coa565 10 Posted December 17, 2016 Ne znam dal zato sto termostat ne otvara pa ne kruzi voda i ne izlazi na malo crevce ili je pumpa Vodena pumpa nigde ne curi niti kaplje Quote Share this post Link to post Share on other sites
coa565 10 Posted December 17, 2016 Kako drugacije da odzracim sistem? Quote Share this post Link to post Share on other sites
vicent 1263 Posted December 17, 2016 Vodena pumpa ne mora da curi kad je u problemu. Jednostavno sa osovine spadne radno kolo i ne cirkuliše tečnost. Retkost je da se nađe pumpa sa metalnim radnim kolom, uglavnom su plastična. Quote Share this post Link to post Share on other sites
coa565 10 Posted December 17, 2016 A jel nece da otvori termostat ako ne radi vodena pumpa, kad ga stavim u vodu i zagrejem na 86C on otvara uredno... Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted December 17, 2016 Ma tu je termostat ok...problem je ili pumpa ili vazduh. Quote Share this post Link to post Share on other sites
coa565 10 Posted December 17, 2016 Meni deluje da je negde vazduh i da ne moze da probije... Zato ne kruzi Quote Share this post Link to post Share on other sites
coa565 10 Posted December 19, 2016 Izvadio sam termostat i opet na leru be ide antifriz na ono malo crevce id ekspanzione posude, cim dam gas odma krene da izlazi, cim pustim ono stane... Da li treba da tece antifriz na malo crevce na leru? Quote Share this post Link to post Share on other sites
MS PK 7734 Posted December 19, 2016 Dize li temp? Quote Share this post Link to post Share on other sites
coa565 10 Posted December 19, 2016 Zortio sam ga 90 km/h uz veliki uspon i podigao je skoro do pola malko nu zali ali to bez termostata, cim ubacim termostat na 200 metara podigne temperaturu iznad pola i pocne da kuva a ja mu odma upalim grejanje i on spusti. Kasnije cu okaciti snimak kako ide 90 na 3000 obrtaja uz veliki uspon cetvrtom Quote Share this post Link to post Share on other sites
alex011bgd 2 Posted December 21, 2016 (edited) Pozdrav svima, zamolio bih za pomoc. Moj auto sada u zimskom periodu ne dize radnu temperaturu, tako da grejanje nemam u kabini. To mi se desava na otvorenim putevima kada sam u 4-toj ili 5-toj brzini. U gradskoj voznji podize temperaturu, jer "kreni-stani, prva druga", pa se i temp. podigne. Medjutim cim izadjem na otvoren put ona pada. Fiat Punto II 1.9 JTD Sta mi je ciniti? Hvala Edited December 27, 2016 by neshaoct spojeno & dodata napomena o autu Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted December 21, 2016 Zameni termostat? Quote Share this post Link to post Share on other sites
alex011bgd 2 Posted December 21, 2016 aha. koliko to moze da me kosta? okvirno da li znas. Hvala. Quote Share this post Link to post Share on other sites
Home 56 Posted December 21, 2016 1200 dinara beru...taj je fabrička ugradnja...ima neki i za 800 dinara. Možeš i sam da zameniš, 2 šrafa i šelna...Govorim i puntu mk2 2003 godište benzin Quote Share this post Link to post Share on other sites
pedjabj 16 Posted December 21, 2016 Oko 1000 termostat i jos toliko za ruke.Ako ti u mestu dostigne radnu i cim krenes pocne da pada, znaci da je 99% termostat. Quote Share this post Link to post Share on other sites
alex011bgd 2 Posted December 21, 2016 Hvala puno ljudi... Nije to onda neka investicija velika...a bas bi mi znacilo, jer se smrznem na duza putovanja Quote Share this post Link to post Share on other sites
rage_man 130 Posted December 21, 2016 Ja sam bas menjao pre par dana, stavljen taj od 800 din (ne znam koji je) i za ruke 1200 din Quote Share this post Link to post Share on other sites
coa565 10 Posted December 21, 2016 Nece biti da je za dizela oko 1000 dinara a on ako dobro vidim vozi dizela. Za taj auto je oko 5000 dinara samo termostat bez zamene... Quote Share this post Link to post Share on other sites
pedjabj 16 Posted December 21, 2016 Ja se unapred izvinjavam,ali nije napisano koji je auto,pa sam po inerciji pomislio da je Punto benzinac.Na fonu se ne vidi sta ko vozi i ako je napisano,mislim kada se koristi Tapatalk. Quote Share this post Link to post Share on other sites
bane000 108 Posted December 21, 2016 Ne mora da kupuje termostat od 5000 dinara. Moze i termostat od Renoa koji kosta 550 dinara. Quote Share this post Link to post Share on other sites
alex011bgd 2 Posted December 21, 2016 u pitanju je dizel 1.9, 2001 god. ako je 5000 din samo deo, plus ruke, onda je to vise nego sto sam i mislio da moze da bude... Quote Share this post Link to post Share on other sites
rage_man 130 Posted December 21, 2016 Jbg, i ja sam mislio da je benzinac, ovo sto sam napisao u prethodnom postu odnosi se na Punta 1.2 8V Quote Share this post Link to post Share on other sites
Memphis 15 Posted December 22, 2016 Ovisi koji uzmeš. Ako imaš mogućnosti uzmi Mahle/Behr ili Gates Quote Share this post Link to post Share on other sites
darkman14 5900 Posted December 22, 2016 Preporuka za Behr, menjao sam pre 4-5 zima, od tada radi bez problema. Mislim da je tada bio oko 6500 za 1.9 jtd motor. Vernet je bio tada oko 1000 dinara jeftiniji a Behr sam stavio po preporuci majstora jer je prva ugradnja. Vidim da je sve popularniji Reno 4/5 termostat, verovatno zbog cene. Quote Share this post Link to post Share on other sites
Martin 799 Posted December 22, 2016 Takođe preporučujem Behr. Oko 120000km radi bez greške. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted December 22, 2016 Ili Behr ili Reno. Trece nema, tj.bacanje je para, a nije mala para u pitanju Quote Share this post Link to post Share on other sites
