Stex3105 107 Posted April 11, 2020 Presvuceno nebo i stubovi 4 ISV_01, PremieRacing, darkman14 and 1 other reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4033 Posted April 11, 2020 Nemoj samo da ga ucrnis previse Odlican bravko. Quote Share this post Link to post Share on other sites
Stex3105 107 Posted May 27, 2020 5 MiloshShomy, Martin, neshaoct and 2 others reacted to this Quote Share this post Link to post Share on other sites
Stex3105 107 Posted June 30, 2020 Nesto novo Klesta od Tuarega 5.0 v10 prednja sestoklipna zadnja cetvoroklipna. Diskovi od alfe 166 prednji 310mm zadnji 280mm ventilirajuci. Koci odlicno. Ostalo mi jos da napravim elektricnu rucnu. 7 neshaoct, PremieRacing, Mijailović P. and 4 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7734 Posted June 30, 2020 Sve si uradio da stane, samo jos da ga nesto pokrene, onako u skladu sa ovim 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Stex3105 107 Posted June 30, 2020 (edited) Bice nekada neki nabrijani 1.4 t-jet ali ima vremena Edited July 4, 2020 by neshaoct formatiranje 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
MiloshShomy 114 Posted June 30, 2020 Treba obuzdati tu masinu, nego koje prepravke si odradio da ukopis sve? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted June 30, 2020 (edited) Samo ploca izmedju fabrickog nosaca i klesta ovih. Ima malo zajebancije dok se sve mere uhvate ali nista strasno. I ostao je fabricki glavni kocioni mislim da je 22.2mm velicine i peti kocioni pozadi koji fabricki nije zakacen za balans stanglu verovatno je samo razdelnik biiip li ga nisam mu shvatio svrhu. Edited July 4, 2020 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
miljanxXx 26 Posted July 1, 2020 A stare zadnje diskove i klesta od hgt prodajes? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted July 2, 2020 (edited) Nisu na prodaju brate Edited July 4, 2020 by neshaoct formatiranje Quote Share this post Link to post Share on other sites
Stex3105 107 Posted July 4, 2020 2 neshaoct and Sedla reacted to this Quote Share this post Link to post Share on other sites
Stex3105 107 Posted July 11, 2020 2 neshaoct and MiloshShomy reacted to this Quote Share this post Link to post Share on other sites
Stex3105 107 Posted September 3, 2020 Decaci da li neko zna gde mogu naci menjac od punta 1.2 16v sa 6 brzina? Moj se malo prosuo po putu.... Quote Share this post Link to post Share on other sites
Sedla 2576 Posted September 4, 2020 Jesi gledao ovde na ulasku u AR? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted September 4, 2020 Nadjoh danas u bgd. Sutra sledi montaza. Uglavnom izbacen je 1.2 16v i ubacen 1.4 16v od 95 ks. 1 Martin reacted to this Quote Share this post Link to post Share on other sites
Stex3105 107 Posted September 7, 2020 (edited) sve je spakovano radi sve super. Znaci motor je 1.4 16v 95ks menjac sam drugi stavio punto dvojke 1.2 16V. E sad mene interesuje ima li ko strucan da me posavetuje sta da radim. Sada je motor 1.4 sa instalacijom kompjuteromi svim agregatima od 1.2. On sad sigurno ne moze da ima 95ks kao fabrika. sta ciniti sta menjati? da bi dosao na to da ima 95 ks kao sto je u puntu? Sto sam saznao da sto se tice agregata da je usis,klapna gasa,izduv isti ka na 1.2. Dizne od 1,2 imaju malo vecu kubikazu nego 1.4 ali to nije neka velika razlika. jedino ostaje samo kompjuter. Sto se tice motora glava ventiuli usis izduv su isti. razlika je u velicini klipa a za hod klipa i radilicu nisam nasao podatak... Edited September 7, 2020 by Stex3105 Quote Share this post Link to post Share on other sites
MS PK 7734 Posted September 7, 2020 Pa jel radi? Quote Share this post Link to post Share on other sites
Stex3105 107 Posted September 8, 2020 radi sve super na ovu moju instalaciju i komp. Ali verujem da nema sanse da ima tih 95 ks sa mojim kompom Quote Share this post Link to post Share on other sites
MS PK 7734 Posted September 8, 2020 Izmeri ga negde Quote Share this post Link to post Share on other sites
Stex3105 107 Posted September 8, 2020 icice kad budem odradio sve sto treba Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted September 8, 2020 Odes izmeris i dogovoris odmah mapiranje Quote Share this post Link to post Share on other sites
Stex3105 107 Posted September 8, 2020 to cu lako nego me sad muci sto ne znam da li moj komp od 1.2 moze da se mapira isto kao od 1.4.... Da li 1.4 moze da se mapira na vise ks nego ovaj od 1.2 to je sad muka Nose istu oznaku Bosch ME73H4F Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted September 8, 2020 Pa to obicno znaci da su im funkcije iste, razlikuju se mape samo u njima. Ako su svi delovi isti kao sto kazes sem brizgaljki, trebalo bi da mozes da upises samo mapu od 1.4 i da resis problem. Zato kazem, uzmes cipujes ga odmah Quote Share this post Link to post Share on other sites
Stex3105 107 Posted December 21, 2020 Zimski set :D Quote Share this post Link to post Share on other sites
Sedla 2576 Posted December 21, 2020 Gay. 2 neshaoct and Stex3105 reacted to this Quote Share this post Link to post Share on other sites
