Milutinac 5906 Posted August 28, 2019 Dzaba, kasno si javio. To sam vec obavio aj sutra 1 hour ago, PremieRacing said: Toooooooo, 100 strana Aaaaa ti mora da ides na forum preko tapatalka, pa zato 100 strana. Mi preko obicnih pretrazivaca smo tu brojku odavno presli. Mi smo na 116 trenutno... Quote Share this post Link to post Share on other sites
totti 13165 Posted August 28, 2019 Na TT je 2 Milutinac and horvat reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted August 28, 2019 (edited) Chrome, isto je i na Desktop verziji. Edited September 3, 2019 by neshaoct postavio sliku na FLCS server Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted August 28, 2019 Aaaaaaa. Mi zeleni vidimo i obrisane/sklonjene postove, pa eto ima cak 16 strana obrisanih postova Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted August 29, 2019 'El ti sad jasno Aj da platiš doručak... Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 3, 2019 Cetvorke. Ko zeli da cestita nek cestita... 2 horvat and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 3, 2019 Evo i korekcija. Pa da vidimo razliku pre/posle. Cilj je da se srede korekcije, zamene podloske i da vidimo da li ce peak NM otici u levo i koliko Quote Share this post Link to post Share on other sites
darkman14 5900 Posted September 3, 2019 (edited) 16 minutes ago, Milutinac said: Kako ti to baš monitor crkao na Desired intake air quantity? A ova četvrta izgleda po defaultu mora da odstupa, kako nije negde između prve 2 ili oko njih Edited September 3, 2019 by andreja.micovic falilo mi intake 2 1 Danilo1, dekirs and MS PK reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 4, 2019 On 9/3/2019 at 8:31 PM, andreja.micovic said: Kako ti to baš monitor crkao na Desired intake air quantity? Pa zna gde treba i ti se igras sa opasnim recima, pripazi ako ne na protokomander onda na frizider, tv, mikro-rernu... 2 1 alfini0507, dekirs and horvat reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted September 4, 2019 Dobro Milutine, mislim da smo dovoljno glumili Daj lepo ljudima presek stanja koliko si ulozio dok si vozio benzinca i koliko dok si vozio dizela pa da te vratimo na redovno gorivo 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 4, 2019 (edited) Manje je kostalo to sve na HGT-u naravno, ali ima i manje delova, a ni ja tada nisam bio toliko lud... o_0 Ja se ne zezam - navukao sam se... Edited September 4, 2019 by Milutinac Quote Share this post Link to post Share on other sites
horvat 6457 Posted September 4, 2019 Manje je kostalo odrzavanje, al zato 5.3 l/100 km do Gr, pa ti racunaj kolko je tu dizni, zamajaca i protokomandera ustedjeno 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted September 4, 2019 Lako je sada kad ima farmu protokomandera 2 horvat and marko.jovanovic reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 4, 2019 Nije mala stvaaar rodjaaaci Just now, dekirs said: Lako je sada kad ima farmu protokomandera Proto rig 2 dekirs and horvat reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted September 4, 2019 Cetvorke. Ko zeli da cestita nek cestita...Koja kinta druze i gde? Sent from my Redmi Note 3 using Tapatalk Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 4, 2019 Dule iz Sr. Karlovaca. A za kintu videcemo - tek evo danas ih nosim... Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted September 4, 2019 Aj javni kad bude gotovo... Moze i na pm ako je neki problem ovde... Sent from my Redmi Note 3 using Tapatalk 2 Milutinac and Martin reacted to this Quote Share this post Link to post Share on other sites
Ivan 17679 Posted September 5, 2019 On 03/09/2019 at 8:14 PM, Milutinac said: Cilj je da se srede korekcije, zamene podloske i da vidimo da li ce peak NM otici u levo i koliko Ovo poslednje, tj. torque graph i mene izuzetno zanima za 1.6 i 2.0 (koje sam btw gledao i za sebe). Koliko ce sa tvojom pedanterijom, fabricki setup (bez pomoci chipa) moci da se priblizi onome sto kazu grafikoni. Ovo sto ja probah (ukljucujuci i odrzavano), grizlo je u piku sa min 2200-2300 rpm pa navise i uz jos par stvari je uticalo na konacan izbor. Pratim temu i rezultate operacije . 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 5, 2019 Neke informacije koje sam nalazio je da posle ovog zahvata peak koji je pomeren na desno obicno se vrati "unazad" za nekih 300-400rpm, sto bi kod mene dovelo na nekih 2200-2300rpm ali ne subjektivnog osecaja, vec grafike na valjcima... I moj bi subjektivni osecaj bio da ovo moje sokocalo najvise grize oko 2400 recimo, dok grafika na valjcima ipak crta peak na nekih 2700. E sad sta ce zaista desiti, ja se nadam da cu videti vec sutra Nego Ivanski, daj ti meni ideju kako peak da vratimo na fabrickih 1850 nitrious oxide hmmmm? Quote Share this post Link to post Share on other sites
horvat 6457 Posted September 5, 2019 A ima li to mozda veze sa tim sto su ti fabricki podaci sa merenja motora na stolu, a da zapravo teret svega vuce to malo u desno? Jer kao sto ni konjskih snaga nemas na tocku, 165ks tako mozda ni krivulja snage nije bas skroz ista (u smislu ovih pomeranja bas)? S tim da gubitak kroz transmisiju mogu da sracunaju, ali pomeraj krive verovatno ne? Nemam pojma, ne tvrdim da je ovo ovako, samo razmisljam 'na glas' Quote Share this post Link to post Share on other sites
dekirs 4819 Posted September 5, 2019 Hahaha, samo mu vuce u desno 2 2 horvat, Ivan, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
Ivan 17679 Posted September 5, 2019 Ma to je samo zbog nagiba puta . 21 minutes ago, Milutinac said: Nego Ivanski, daj ti meni ideju kako peak da vratimo na fabrickih 1850 nitrious oxide hmmmm? Ako obezbedis neku da upravlja, nas dvojica mozemo da dodamo jedno 2 konja i koji Njutn : 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted September 5, 2019 Pffff, necu ni da se mucim, za ta dva konja cu radije da zalepim dve KaEn nalepnice... 1 1 horvat and dekirs reacted to this Quote Share this post Link to post Share on other sites
