok je EGR bio otvoren tražene mase i dobijene su bile ujednačene. Kod mene sam gledao, 100% otvoren, i razlika skoro duplo između tražene i izmerene vrednosti. Quote Share this post Link to post Share on other sites
Mc Shok 0 Posted March 1, 2016 Pozdvar ljudi. Evo upisah se i ja medju vas koji ste blokirali EGR. Danas ga i ja zacepih Da ne duzim,imaju slike ima i video sa pre blokiranja i posle blokiranja EGR-a Samo da kazem posto ga nisam vozio nesto pretjerano posle samo eto da probam kako ide... ide odlicno i sto je najbitnije TEMPERATURU DIZE NA VREME kao i pre blokiranja. Gas je osetljiviji bolje vuce i tisi rad motora. Hvala svima koji su mi pomogli da se odlucim na ovo Jos nesto da pitam. da lise moze sjebati sad EGR jer u njega ulaze izduvni gasovi a nemaju kud da izadju ? Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted March 1, 2016 Pa on je sad kao neko slepo crevo i moje misljenje je da se manje sakuplja cadji u njemu sad kad nema protoka, a mogao si i ispred njega da blokiras i da ostane cist zauvek. A i sad kad je blokiran sta te briga sta ce biti sa njim Quote Share this post Link to post Share on other sites
totti 13165 Posted March 1, 2016 Pošto je inače nov EGR za Jtd/Mjet? Ja sam danas zamenio na 2.0 Tdi i nov je 11.000 din (doduše serviserova nabavna cena). Ja se recimo nikad ne bih razmišljao da l' da ga zatvaram ili menjam za tako neku cenu. Quote Share this post Link to post Share on other sites
Mc Shok 0 Posted March 1, 2016 ma nije mi se dalo skidati ga a nemogu prici bez da ga skinem da bi ga zatvorio na ulazu. Posto mi je ispravan EGR nebi voleo da se nesto sjebe s tim sto gasovi nemaju kud da izadju a ipak ulaze u njega ? :/ Quote Share this post Link to post Share on other sites
MS PK 7735 Posted March 1, 2016 I ja se Totti nebih uopste razmisljao Quote Share this post Link to post Share on other sites
majkicbane 58 Posted March 1, 2016 Fino kolega po kilovatima i konjima nego ne razumem sta video pokazuje? ocekivao sam da ga przis u crveno, potpisujes itd Quote Share this post Link to post Share on other sites
