Milutinac 5994 Posted June 2, 2017 2 hours ago, MS PK said: Zbog radi cega ? Turba? Da da da i pre sam mislio da lepo radi i puni turbo, medjutim tek sada sa novim vidim da znaci kada je nov, nastelovan kako treba itd 2 hours ago, Ivan said: Traktorska 3. i 4. za uzivanje u preticanjima i igranju po nekoj lepoj magistrali . Da da, bas tako Ps - na nizim obrtajima i ovako ostao lenj. Dzaba nova varijabila i sve. Opet bi mogao biti zivahniji ali sta da se radi, bar kad ga forsiram stvarno ide Quote Share this post Link to post Share on other sites
vagenovac 4627 Posted June 2, 2017 Bitno da je sve po PSu Sent from my KIW-L21 using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7980 Posted June 2, 2017 Takav je taj 2.0 izgleda. Chipuj ga, nema mu druge Quote Share this post Link to post Share on other sites
Zvezdo 1231 Posted June 2, 2017 Nema tu nista bez remapa! Quote Share this post Link to post Share on other sites
dekirs 4926 Posted June 3, 2017 Hocemo 200 konjica Mile! Sent from my SM-G935F using Tapatalk Quote Share this post Link to post Share on other sites
gorank82 186 Posted June 3, 2017 Neka je sa srećom nova turbina da je trošiš lagano Quote Share this post Link to post Share on other sites
Milutinac 5994 Posted June 4, 2017 On 6/3/2017 at 10:31 AM, dekirs said: Hocemo 200 konjica Mile I Mile ih hoce cim se vratim sa mora...cisto zbog mira u kuci I to idemo brze, jace, bolje...cipovacu ga na koliko god moze - pa kad se raspadne na sitne delice bar da znam zasto se raspao... On 6/3/2017 at 11:09 AM, gorank82 said: Neka je sa srećom nova turbina da je trošiš lagano Hvala vi. Ista je to turbaljka samo podmladjena Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted June 4, 2017 Pa sad kad si ga tako sredio valjda ce lepo da sluzi. I sa ga malo cipnes za svoju dusu i samo gas Quote Share this post Link to post Share on other sites
MS PK 7980 Posted June 4, 2017 A dobro onda, ti pre mora samo ispeglaj mapu, nemoj da dizes nista dok se ne vratis Quote Share this post Link to post Share on other sites
Timke 16 Posted June 4, 2017 Neka si je sredio, i uradio si to na pravom mestu. Nadam se da ste skinuli sito sa dovoda ulja. Nasviraj ga lepo sad, za sve pare kad znas da je ispravan! Jedno pitanje, nisam zapamtio od ranije, koje ulje sipas? Quote Share this post Link to post Share on other sites
Milutinac 5994 Posted June 5, 2017 (edited) 15 hours ago, Gagy.GM said: Pa sad kad si ga tako sredio valjda ce lepo da sluzi. I sa ga malo cipnes za svoju dusu i samo gas Bice bice 12 hours ago, MS PK said: A dobro onda, ti pre mora samo ispeglaj mapu, nemoj da dizes nista dok se ne vratis Nista ne cackam pre mora, jer kakve sam srece... 9 hours ago, Timke said: Neka si je sredio, i uradio si to na pravom mestu. Nadam se da ste skinuli sito sa dovoda ulja. Nasviraj ga lepo sad, za sve pare kad znas da je ispravan! Jedno pitanje, nisam zapamtio od ranije, koje ulje sipas? Pa skinuli karter i ocistili i odradili sve sto smo mogli. Zamenuli i gumicu uljane pumpe kada se vec petljalo oko toga Prvo sipanje sam kao isao za pocetak na sigurno pa sam sipao WR 5-30...a sada posle "operacije" meguin ultra performance 5-40 Edited June 5, 2017 by Milutin-NS Quote Share this post Link to post Share on other sites
nstyner 183 Posted June 5, 2017 Pa nećeš valjda da se Debeli raspadne na sitne deliće,kuku Milutinac !Samo lagano sa čipom,biće to ! Quote Share this post Link to post Share on other sites
Milutinac 5994 Posted June 5, 2017 Pa bar cu znati sto se raspao... Quote Share this post Link to post Share on other sites
Milutinac 5994 Posted June 9, 2017 (edited) Ako je neko slucajno pomislio da je mojim diesel mukama kraj...hahahaha Ono sto sam mislio da je lezaj (jer je nesto sitno brujao na pipkanje gasa) u pocetku i sad pred sam kraj - druk lager ispostavilo se da je...zamajac...uopa! Ono sto je zanimljivo je da se sam zamajac pre recimo mesec dana nista nije cuo, nista apsolutno, bukvalno je propao u roku od mesec dana do te mere da ne moze da se vozi...krklja na stisnuto kvacilo Zamajac poslat juce u Ostruznicu na remont... Edited June 9, 2017 by Milutin-NS Quote Share this post Link to post Share on other sites
@bane@ 102 Posted June 9, 2017 E otac je*o, koliko je remont? Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted June 9, 2017 Jbt ne verujem koji si ti maler, bas te hoce.Smor.Sent from my HTC One M9 using Tapatalk Quote Share this post Link to post Share on other sites
Ticma 548 Posted June 9, 2017 Dal je moguce sta te je sve poteralo bio sam u NS prosle nedelje ali nisam stigao da se javim Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
darkman14 6156 Posted June 9, 2017 Auuu, baš smor... Baš nema pravila kod polovnjaka Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted June 9, 2017 Ala te poteraloooo. Bem ti biiip...Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
MS PK 7980 Posted June 9, 2017 Brate to je baxuz auto. Sto bi mi juznjaci rekli " teraj to iz avlije sto pre " Послато са SM-J320FN уз помоћ Тапатока Quote Share this post Link to post Share on other sites
Ivan 18930 Posted June 9, 2017 (edited) Mico, ponudi mu tvoj Stilo i da ti doplati za 1.9 i dvoja vrata viska. Da ne stajem na muku sa zezanjem, ali stvarno ne verujem sta vise citam na ovo temi... Bas me zvrcnu Milutin nedavno, iskopah mu u Bravo eLearn kompletnu semu instalacije za prskalice farova, nesto su on i Dezurni sredjivali - reko' hvala Bogu pa se preslo na picajzlisanje, kad ono... Edited June 9, 2017 by Ivan Quote Share this post Link to post Share on other sites
Martin 812 Posted June 9, 2017 Au jbt žvt.... Aj samo jako i (nažalost) čekamo utiske sa remontovanim zamajcem. Šta je sa lamelom, korpom - sve ok ili si i to poslao na remont? Quote Share this post Link to post Share on other sites
Milutinac 5994 Posted June 9, 2017 (edited) 9 minutes ago, Ivan said: Mico, ponudi mu tvoj Stilo i da ti doplati za 1.9 motor i dvoja vrata viska. Da ne stajem na muku, ali stvarno ne verujem sta vise citam na ovo temi... Bas me zvrcnu Milutin nedavno, iskopah mu u Bravo eLearn kompletnu semu instalacije za prskalice farova, nesto su on i Dezurni sredjivali - reko' hvala Bogu pa se preslo na picajzlisanje, kad ono... E da, prskalice rade samo tako 16 minutes ago, MS PK said: Brate to je baxuz auto. Sto bi mi juznjaci rekli " teraj to iz avlije sto pre Odem na more, vratim se i u oglase. Neko ce dobiti nov zamajac, turbinu, kocnice, gume, protokomer, sredjenu usisnu, dpf off, egr off, veliki servis...ali sta je tu je, ja vise nemam zivaca a i smucilo mi se... 1 hour ago, Ticma said: Dal je moguce sta te je sve poteralo bio sam u NS prosle nedelje ali nisam stigao da se javim Javi se drugi put 1 hour ago, @bane@ said: E otac je*o, koliko je remont? 200-250e Edited June 9, 2017 by Milutin-NS Quote Share this post Link to post Share on other sites
Ticma 548 Posted June 9, 2017 Nemoj da ga prodajes pa tu vise nema sta da se pokvari Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
