djomla 8492 Posted August 6, 2019 Sala naravno... Onaj drugi znak pitanja mi je bio sumnjiv Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
milekontras 7 Posted August 6, 2019 [mention=6868]milekontras[/mention] Sad bi trebalo da je rešeno i da radi. E da, sad sam dobio poruku o rashladnoj tečnosti koja curi ;-) Sent from my Redmi 3S using Tapatalk Quote Share this post Link to post Share on other sites
milekontras 7 Posted August 6, 2019 16 hours ago, milekontras said: A ko je proizvidjac originalne ako ne nedjem polovnu? Nisam se dobro izrazio, ko je prozivođač tog nosača koji vredi ugrađivati kao novi? Pitam iz prostog razloga jer mogu da nabavim po možda nekoj povoljnoj ceni direktno iz uvoza ;-) Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 6, 2019 http://www.bayraklastik.com.tr/index.html Quote Share this post Link to post Share on other sites
Nikola 1.6 293 Posted August 6, 2019 Gorane jel gužva sutra ujutru? Trebao bi na put da idem uskoro pa da proverimo da li je sve ok. Sent from my HUAWEI VNS-L21 using Tapatalk Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 6, 2019 53 minutes ago, Nikola 1.6 said: Gorane jel gužva sutra ujutru? Trebao bi na put da idem uskoro pa da proverimo da li je sve ok. Sent from my HUAWEI VNS-L21 using Tapatalk Moze.. 7 i 30.. 1 Nikola 1.6 reacted to this Quote Share this post Link to post Share on other sites
xenon 118 Posted August 7, 2019 Pozdrav Gorane.Da li ima možda neka vest, za mog crnog mališu?Sent from my HUAWEI MT7-TL10 using Tapatalk Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 7, 2019 53 minutes ago, xenon said: Pozdrav Gorane. Da li ima možda neka vest, za mog crnog mališu? Sent from my HUAWEI MT7-TL10 using Tapatalk Gotov je juce.. Jos jednom da probam kad malo skoci temperatura... Quote Share this post Link to post Share on other sites
xenon 118 Posted August 7, 2019 Hvala Gorane.Nema žurbe.Samo lagano, da se lepo sve proveri.Sent from my HUAWEI MT7-TL10 using Tapatalk Quote Share this post Link to post Share on other sites
Skarac 12 Posted August 12, 2019 Postovani Gorane, pozdrav, imam provlem sa Puntom Classic, oba srafa pri promeni ramena, su otisla ukrivo, to su srafovi koji vezuju balans stanglu sa ramenom, stangle ih je napinjala i izbila iz ose. Da li imate ureznicu za ovu dimenziju, kako bi se navoji procistili. Ovo sad stoji jako stisnuto, ali bojim sa da ako ostavim ovako, da ce prilikom sledece zamene, biti problema da se srafovi izvuku. obzirom da je tesko to sve islo. Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 12, 2019 11 hours ago, Skarac said: Postovani Gorane, pozdrav, imam provlem sa Puntom Classic, oba srafa pri promeni ramena, su otisla ukrivo, to su srafovi koji vezuju balans stanglu sa ramenom, stangle ih je napinjala i izbila iz ose. Da li imate ureznicu za ovu dimenziju, kako bi se navoji procistili. Ovo sad stoji jako stisnuto, ali bojim sa da ako ostavim ovako, da ce prilikom sledece zamene, biti problema da se srafovi izvuku. obzirom da je tesko to sve islo. Imamo ureznucu ali ako je navoj unisten onda se moze izbusiti malo veca rupa i staviti duzi sraf i matica sa druge strane. Quote Share this post Link to post Share on other sites
Skarac 12 Posted August 12, 2019 Hvala na informacijama, kad mogu da dodjem, da pogledate te srafove, vozim porodicu pa ne bih da se igram sa time.Sent from my PAP5044DUO using Tapatalk Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 12, 2019 7 minutes ago, Skarac said: Hvala na informacijama, kad mogu da dodjem, da pogledate te srafove, vozim porodicu pa ne bih da se igram sa time. Sent from my PAP5044DUO using Tapatalk Sutra u 7 i 30... Quote Share this post Link to post Share on other sites
Skarac 12 Posted August 12, 2019 Hvala puno,vidimo se.Sent from my PAP5044DUO using Tapatalk Quote Share this post Link to post Share on other sites
Skarac 12 Posted August 13, 2019 Sve reseno, hvala jos jednom na velikoj pomoci, pao mi je teret sa ledja Quote Share this post Link to post Share on other sites
xenon 118 Posted August 13, 2019 Pozdrav Gorane.Čini mi se, kao da mi je klapna za ventilaciju neispravna.Možda ne zatvara kako treba, pa ulazi topao vazduh zajedno sa klimom.Nisam dovoljno stručan, pa me zanima tvoje mišljenje, vezano za problem sa slabim hlađenjem. Sent from my HUAWEI MT7-TL10 using Tapatalk Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 13, 2019 6 minutes ago, xenon said: Pozdrav Gorane. Čini mi se, kao da mi je klapna za ventilaciju neispravna.Možda ne zatvara kako treba, pa ulazi topao vazduh zajedno sa klimom. Nisam dovoljno stručan, pa me zanima tvoje mišljenje, vezano za problem sa slabim hlađenjem. Sent from my HUAWEI MT7-TL10 using Tapatalk Moguce je... Mozemo i to proveriti.. Quote Share this post Link to post Share on other sites
xenon 118 Posted August 13, 2019 Napiši kad je zgodno da navratim, i koliko traje procedura, da znam zbog posla.Čisto,pre nego što se Sale vrati sa odmora, da isključimo sve što možemo.Može i od sabajle. Sent from my HUAWEI MT7-TL10 using Tapatalk Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 13, 2019 2 hours ago, xenon said: Napiši kad je zgodno da navratim, i koliko traje procedura, da znam zbog posla.Čisto,pre nego što se Sale vrati sa odmora, da isključimo sve što možemo.Može i od sabajle. Sent from my HUAWEI MT7-TL10 using Tapatalk Ja sam tu do petka.. Bilo koji dan.. Javite se samo da budem tu.. Quote Share this post Link to post Share on other sites
xenon 118 Posted August 13, 2019 Da li vam odgovara, da sutra budem položajnik, tamo od 07:30? Sent from my HUAWEI MT7-TL10 using Tapatalk Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 13, 2019 35 minutes ago, xenon said: Da li vam odgovara, da sutra budem položajnik, tamo od 07:30? Sent from my HUAWEI MT7-TL10 using Tapatalk Moze Quote Share this post Link to post Share on other sites
xenon 118 Posted August 13, 2019 Ok, već krećem da hvatam san .Sent from my HUAWEI MT7-TL10 using Tapatalk Quote Share this post Link to post Share on other sites
milekontras 7 Posted August 13, 2019 Treba mi savet, Goranov ili neko od forumaša ako ima iskustva. Danas sam krenuo na put i desilo mi se da kočnica propada, propadne skroz i onako pomalo koči, a onda kad je "nadrukam" može malo bolje da ukoči, pa opet propadne. Tako sam vozio 50 km, i onda se vratilo u normalu, postala tvrda kočnica kako treba. E sad, diskovi su novi, pločice isto, ulje sam pogledao malo ispod max, sve spolja izgleda ok. Lako bi bilo da sam u bg, Goran bi rekao dodji ujutro da pogledamo, ali ja sam krenuo na put, do Makedonije i Grčke i trenutno sam dam dva u Kraljevu. Jeste teško reći ovako šta je problem ali ako može sad savet šta da činim, verovatno je mnogo ljudi imalo slična iskustva.Sent from my Redmi 4 using Tapatalk Quote Share this post Link to post Share on other sites
Goran Zemun 497 Posted August 13, 2019 1 hour ago, milekontras said: Treba mi savet, Goranov ili neko od forumaša ako ima iskustva. Danas sam krenuo na put i desilo mi se da kočnica propada, propadne skroz i onako pomalo koči, a onda kad je "nadrukam" može malo bolje da ukoči, pa opet propadne. Tako sam vozio 50 km, i onda se vratilo u normalu, postala tvrda kočnica kako treba. E sad, diskovi su novi, pločice isto, ulje sam pogledao malo ispod max, sve spolja izgleda ok. Lako bi bilo da sam u bg, Goran bi rekao dodji ujutro da pogledamo, ali ja sam krenuo na put, do Makedonije i Grčke i trenutno sam dam dva u Kraljevu. Jeste teško reći ovako šta je problem ali ako može sad savet šta da činim, verovatno je mnogo ljudi imalo slična iskustva. Sent from my Redmi 4 using Tapatalk Neki tocak je blokirao.. Ulje se pregrejalo i preslo u gasovito stanje... Pedala je propala... Cim se ulje ohladilo i ulje postalo tecno... I ne stisljivo... Pedala se vratila u normalu. Kontrolisite temperaturu tockova posebno zadnjih... I oprezno.. 1 djomla reacted to this Quote Share this post Link to post Share on other sites
milekontras 7 Posted August 13, 2019 Ok hvalaSent from my Redmi 4 using Tapatalk Quote Share this post Link to post Share on other sites
