Ivan 17679 Posted July 28, 2017 Tako sam i ja pricao . Je*o ga Zabar, tera jos za sve pare. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted July 28, 2017 7300din komad u Bogunovicu pa x 2 za ona dva mala g...nceta . Nece da moze Ce tera i sa Lemforderom, Febi i ostalima Quote Share this post Link to post Share on other sites
djomla 8386 Posted July 28, 2017 Će gi teraš dok ne ripi Uf, pa nije baš povoljno. Si gledao Birth? Ili kako se već zove. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted July 28, 2017 Swag 2200din, Febi 2576din al moze nesto manje i Akron oko 2000, tipa 1800din al mislim da je greska. Cekam da mi have cenu jos za taj Lemforder Quote Share this post Link to post Share on other sites
Markobgd 609 Posted July 28, 2017 Pa kako majku mu sad. Ja bio ubeđen da je to sve isti q. Delta, Stilo, Bravo Za Deltu donji bez popusta iz originala cca 6000din zamenski koje sam našao po prodavnicama išli od 3600 do 5500din Quote Share this post Link to post Share on other sites
djomla 8386 Posted July 28, 2017 @Markobgd ma čim ti nemaš onaj prekidač, ko zna kakve si i nosače nalazio Quote Share this post Link to post Share on other sites
MS PK 7734 Posted July 28, 2017 Pa isti jeste al stilo nema 2.0mjt Bogu hvala , i onda kakve veze ima? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted July 28, 2017 Ništa Bogu hvala! Turaj Swag i nek trese samo Quote Share this post Link to post Share on other sites
djomla 8386 Posted July 28, 2017 Bar neće se brineš za kamen u bubregu Quote Share this post Link to post Share on other sites
MS PK 7734 Posted July 28, 2017 Nek se trese on, necu ja za njega Quote Share this post Link to post Share on other sites
Djura87 2 Posted July 29, 2017 1.8 na jtd manje vibracije jer je tvrdja guma samo treba duzi sraf,jeftiniji a sad to kinez italijan isto sve se u kini pravi drugo i na cipsu pise neto 100grama a bruto 70grama. naso sam 4800auto mika,a donenje srednje rekete sam menjao oba 3000sa popostom preko druga levi duzi desni kraci. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted July 29, 2017 Ma tako je...sve to isto Quote Share this post Link to post Share on other sites
morke 0 Posted September 17, 2017 Imam problem sa Stilom 1.9 JTD pri drzanju gasa ceo auto trese a cim se drzi ista brzina auto mirno radi.npr kad se ubrzava iz trece u cetvrtu dok drzim gas trese i kad ubacim u cetvrtu i odrzavam istu brzinu motor mirno radi a cim opet pipnem gas pocne opet da trese auto.Da li je do nekog nosaca ili zamajac.pozz Quote Share this post Link to post Share on other sites
Ivan 17679 Posted September 17, 2017 Proveri za svaki slucaj banalnu stvar - da li su ti stegnuti srafovi na tockovima. Osim pomenutog, uzmi u obzir da moze da bude i krst poluosovine, baci pogled i na tu temu: Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted October 2, 2018 preporuka za "koske i reket", gde uzeti? koja je cena itd.. Bravo 1.9 150 Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted October 2, 2018 Izbegavas acron. Trazis ili original deo ili eventualno SWAG. I ja cu uskoro sva 4... 2 Danilo1 and neshaoct reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 2, 2018 Napukla su mi oba prednja nosaca (onaj ispod akumulatora i onaj desno) pa bi ih valjalo zameniti (a i vibrira dosta u kabini), zadnje nisam gledao. Gde uzeti i koje traziti? Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted October 3, 2018 @Flex Originalne. Ali, biće skupi. Baš skupi. Onaj ispod akumulatora još i nekako, ali onaj bočni... Možda da probaš sa novim tim ispod akumulatora, i polovnim onim bočno. Quote Share this post Link to post Share on other sites
Ivan 17679 Posted October 4, 2018 Sto neko davno rece, kada je to bila prilicno zesca klempa po usima nego danas - kada vidim cenu desnog nosaca iz originala, odjednom shvatim da mi auto vise nema vibracija . 3 Pluto, neshaoct and bit reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 4, 2018 Veci mi je problem naci u ovom raspalom Krusevcu normalnog majstora (gde da pitam za preporuku, ima li tema?). Quote Share this post Link to post Share on other sites
MS PK 7734 Posted October 4, 2018 Nosace moze bilo ko da ti zameni, ne treba ti tu neki poseban majstor Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 4, 2018 Nisam mislio samo za nosace vec generalno za odrzavanje. Sve neki fuseri, daleko bilo. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted October 4, 2018 Tako ti je svuda, ne samo u Ks. ali svi deru lao pravi Quote Share this post Link to post Share on other sites
Ivan 17679 Posted October 5, 2018 13 hours ago, Flex said: Veci mi je problem naci u ovom raspalom Krusevcu normalnog majstora (gde da pitam za preporuku, ima li tema?). 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
