Bingodalton 738 Posted January 13, 2018 Skoro pa u Gedoru upao. Steta za taj auto.http://www.polovniautomobili.com/putnicka-vozila/11031163/bmw-635-m-csiSent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted January 13, 2018 Ništa gedorasto, navlaka volana, patosnice i ručica menjača se izvade i bace za manje od 10sec. Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 13, 2018 Znas kako, nekom je i 10s vremena puno Sent from my SM-A510F using Tapatalk 1 PremieRacing reacted to this Quote Share this post Link to post Share on other sites
Axic 20048 Posted January 13, 2018 1 hour ago, Bingodalton said: nekom je i 10s vremena puno @totti ovo nesto na tvoj račun? Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 13, 2018 HahahaTo je na@Milutin-NS racun i skidanje nalepnica sa "Abarth" Punta.Zaista mi je nejasno da stavis te ciganske patosnice u ovaj auto, koji prodajes za ne male pare. U sustini sasvim sigurno sam i opisao prodavca.Sent from my SM-A510F using Tapatalk 1 Milutinac reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 19, 2018 Ako je neko zainteresovan Specification Phantom 2 is a new version of the 4x4 B6 Armoured Personnel Carriers (APC). Other than a 5 door configuration, with 360° gun turret and with two or three escape hatches, the Manufacturing allows you to customize the vehicles for the special clients needs and requirements. ENGINE TYPE 6.7 L V8 Turbo Diesel HORSEPOWER 300hp @ 2,800rpm DIMENSIONS W - 2,240 mm | L - 6,250 mm | H - 2,600 mm WHEELBASE 3,567 mm DRIVE CONFIGURATION AWD FUEL TYPE Diesel FUEL CAPACITY 257L SEATS 8 Seats (2+6) TRANSMISSION Automatic, Electronically controlled SUSPENSION Heavy Duty Reinforced Components STANDARD EQUIPMENT Automatic AC, 2 Units (Front & Rear) 8 Gun Ports (3 Left, 3 Right & 2 Rear) Run Flat Tire Devices Ballistic steel-case fuel tank protection Heavy duty front and rear ram bumpers PROTEK Crew Seats with 5 Point Restraint System Rear View Camera with Display Self Recovery Winch Roof mounted Escape Hatch OPTIONAL EQUIPMENT Independent Suspension Central Tire Inflation System (CTIS) FLIR Driver Aid System Blastek Floor Mat Roof mounted 360-degree turret with perimeter protection Navigation System Automatic Fire Suppression System Quote Share this post Link to post Share on other sites
silenci 2337 Posted January 19, 2018 posalji ovo cudo ministrima vojske i policije nase da vide,ima odma 500 komada da kupe Quote Share this post Link to post Share on other sites
Pluto 448 Posted January 23, 2018 @Ivan jel ovo ono sto trazis? Ne znam zasto nece da taguje..http://www.polovniautomobili.com/putnicka-vozila/11678007/fiat-bravo-19-multijet-acitveSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
lajsna 21 Posted January 27, 2018 https://www.polovniautomobili.com/putnicka-vozila/11656500/zastava-yugo-tempo-20-16v Quote Share this post Link to post Share on other sites
Pluto 448 Posted January 27, 2018 "auto bestan kako ide" Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 27, 2018 Jer centar ne mere Fiat http://www.polovniautomobili.com/putnicka-vozila/11560567/fiat-500l-trekking-34-000Sent from my 3310 Quote Share this post Link to post Share on other sites
Pluto 448 Posted January 28, 2018 Pozdrav, šta mislite o oglasu? Vidim da mu hauba malo krivo ide, ali to je na većini GP-a, ali mi baš lepo izgleda i ima sportska sedišta i 17 felne https://www.polovniautomobili.com/putnicka-vozila/11442731/fiat-grande-punto-13-mjtd I evo slika gde se vidi da hauba nije u ravni, ali to mi iskreno nije neki problem Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted January 28, 2018 Haubu nastelujes pomocu onih odbojnika... Auto izgleda donro i cena je ok. Jos da ima digitalnu klimu, bio bi top 1 Pluto reacted to this Quote Share this post Link to post Share on other sites
Pluto 448 Posted January 28, 2018 Da slazem se. Trebalo bi da odem do novog sada da ga pogledam, ako neko slucajno prolazi pored placa i ako moze da ode da vidi bilo bi savrseno, castio bih ga Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
rkoma1986 1113 Posted January 28, 2018 Plac je relativno blizu mojih, mogu pogledati ovih dana kad budem isao do njih, nznm tacno kad da ti kazem. Bez cascenja :-) 1 Pluto reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 28, 2018 A bas 1.3 vijas?Sent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
Pluto 448 Posted January 28, 2018 Pa i 1.9 ali svi su mi nekako izdrndani i preskupi, nesto im uvek fali Ovaj mi se bas svideo, imas ti neki 1.9? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 28, 2018 Imam svoj Sent from my SM-A510F using Tapatalk 1 Pluto reacted to this Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 30, 2018 Verovatno je vec bio.http://www.polovniautomobili.com/putnicka-vozila/9036815/fiat-uno-13-turbo-ieSent from my SM-A510F using Tapatalk Quote Share this post Link to post Share on other sites
Markobgd 609 Posted January 30, 2018 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
neshtry 14867 Posted January 30, 2018 Ovo je ristajling model,nije puno ni skup....Послато са LG-H440n уз помоћ Тапатока Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 30, 2018 Raketica mala.Moze da dohvati 200km/h, a oko 8s do 100. Kad mu se standardni pritisak turbine od 0.6 bara poveca na 1.0, moze da izbaci i 130-150 konja, naspram standatdnih 105.To je vec ludo u autu sa manje od 850kg.Sent from my SM-A510F using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 31, 2018 Mislim da stoji vec jedno 2 godine... Ali dobra roba svakako Quote Share this post Link to post Share on other sites
The Punisher 6616 Posted January 31, 2018 Traži preko 3500 evra a skinuo kasetofon. Pilićar. Quote Share this post Link to post Share on other sites
PremieRacing 5318 Posted January 31, 2018 Puno puta komentarisan, bio i 4500,- ali će svakako neko kad ga i ako kupi, uživati u jangtimeru Quote Share this post Link to post Share on other sites
