Branislav 722 Posted August 27, 2020 (edited) Takodje da se Horvatu zahvalim za savete i pomoc oko resavanje ove gluposti Edited August 27, 2020 by horvat skinut citat 1 horvat reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted August 27, 2020 Nema na cemu stvarno, tu smo da razmenjujemo iskustva 2 Branislav and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted February 26, 2021 Ludnica! Nigde u SRB nema zamenskog nosača motora, desnog! Ne gine mi iz originala. Kod Stojanova cca 18300. Kod Bogunovića cca 17500. Jbte, za malo plivajući ... No, život ide dalje. Nije za sada hića. Sačekaću koji dan. Siguran sam da neko nebi ni primetio da je u problemu nosač, da kažem, rekao bi da sam lood! Tako, sad odoh laganim gasooom. 1 1 horvat and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted February 26, 2021 Pa lud si Послато са SM-A307FN помоћу Тапатока 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
TheWickerMan 928 Posted February 26, 2021 Dranje. Probaj KiT komerc ako nisi probao, pre 2 god su imali Acron, 13.5 k je bio al je izdržao jedva godinu dana. Gesendet von OnePlus 8T mit TT Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted February 26, 2021 Probao, ništa. Hvala ali Akrona bez! 3 MS PK, TheWickerMan and Milutinac reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4035 Posted February 26, 2021 Ono...reparacija ? Ako je moguća.. Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted February 26, 2021 12 minutes ago, MS PK said: Pa lud si Послато са SM-A307FN помоћу Тапатока Mićaga, ima l' to na tvom? Just now, ISV_01 said: Ono...reparacija ? Ako je moguća.. Gde pobro? Quote Share this post Link to post Share on other sites
MS PK 7734 Posted February 26, 2021 Imalo je, sad ne znam Послато са SM-A307FN помоћу Тапатока 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 26, 2021 (edited) Nista od reparacije, jer nije obican nosac, tj sama guma vec u sebi ima neki hidro deo, sta li vec...tako ga valjda i zovu -hidro- Iako nisam pobornik polovnih stvari na kolima, kada sam radio obnavljanje nosaca probao sam da prodjem bez tih 15-ak hiljada, nasao sam polovan i urnisao lika koji mi ga je prodao da mi ga islika. Posle jedno 25 slika sam ustanovio da je -taj- nosac dosta bolji od mog, stigao zasrafio i sve ok! Zavrsio pricu sa nosacima... 2 koske/reketa sam uzeo nove, a onaj levi skinut, ustanovio da je odlican, vratio i gazzz Edited February 26, 2021 by Milutinac 3 Reacher Gilt, MS PK and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3450 Posted February 26, 2021 (edited) Da nemaš jedno 100kg a od toga 50kg mišića, izraženih? Ma znam to sve i znam kava je gnjavaža ljudima pa zato nisam razmatrao. Kod reparacije sam pretpostavljao da ima neka opcija zamene samog gumenog dela/silenta, ili kako već. Dubljom analizom nalazim da nije moguće sem u specijalnim uslovima. Hm, opet gnjavaža. Jedino da u NS postoji neki prodavac polovnih delova kod kog bih mogao lično da pregledam dotični. Edited February 26, 2021 by Mijailović P. 1 horvat reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted February 26, 2021 Ma kakva reparacija ako je punjen glikolom. Ili polovan ili nov originalПослато са SM-A307FN помоћу Тапатока 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted February 26, 2021 6 minutes ago, MS PK said: ako je punjen glikolom. To! Bravo Miconi! Quote Share this post Link to post Share on other sites
Ivan 17670 Posted February 26, 2021 1 hour ago, Mijailović P. said: Kod Bogunovića cca 17500. 17.300 din, preko drugara sa foruma 15.570 din . Kod Koleta okruglo 17.500 din. Precizan info iz prve ruke, od angazovane Pedjine mreze insajdera po BG . 1 1 Mijailović P. and horvat reacted to this Quote Share this post Link to post Share on other sites
srkiprki 0 Posted March 8, 2021 Pozdrav ljudi, da ne bih otvarao novu temu postavicu svoj problem ovdje. Vozim vec 6 godina Brava 1.9jtd 66kw. Ponekad, ne uvijek auto zna da cima u mjestu dok stojim, lagano trza taman da osjetim da mi dupe cima naprijwd nazad, bas tako u tom pravcu, naprijed nazad. Na sasiji se vibracija uopste ne osjeca. Nekada zna cimati po minut, dva, pet, bez pravila, i hladan i topal. Da napomenem da nikakvih problema sa vucom nemam. Jedino me zadnjih mjesec dva zeza na paljenju, vergla 3-5 sekudni i onda sastavi. Hvala na pomoci. Quote Share this post Link to post Share on other sites
vicent 1263 Posted March 8, 2021 Meni liči na neku diznu, imao slučaj na Puntu jtd. Pri gasu funkcioniše ali u mestu povremeno ne radi, stvara to ljuljanje napred- nazad.Poslato sa JSN-L21 pomoću Tapatoka 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
srkiprki 0 Posted March 8, 2021 6 hours ago, vicent said: Meni liči na neku diznu, imao slučaj na Puntu jtd. Pri gasu funkcioniše ali u mestu povremeno ne radi, stvara to ljuljanje napred- nazad. Poslato sa JSN-L21 pomoću Tapatoka Hvala druze i moj majstor sumnja na diznu ali opet kad imam vas sto da ne uppitati Quote Share this post Link to post Share on other sites
Slex 0 Posted October 27, 2022 Pozdrav drugari, Da ne otvaram novu temu, potrebna mi je mala pomoc. Ako je konstatovano da je centralni nosac motora za zamenu (radi se o 1.4 90kS) da li se zapravo radi o "zadnjem" nosacu ? Quote Share this post Link to post Share on other sites
Ivan 17670 Posted October 27, 2022 @Slex Pretpostavljam da je u pitanju donji nosac, tzv. "koska" ili "reket"? Ostavio sam ti ispod i OEM SN za obicni 1.4 Bravo (aspirated, ne turbo): Videces vec i po ceni, dosta su jeftiniji od ona druga dva gornja. Imas jos jedan kod menjaca: I onaj najskuplji sa suprotne suvozacke strane, punjen glikolom: Quote Share this post Link to post Share on other sites
