joshibeast 74 Posted January 9, 2015 Evo fotki koje sam obećao. Ne suditi o PK kaišu po spoljnom izgledu Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 9, 2015 A i zupcasti je menjan verovatno istog dana... Quote Share this post Link to post Share on other sites
simonen 81 Posted January 9, 2015 Samo se vi zaj*b*vajte,neki dan pre Nove godine mi dovukli na slep sluzbi Dobla 1.9 Mjet,2008god,zvali predhodno telefonom.Zamenili mu samo kais.....kazu skoro.Ugasio se na auto putu,vergla kao da nema klipove.Super,mislim ja.Skinem poklopac kaisa kad unutra blokirao lezaj pumpe za vodu i naravno otkinuo kais.Iskrivio sve izduvne i da usisna ventila.Soljice plocica ventila popucale...Sve u svemu delovi +ruke 50-tak hiljada.......Tako da predpostavke da je sve ok,samo kais .Dobronameran savet Quote Share this post Link to post Share on other sites
igor0511 2882 Posted January 9, 2015 50 000 za sve ili na to ide još i veliki servis? Quote Share this post Link to post Share on other sites
deki87 7 Posted January 9, 2015 Pise za delove+ruke namestanja,verovatno u te delove ulazi kais sa spanerima,dihtung glave,vod.pumpa,ulje i filter. Quote Share this post Link to post Share on other sites
simonen 81 Posted January 9, 2015 U cenu je uslo sve osim ulja i svih filtera,jer je to zamenio kada je menjao samo kais... Quote Share this post Link to post Share on other sites
igor0511 2882 Posted January 9, 2015 Baš dobra cena s obzirom na štetu. Zato sam i pitao da li veliki servis ulazi u to. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted January 9, 2015 Samo se vi zaj*b*vajte,neki dan pre Nove godine mi dovukli na slep sluzbi Dobla 1.9 Mjet,2008god,zvali predhodno telefonom.Zamenili mu samo kais.....kazu skoro.Ugasio se na auto putu,vergla kao da nema klipove.Super,mislim ja.Skinem poklopac kaisa kad unutra blokirao lezaj pumpe za vodu i naravno otkinuo kais.Iskrivio sve izduvne i da usisna ventila.Soljice plocica ventila popucale...Sve u svemu delovi +ruke 50-tak hiljada.......Tako da predpostavke da je sve ok,samo kais .Dobronameran savet Pa pumpa za vodu se čuje pre nego što zablokira ? Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 9, 2015 Cuje se kad znas da cujes i ako obracas paznju i otvaras haubu i cujes od dizelasa Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted January 9, 2015 Ovi mora da su gluvi ili slušali muziku glasno. Quote Share this post Link to post Share on other sites
hansf 1 Posted February 4, 2015 Kada treba raditi drugi veliki servis, posle 50, 60, 100kkm.....? je li ko radio? Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted February 4, 2015 Zavisi od delova koji su ugradjeni.Ako su kopije preporuka je na 50k ako su iz originala moze i kasnije. Quote Share this post Link to post Share on other sites
deki87 7 Posted February 4, 2015 Preporuka je izmedju 60-70hkm. Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted February 4, 2015 Zavisi i koliko je vremena proslo od servisa kao i uslova u kojima je auto vozen... Quote Share this post Link to post Share on other sites
deki87 7 Posted February 4, 2015 Ovo sam napisao za dayco setove ina,skf,mogu i kasnije Kod mene je dayco 3 pune godine i 68000km uskoro ide novi set. Quote Share this post Link to post Share on other sites
hansf 1 Posted February 5, 2015 To je ok, dayco i skf, imam vremena da uradim do odmora.... Quote Share this post Link to post Share on other sites
vujasin 11 Posted February 15, 2015 Je li se sa zupcastim remeno i njegovim spanerima mijenja obavezno i klinasti remen i njegove vodilice i spaner s obzirom da njegovo pucanje ne izaziva havariju motora Quote Share this post Link to post Share on other sites
Ticma 537 Posted February 15, 2015 Ne izaziva havariju motora ali te po pravilu ostavi u nekoj vukojebini uglavnom Quote Share this post Link to post Share on other sites
joshibeast 74 Posted February 15, 2015 A na nekim motorima može da se desi da se klinasti, kada pukne, podvuče pod zupčasti pa do havarije ipak dođe. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted February 15, 2015 Zna i da izazove havariju, tako sto kad pukne se podvuce kod remenice radilice i onda ode i zupcasti a tada znas koja je havarija, mislim da se 2000din ne treba kockati. Haha u isto vreme, bas tako. Quote Share this post Link to post Share on other sites
vujasin 11 Posted February 16, 2015 Koji proizvodac pumpe za vodu je najbolji:Metelli, valeo, ruville, magnetti-marelliKoji set zupcastog remenja bi izabrali:INAContitechSKF Quote Share this post Link to post Share on other sites
MS PK 7734 Posted February 16, 2015 Ja sam sve stavio Skf i bilo je malo skuplje od oruginala 12800din valhda bese set zupcastog Quote Share this post Link to post Share on other sites
vujasin 11 Posted February 17, 2015 Koje remenje ima skf i ina set zupcastog, a koje spannere i rolice ima set zupcastog contitech Quote Share this post Link to post Share on other sites
MS PK 7734 Posted February 17, 2015 Ne znam, nisam ni pogledao Quote Share this post Link to post Share on other sites
deki87 7 Posted February 17, 2015 Cini mi se da skf ima gates. Ja bih stavio INA. Quote Share this post Link to post Share on other sites
