rkoma1986 1113 Posted February 27, 2020 Neka mi je bog u pomoci Quote Share this post Link to post Share on other sites
Desmo 430 Posted February 27, 2020 Nisu cesti slucajevi. Kolegi je na 120.000km pukla klipnjaca, posle toga su mu ubacili nov motor i nije imao problema. Auto jos uvek radi ima 470.000km ukupno. Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted February 27, 2020 Zato se polovnjaci uzimaju sa 150.000km, sto je crklo crklo je dotle Послато са Mi MIX 2 помоћу Тапатока 1 djomla reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted June 2, 2020 (edited) Zeni stigao novi objektiv pa smo se malo igrali Edited June 2, 2020 by Ivan Sredjene slike 5 totti, neshaoct, Milutinac and 2 others reacted to this Quote Share this post Link to post Share on other sites
zunto 517 Posted June 2, 2020 VW je sa b6 napravio dizajnerski bum, tesko da ce ikada vise izbaciti nesto ovako avangardno. Bravo za slike 2 rkoma1986 and darkman14 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted June 2, 2020 Slazem se. Bas velika razlika u odnosu na prethodni model sto se dizajna tice Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted June 2, 2020 Ali b5.5 je bio a4 ispod lima, a b6 je golf sa gepekom Sad mi je b6 legao, kao i recimo w211 i e60, ali kad su izasli pre 15ak godina bas sam ih hejtovao Quote Share this post Link to post Share on other sites
nstyner 171 Posted June 2, 2020 Dobre komšo! 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted June 3, 2020 8 hours ago, vagenovac said: Ali b5.5 je bio a4 ispod lima, a b6 je golf sa gepekom Sad mi je b6 legao, kao i recimo w211 i e60, ali kad su izasli pre 15ak godina bas sam ih hejtovao Ja i dalje hejtujem e60. Nije mi jasno kako su posle e39 uspeli tako da zajebu stvar. Naravno, sve je stvar ukusa 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 3, 2020 Takva je moda bila kod svih izgleda 1 vagenovac reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted June 3, 2020 Odbi od Pasata!!! Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted June 9, 2020 Negde na prethodnim stranama sam navodio problem sa gubitkom tecnosti, pa je najveca sumnja bila na glavu motora i trosak od xxx eur. Danas resen problem, hladnjak ulja je prosvirao. Usput zamenjena i creva koja su bila dosta porozna. Sad ostaje da pratim nivo tecnosti, nadam se da je to to. Tj hladnjak je sigurno pustao, ima i trag, a ja se nadam da je samo to bio problem 2 djomla and MS PK reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 9, 2020 Pustao spolja ili unutra? Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted June 9, 2020 Spolja... skroz je propao na kraju gde ide crevo , ne znam od cega tako da korozira Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 9, 2020 Od kvaliteta i zuba vremena Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted July 16, 2020 Ostadoh danas bez poklopaca na Strandu... Kao i svi koji su bili parkirani ispod mosta... Uhh al sam se iznervirao, jako bi voleo da vidim ko je taj brban koji u 9 ujutru dodje s namerom da odradi ceo parking Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted July 16, 2020 Dve matore debele ciganke kradu na limanu, pa verovatno i na strandu. Uvek sam zamisljao da to radi neki narkoman i kako bih ga polomio da ga uhvatim na delu, a onda vidim dve debele ciganke sto skidaju cepove i trpaju u ceger. Sta da im radis, izderes se na njih i uzmes svoje cepove... Quote Share this post Link to post Share on other sites
darkman14 5900 Posted July 16, 2020 Meni su na Limanu skunuli isto. Ali ih ne nadjoh ni na najlonu posle Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted July 16, 2020 On 7/16/2020 at 12:33 PM, rkoma1986 said: Ostadoh danas bez poklopaca na Strandu... Kao i svi koji su bili parkirani ispod mosta... Uhh al sam se iznervirao, jako bi voleo da vidim ko je taj brban koji u 9 ujutru dodje s namerom da odradi ceo parking Kad poranis ne valja raditi samo 5 automobila, radis ceo parking. Quote Share this post Link to post Share on other sites
Dale 6810 Posted July 18, 2020 Koji smor... Prvo sto mi je palo na pamet kada si ih kupio je bas lepe, ali imaju poklopce. Nisam hteo da kazem i malerisem. Ja sam odustao par puta od lepih felni samo zato sto imaju poklopce, ne zelim da se nerviram. Evo twingo smo kupili bez poklopaca i ne mogu nigde da nadjem da ih kupim. Renault samo fura felne sa poklopcima, inace bih zamenio felne za neke fabricke bez. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted July 18, 2020 Ja nisam bio toliko pametan da odustanem od felni zbog poklopaca... Al danas sam kupio poklopce od nekog tipa iz NS (mozda sam kupio i moje ) i stavio felne na oglase.. naravno, poklopce nisam montirao Quote Share this post Link to post Share on other sites
Ivan 17670 Posted July 18, 2020 33 minutes ago, rkoma1986 said: Al danas sam kupio poklopce od nekog tipa iz NS (mozda sam kupio i moje ) Za ovih deceniju i kusur koliko vozim Fiate, izmenjao sam nekoliko OEM kompleta felni. "Pametnjakovici" su na svim predvideli i poklopce, tako da cim stignu u moje ruke, skinem ih i svaki poklopac obelezim lemilicom sa unutrasnje strane. Eto, 'leba ne jede, a mooooozda pripomogne u situacijama kao ova. Pravili su ovde svojevremeno i tutorial kako bar malo osigurati poklopce srafcicima (a i na taj nacin ih oznaciti i odbiti pilicare). Mada, da kucnem u drvo, nikada mi nije zafalio ni jedan do sada, pa se nisam nesto opterecivao oko osiguravanja istih. Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted July 18, 2020 Ja sam ove bio 'obezbedio' vezicama, posto poklopci imaju 6 rupica pa sam odradio to da bude dosta neprimetno sa providnim vezicama. I to sam uradio da ih ne bi neko skinuo ako slucajno vidi pa mu trebaju. Al ovako kad neko krene u akciju sigurno da nosi secice sa sobom i da, danas sam provalio da na jednoj felni fali jedan sraf. Ne znam da li mu je trebao taj jedan sraf il je kreten hteo i felne da mi skine pa je odustao kad je skontao da na svakoj felni ima po jedan sigurnosni sraf 1 Bingodalton reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted July 31, 2020 (edited) Igrao se sa folijom.. u sustini sam prezadovoljan kako je ispalo s obzirom da sam prvi put radio. Malo sam se smorio kad sam skontao da je dosta osetljiva na ogrebotine, ovaj deo oko klime treba opet da odradim jer sam ga slucajno zagrebao noktom. Ali preporucujem svima da se igraju, jako je lako za rad u sustini Edited July 31, 2020 by Ivan Sredjene slike 5 darkman14, Bingodalton, totti and 2 others reacted to this Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted September 9, 2020 Osle one felne s poklopcima... Josnjedno iskustvo da vise ne uzimam felne s poklopcima gde poklopac cini pola same felne. Uzeh opet 16, GamaParts. Felne mi nisu nesto preterano lepe, nisu ni ruzne, sto bi rekli, nit smrdi nit mirise. Al sam ih uzeo najvise jer su bile u kompletu sa Yokohama zimskim gumama koje su bukvalno kao nove. Sve zajedno za 200 e, sto je po meni bas povoljno. Gelne su isto bas ocuvane, uglavnom sve koje sam gledao su iskrzane po rubovima, ostecene manje ili vise. Naravno, ima i ocuvanih al je cena onda mnogo veca. I jos mi odgovara sto su gume zimske tako da sad mogu da prodam i svoj zimski set na celicnim felnama i da sledece godine auto udam samo sa jednim setom jer svakako necu nista visen zvuci ako dam oba seta 2 alfini0507 and MS PK reacted to this Quote Share this post Link to post Share on other sites
