Marko Topola 71 Posted December 10, 2014 Jos 30-35dinara treba da spadne, da bi dosta na pravu cenu... Quote Share this post Link to post Share on other sites
totti 13183 Posted December 10, 2014 Da neće izbori? Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted December 10, 2014 Eeee mare kad padne tolko ima kanisteri i tankovi da rade, i onda stek dok se nesto ne dosete, da im trebaju pare i slicno... Quote Share this post Link to post Share on other sites
Marko Topola 71 Posted December 10, 2014 (edited) Hocu samo da kazem koliko su nas navikli na visoke cene, pa se sad radujemo i 10 din po litru nizoj ceni, a ona treba jos najmanje 3 puta toliko da spadne.Mislim da bi mi bili srecni i zadovoljni kad bi se samo cene dovele u red, a da ne pricam o povecanju plata, zaposljavanju itd... Edited December 10, 2014 by Marko-Topola Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 10, 2014 Aj preracunajte koliko je to u evrima ... i koliko ce da bude za mesec dana u evrima Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted December 10, 2014 Pa to je to beli za par dana ima da bude ravno 1euro po litri Quote Share this post Link to post Share on other sites
majkicbane 58 Posted December 10, 2014 Totti, uzede mi reč iz usta mora da će izbori uskoro Quote Share this post Link to post Share on other sites
acca90 0 Posted December 10, 2014 reforme,reforme, mere stednje Quote Share this post Link to post Share on other sites
Dusan 4 Posted December 10, 2014 Da da, kako se samo ne sete da malo reformisu njihove lopovske guzice i malo vise smanje alavost.... :2guns: :realmad: :rant: Quote Share this post Link to post Share on other sites
milos66 39 Posted December 12, 2014 idemo plin danas 83 zarez nestooo hahaha al ce od nove godine da bude 100 kinti jaoooo Quote Share this post Link to post Share on other sites
YUgisa 2903 Posted December 12, 2014 83 ili 93? Quote Share this post Link to post Share on other sites
Mijailović P. 3737 Posted December 12, 2014 Eko Zr. 83,××rsd Quote Share this post Link to post Share on other sites
YUgisa 2903 Posted December 12, 2014 Moj cale je sipao pre neki dan za 93 Quote Share this post Link to post Share on other sites
Mijailović P. 3737 Posted December 13, 2014 (edited) Ma slag'o ćale! Otišla razlika na Edited December 13, 2014 by Mijailović P. Quote Share this post Link to post Share on other sites
Ivan BG 747 Posted December 13, 2014 TNG na Zrenjanincu MBG gas. 81,40 din. Mada im nijedno gorivo nije neko, licno samo se OMV-a drzim. Quote Share this post Link to post Share on other sites
milos66 39 Posted December 13, 2014 jebes te pumpe deki,veki,miki i ostal opametno i ja gledam da benzin tocim na OMW-u imam drugara koji je radio tu i preporuka svakako za nju... Quote Share this post Link to post Share on other sites
majkicbane 58 Posted December 13, 2014 prolazim sinoc pored KNEZ pterola, cini mi se da je ED ispod 140 Dzaba im i da je ispod 120 Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted December 13, 2014 jebes te pumpe deki,veki,miki i ostal opametno i ja gledam da benzin tocim na OMW-u imam drugara koji je radio tu i preporuka svakako za nju...Kakve veze ima tvoj drugar koji je radio na OMV-u ? On je tamo pravio gorivo ili radio na crevu Quote Share this post Link to post Share on other sites
Sasa_NS 54 Posted December 13, 2014 79.90 gas u NS-u na više mesta, a verujem da ima i još niže. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 13, 2014 jebes te pumpe deki,veki,miki i ostal opametno i ja gledam da benzin tocim na OMW-u imam drugara koji je radio tu i preporuka svakako za nju...Preporuka zato sto je tvoj drugar radio?A zato sto su se meni cule dizne sa maxmotion dizelom zadnji put jel i za to preporuka, ili zato sto su na omv-u u surcinu nasuli caletu pun rezervoar vode umesto bezolovnog jel i za to preporuka? Oce tvoj drugar da refundira te troskove posto je on izgleda garancija za kvalitet?prolazim sinoc pored KNEZ pterola, cini mi se da je ED ispod 140 Dzaba im i da je ispod 120 Dzaba im brate moj.jebes te pumpe deki,veki,miki i ostal opametno i ja gledam da benzin tocim na OMW-u imam drugara koji je radio tu i preporuka svakako za nju...Kakve veze ima tvoj drugar koji je radio na OMV-u ? On je tamo pravio gorivo ili radio na crevu +1 Quote Share this post Link to post Share on other sites
neshaoct 9740 Posted December 13, 2014 Polako Kuvalja, kakve veze ima čovek sa postupanjem neke pumpe u okviru franžize OMV? Ton tvog posta kao da je malte ne on odgovoran za rad OMV pumpi u Srbiji. Ja sipam na OMV godinama unazad i sve je ok. Isti taj Maxx Motion evro dizel. Očigledno da nije samo stvar brenda, nego i konkretne pumpe.Sećam se da je Boki davnih dana na NIS-u, i to na Dejtonci sipao evrodizel u Stila, i posle 200 metara na penjanju na Brankov most eto lampice za vodu u gorivu i ugasi se auto. Epilog...bio jak pljusak tokom noći, probila se voda, otvorili pumpu, on je bio među prvima koji su sipali ujutro i eto problema. Ali, nije svaka NIS pumpa sa tim problemom, verovatno su i na Dejtonci do danas sredili te svoje odvode kako im ne bi opet voda ušla u rezeorvare. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 13, 2014 Ma sta bre polako, nema nista polako Ma nema decko nista sa tim, nego kad je napisao za drugara koji je radio, pa kakve veze ima sto je on radio, deluje mi napisano kao neka garancija kvaliteta, pa sam se na to ja nadovezao, i namerno takvim "tonom" da decko skonta poentu, nisam mislio njega da uplasim, napadnem uvredim...... p.s. znas ti kakvim ja tonom pricam i znas da je ovo ovako sve blago u odnosu na uzivo Quote Share this post Link to post Share on other sites
neshaoct 9740 Posted December 13, 2014 Ako neka od sledećih verzija foruma bude imala audio opciju, biće isključena samo zbog tebe. Quote Share this post Link to post Share on other sites
milos66 39 Posted December 13, 2014 Decko je duzi niz godina radio tamo, verovatno je da ima problema na svakoj pumpi ima problema, ne kazem da su idealni sipaj gde god hoces meni ni u dzep ni iz dzepa... Tamo imaju neke senzore ne znam vec kako se to strucno zove u rezervoarima koji cim primete vodu cela se cisterna prazni i to garantujem zato sto je stvarno tako,drugo uvek je tacna doza znaci sipas 5l siapo si 5l... pouzdano znam da imaju i kvalitetno uvozno gorivo, ja sipam dosta dugo tamo nikada nisam imao problema kao i mnogi nasi drugari...smatram da je mnogo bolje i sigurnije sipati na molu,omw-u,nisu nego na vekiju dekiju mikiju... jebes te pumpe deki,veki,miki i ostal opametno i ja gledam da benzin tocim na OMW-u imam drugara koji je radio tu i preporuka svakako za nju...Kakve veze ima tvoj drugar koji je radio na OMV-u ? On je tamo pravio gorivo ili radio na crevu hahahaha... neeeeeeeee on kosi travu nema veze sa pumpom .. hahahahaah Quote Share this post Link to post Share on other sites
