OMP 2215 Posted October 14, 2022 i ja sam tako radio na vise auta, razredjivac ili antisil, po potrebi smirglanje vodenom i na kraju boja bez ikakve podloge, moze spric kit i ne mora, za zavrsnu koristim klasican mat crni sprej i nije bilo nikad problema Quote Share this post Link to post Share on other sites
darkman14 5900 Posted October 14, 2022 @PremieRacing ljudi na librama imaju istih problema Quote Share this post Link to post Share on other sites
OMP 2215 Posted October 14, 2022 (edited) ma mnoga kola imaju taj problem samo zavisi od modela i samog auta kako je odrzavan tj da li je mazan nekim hemijama i sl. posto kontam da to dosta utice na tu lepljivost Edited October 14, 2022 by OMP Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted October 31, 2022 (edited) Subotu ujutru upalio Amfibiju, prešli cca. 1000km, sinoć je vratio u garažu... prezadovoljan! Edited October 31, 2022 by PremieRacing 3 Lufti, nemanja84bg and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted October 31, 2022 U subotu vidjena jos jedna amfibija u Novom Sadu, bordo boja, austrijske table. Sva sreca pa je tvoja bila van grada, jer je moglo doci do onog WARP-a o kojem sam pricao pre par strana 2 1 PremieRacing, nemanja84bg and darkman14 reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted October 31, 2022 (edited) Leleeeee, dobro smo prošli, mogomo da najebemo... Edited October 31, 2022 by PremieRacing 1 Dale reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1310 Posted October 31, 2022 (edited) Suri amfibija! daj da vidimo taj svemirski kokpit kako izgleda Edited October 31, 2022 by nemanja84bg Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted October 31, 2022 On 5/9/2022 at 11:14 PM, horvat said: ... On 7/17/2022 at 11:06 PM, PremieRacing said: On 7/20/2022 at 7:40 AM, PremieRacing said: On 8/17/2022 at 1:31 PM, PremieRacing said: https://www.google.rs/search?q=avantime+interior&sxsrf=ALiCzsbGfRJ017o6U3__49qNeX24DaSPtg:1667216817173&source=lnms&tbm=isch&sa=X&ved=2ahUKEwj3s5rRsor7AhVUX_EDHZtqBHAQ_AUoAXoECAIQAw&biw=1600&bih=761&dpr=1 2 horvat and nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1310 Posted October 31, 2022 Lepa lepa, koza klima allinclusive varijanta Quote Share this post Link to post Share on other sites
Lufti 690 Posted October 31, 2022 Fali lamperija....Sent from my SM-A805F using Tapatalk 1 nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
nemanja84bg 1310 Posted October 31, 2022 (edited) Kolko dugo nisam cuo taj izraz, lamperija hahahaha Edited October 31, 2022 by nemanja84bg Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted November 28, 2022 Napokon zamenjen termostat... Od početka znam da je bio loš, bilo leto pa nismo žurili, probao da kupim u NS i nigde nisam našao pa se bivši diler ponudio da pomogne. Dobio sam na poklon punu kesu novih originalnih delova a među njima i termostat. Odvezem Amfibiju prošle subote na prostu zamenu kad ono - prc. Termostat ne odgovara! Jbt, po broju šasije mi je čovek dao... Nema veze, ostavimo za ponedeljak, drugar majstor nađe gde može da se poruči, ne dođe u utorak, dođe u sredu, njemu gužva, četvrtak slava, petak gužva i tako... Amfibija stajala 8 dana rasklopljena 2 igor0511 and Milutinac reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 6, 2022 (edited) Vraćen zimski set točkova... Smorio sam se što sam morao da skinem distance, ali fabrička 17" sa 225/55 kači podkrilo sa distancima, a 19" sa 225/45 prolazi bez problema. Nisam računao i upoređivao, Ne znam sve spec točkova, ali je evidentno da ima razlike i da će zima da se fura bez wide stance Novih fotki nema, al' izgleda baš ovako...: On 3/26/2022 at 11:25 AM, PremieRacing said: Vs ovako: On 4/22/2022 at 4:38 PM, PremieRacing said: Edited December 6, 2022 by PremieRacing 4 Woodoo, Bokesh, horvat and 1 other reacted to this Quote Share this post Link to post Share on other sites
jevta 251 Posted December 6, 2022 (edited) Ofset ne znam https://www.wheel-size.com/calc/?wheel1=225-55-17X7ET45&wheel2=225-45-19X7.5ET40&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm Edited December 6, 2022 by jevta 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 6, 2022 Znam sve to, računao sam zilion puta kad sam kupovao 19-ke, ali nikad nisam dodao 20mm distanc na fabrički set up i eto ti ga...ispade da ne može Quote Share this post Link to post Share on other sites
igor0511 2882 Posted December 6, 2022 (edited) Obe felne su lepe, taman malo da promenis a distancere bolje da nemas zimi, bice ti sasija zahvalna Edited December 6, 2022 by igor0511 Quote Share this post Link to post Share on other sites
Ivan 17670 Posted December 6, 2022 Ta 225/55/17 guma ti teoretski ima cak i nesto manji obim od 225/45/19. Sirina gume ista. Tako da ostaje jedino da je ET 17'' felne dosta manji i da je otera napolje i nadoknadi i vise od 2 cm distanca. Dodatno je sigurno 19'' felna sira od fabricke 17''. Offset 17'' felne, nema sta drugo da bude . Sigurno je, po mom skromnom misljenju, ako struze - ET kod 17'' bar 3 cm manji od ET na 19'' setu. Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 7, 2022 Da jbt, prosta matematika, al' mi baš neverovatno da je ET manji za celih 30...pogledam pa javim. Quote Share this post Link to post Share on other sites
Dale 6810 Posted December 7, 2022 30 minutes ago, PremieRacing said: prosta matematika Matematika je jasna... 1 1 PremieRacing and Lufti reacted to this Quote Share this post Link to post Share on other sites
Ivan 17670 Posted December 7, 2022 33 minutes ago, PremieRacing said: Da jbt, prosta matematika, al' mi baš neverovatno da je ET manji za celih 30 Zasto? Pa i sam offset moze da bude pozitivan, negativan i Zero offset. Samim tim i prilicne razlike . Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 8, 2022 Zato što je u pitanju fabrička Renolova feluga... Kad si video fabričku felnu sa zero ili - offsetom Quote Share this post Link to post Share on other sites
Ivan 17670 Posted December 8, 2022 Fabricke felne obicno imaju offset od 30-40 mm u plusu. Ocigledno je caka u toj vecoj 19'' felni i da je ona poprilicno uvucenija. Cim trazi 20 mm distanc, a dodatno je vrlo verovatno i sira u odnosu na 17''. Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 9, 2022 Ako je verovati tire calculatoru, evo ih dimenzije i razlika... https://www.wheel-size.com/calc/?wheel1=225-55-17X7.5ET42&wheel2=225-45-19X8.5ET49&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm Našao sam sve dimenzije točkova prema proizvođaču: https://www.wheel-size.com/size/renault/avantime/2002/ https://www.wheel-size.com/size/jaguar/xj/2008/ (u prilogu slika iz fabričkog kataloga) Kad sam kupovao 19" felne gledao sam ovo zilion puta i sećam se da je bilo maltene identično. E sad, na 19" sam montirao distance i nisam imao nikakav problem, a sada kad je majstor vratio fabričke 17" - navodno kače i prete da otkinu prednji branik kad se mota volan Nisam bio prisutan pa sam tog trenutka morao da mu verujem na reč, ali prema ovim gore informacijama to nema šanse da je moguće pošto je 17" svakako 6mm 'uvučenija', i sa distancerom i bez. Rebus koji ću sam morati da rešim, samo me mrzi da šarafam točkove... Ali u nekom trenutku ću se naterati pa javljam. 1 horvat reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted December 9, 2022 (edited) Po meni je za zimski set fabricki izgled sasvim ok bez distanci, izgleda top. Jedno pitanje koje ti ne resava problem, koji ti je promer rupa? Edited December 9, 2022 by dellas 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted December 9, 2022 (edited) glupavi 5x108 Edited December 9, 2022 by PremieRacing Quote Share this post Link to post Share on other sites
