Goran Zemun 488 Posted September 29, 2013 Moze kod mene...a za drugi servis morao bi znati u kom gradu?? Quote Share this post Link to post Share on other sites
vuki 0 Posted September 29, 2013 Gorane koliko kosta zamena termostata za stilo 1.9 mjt 16v i ima te li vi termostat neki kvalitetniji da ne moram da jurim ? Quote Share this post Link to post Share on other sites
Goran Zemun 488 Posted September 29, 2013 Dodji do sevisa provericemo termostat....a za cenu morate pozvati u servis..011/2193543 Quote Share this post Link to post Share on other sites
vuki 0 Posted September 29, 2013 Hvala gorane vidimo se Quote Share this post Link to post Share on other sites
Dushman 0 Posted September 30, 2013 Jel koristite ORIGINALNE DELOVE kod velikog servisa ili zamenske? Fiat stilo 1.4 I ako znas cenu sa i bez ukljuceng malog servisa. Hvala Quote Share this post Link to post Share on other sites
Goran Zemun 488 Posted September 30, 2013 Veliki servis je oko 18000 din bez malog. A veliki servis sa malim je oko 23000 din. Kais i spaner Dayco, ulje Shell, filteri Champiom, pumpa vode Marelli....... Quote Share this post Link to post Share on other sites
nebo 0 Posted October 2, 2013 U Ponedeljak bio kod Gorana i imam samo reci hvale za njega i zaposlene u servisu.Vozim Multiplu i posle velikog servisa auto nije mogao da krene sa malim normalnim gasom(veliki servis radjen u servisu cije ime necu pominjati)kod Gorana za 5 min.utvrdili sta je problem i u toku dana resili isti,inace problem bio pogresno zupcenje.Hvala jos jednom i sve pohvale. Quote Share this post Link to post Share on other sites
fiat128s 3 Posted October 2, 2013 Odes kod pravog majstora i nema greske Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted October 3, 2013 Gorane, da li imas mozda neku preporuku koji termostat da uzmem za stila 1.9 jtd 16v (mjet) 103 kw. Moj ne zatvara skroz, pa bih da to resim pre zime, probao sam da nabavim originalni preko Boleta sa foruma ali nema, pa moram neki od ovih sto se nude u radnjama. Cuo sam da Facet ne valja nicemu? Quote Share this post Link to post Share on other sites
SerAlex 37 Posted October 4, 2013 Pozdrav Gorane imam cisto informativno pitanje da od prilike znam sta moze da bude problem. Naime kupio sam Stila 1.6 16v pre 2 nedelje u Sloveniji i dok sam bio na placu auto se ok ponasao nikakve greske i slicno sem za airbag i to sto klima pola hladi pola greje (ona digitalna).Ali cim sam izasao na autoput i presao 95/100 km/h poceo je da izbacuje gresku Engine Fault sve to tako dok ne bih presao 125/130 km/h.I ako konstantno izbacuje gresku nista se nije desavalo vukao je isto kao i kad nema greske tako da ne znam sta je problem i da nije nesto strasno. Inace dovezao sam ga do Srbije sa tim problemom/greskom bez problema.Pa da ne znas slucajno sta moze da bude problem.Sve jedno cu ja auto cim stigne sa carine da doteram kod tebe da ga proveris. E da takodje kada je gorivo u autu na granici sa Srbijom palo na rezervu ta greska se nije gasila sve dok nisam ponovo sipao gorivo i ako kad sam ga probao na placu auto je bio na rezervi i nije izbacivao gresku. Hvala unapred. Quote Share this post Link to post Share on other sites
Sreten91 12 Posted October 4, 2013 @Kuvalja, kod drugara na 156-ici JTD zamena termostata počela da spada u mali servis. Stavio Behr i Facet, oba trajala po jednu zimu i posle izdali. I ja treba da ga menjam, planiram da uzmem Vernet, prva ugradnja u Francuze. Ima ih u Beo-Caru. Quote Share this post Link to post Share on other sites
kolega.jankovic 24 Posted October 4, 2013 To je bio moj izbor. + je jeftiniji jer ide bez senzora... Quote Share this post Link to post Share on other sites
mousewho 0 Posted October 6, 2013 Gorane, koliko bi koštala dijagnostika, kao i mali i veliki servis za Grande Punta? Quote Share this post Link to post Share on other sites
Goran Zemun 488 Posted October 7, 2013 Razlicite su cene servisa za razlicite motore, ako nije problem za tacne inf. pozovite servis. 011 2193543 Quote Share this post Link to post Share on other sites
zunto 528 Posted October 9, 2013 Auto danas pregledan kod Gorana u Zemunu.Za majstora i profesionalnost svaka cast. Quote Share this post Link to post Share on other sites
bojankov 36 Posted October 9, 2013 Gorane vidim da te svi hvale i vidim da si dobar majstor pa ako mozes da mi pomognes jer vjerovatno znas...naime greska koja mi se pojavljuje je prouzrokovana senzorom papucice gasa(dijagnostika vidi tu gresku a gubi mi gas i upali check engine)...sad da li znas od kog auta moze na fiat bravi jtd 105 ako moze od nekoga ili samo od jtd brava/e...takodje moze li se to kako popraviti ili samo zamjena dolazi u obzir? I kako se skida..je li komplikovano i sta sve mora da se skida?hvala ti puno izvini:-) Sent from my GT-N7000 using Tapatalk 2 Quote Share this post Link to post Share on other sites
underground79 19 Posted October 9, 2013 Meni je Goran pre 2.5 god jedini uspeo da resi problem papucice gasa... Kod mene je senzor bio ispravan, zamenjena instalacija od kompa do senzora... U pitanju je bio Stilo jtd. Poz Quote Share this post Link to post Share on other sites
bojankov 36 Posted October 9, 2013 E kod mene se upali check engine kada predjem preko vece rupe i zatrese se auto...i na dijagnostici ostaje ta greska papucice...moram je mjenjati... Sent from my GT-N7000 using Tapatalk 2 Quote Share this post Link to post Share on other sites
Goran Zemun 488 Posted October 10, 2013 Mi uvek prvo proverimo instalaciju i izvucemo novu ako nam je sumnjiva. Potenciometar pedale gasa za tvoj auto odgovara samo jos od Multiple i Mareje. Quote Share this post Link to post Share on other sites
bojankov 36 Posted October 10, 2013 Hvala Gorane. Isto jtd ili svi motori odgovaraju? Je li tesko skinuti to i moze li se samo potenciometar skinuti? Sent from my GT-N7000 using Tapatalk 2 Quote Share this post Link to post Share on other sites
Goran Zemun 488 Posted October 10, 2013 Samo jtd...nije tesko za skinuti Quote Share this post Link to post Share on other sites
bojankov 36 Posted October 10, 2013 Hvala puno Gorane. Sve najbolje. Sent from my GT-N7000 using Tapatalk 2 Quote Share this post Link to post Share on other sites
mousewho 0 Posted October 10, 2013 Gorane, koliko bi koštao veliki i mali servis za Grande Punto 1.3mjet 75KS? Quote Share this post Link to post Share on other sites
Sale2810 4 Posted October 10, 2013 Pozdrav Gorane,zanima me cena zamene seta kvacila za stila jtd,sa vasim delovima? Hvala unapred. Quote Share this post Link to post Share on other sites
