ivan.ik 625 Posted October 6, 2015 Joshi , Croma ne Chroma.Francuz baš ga zajeba, Multipla lepa, Astra H ružna. Quote Share this post Link to post Share on other sites
totti 13165 Posted October 6, 2015 decko ima bas jaku mastu! Vozi Opelo a masta ko zna sta da vozi Quote Share this post Link to post Share on other sites
francuz69 995 Posted October 7, 2015 Kako sam se samo nesvesno upleo u zahebanciju za Astru. Tek sam malopre pogledao Zrnketovu temu i onda su mi se sve kockice sklopile u ovoj temi. Quote Share this post Link to post Share on other sites
smilan 0 Posted October 7, 2015 Hm mislim da ce definitivno biti Croma. Jos samo da prodam punta za ucesce Quote Share this post Link to post Share on other sites
zrnke 41 Posted October 8, 2015 Kako sam se samo nesvesno upleo u zahebanciju za Astru. Tek sam malopre pogledao Zrnketovu temu i onda su mi se sve kockice sklopile u ovoj temi.Što, šta si shvatio? Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted October 8, 2015 Pa da je opel Quote Share this post Link to post Share on other sites
francuz69 995 Posted October 8, 2015 Shvatio da te zezaju za Opela a ja jos dolio ulje na vatru Quote Share this post Link to post Share on other sites
Markobgd 609 Posted October 8, 2015 Shvatio da te zezaju za Opela a ja jos dolio vodu na rđu:D Quote Share this post Link to post Share on other sites
asterix 7 Posted October 8, 2015 Realno nemaju za sta Zrnketa da zezaju za Astru,jer mu je auto kao avion,svestan je i on toga,nego je bas bas zajbancija,Zrne lepo shvata salu na njegov racun jer kapira da nema losih namera.Tako da se ne sekiras,nista lose ne mozes tu da uradis.PSNemaoj samo nikako da mu govoris KRATKI...To ce ga pocepati.Ima kompleks zbog 164 cm. Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted October 8, 2015 Nemoj samo nikako da mu govoris KRATKI...To ce ga pocepati.Ima kompleks zbog 164 cm sa sve stiklom dvanesticom . Quote Share this post Link to post Share on other sites
francuz69 995 Posted October 8, 2015 AHAhaAH, e vidis Zrnke e ovih gornjih par postova sam shvatio... Quote Share this post Link to post Share on other sites
integralac 2566 Posted October 15, 2015 sutra krecem u kupovinu, NS i okolina pa sta stignem par informacija me zanimaju ako neko zna iz prve ruke a ticu se cene popravki znam sta su mane procitao sam celu temu ali ne znam cene delovaako neko zna sledece, kvacilo sa zamajcem (rekose mi da je 800 evra) veliki servis, klapna gasa, poluosovine...ako ima jos neki skup deo koji zna da ode moze i to hvala, pa se vidimo u predstavljanju Quote Share this post Link to post Share on other sites
francuz69 995 Posted October 15, 2015 Zamajac, kvacilo, druk lager i semering sa rukama oko 700 evra kod Gorana.V+M servis oko 350 evra kod Gorana.Poluosovine, ako nije stradala cementacija vec je samo potrebno podmazivanje, 3000 dinara obe VB auto. Ako je otisla cementacija onda sve zavisi po kojoj ceni nadjes poluosovine. Zamena je 1500 po poluosovini.Ciscenje klapne gasa je 9000 kod Gorana. Zamena ne znam.Moze da ode usisna grana, koliko kosta zavisi od cene po kojoj nadjes granu.Remap, izbacivanje DPF i sw gasenje DPF i EGR, 160 evra u NovaSpeedu. Pitaj ako te jos nesto zanima Quote Share this post Link to post Share on other sites
integralac 2566 Posted October 15, 2015 uuu svaka castnadam se da necu da nabodem primerak kome fali vecina od ovoga mada realno ovde je samo kvacilo skuplja stavka, ostalo u granicama proseka za vecinu auta te klase sad sam se cuo sa jednim tipom, kaze oce i menjac manuelni da ode ???? za to nisam cuo do sad Quote Share this post Link to post Share on other sites
francuz69 995 Posted October 15, 2015 (edited) Nece, odnosno ako nadjes primerak kome je manuelni menjac u problemu bezi od te Crome sto dalje. To je jedna od poslednjih stvari koja moze da ode. Moze da se desi da moraju sajle da se podmazu ili da ode neki od lezajeva ali da rikne generalno mnogo tesko. Automatski su vec druga stvar. Poznati po problemima Edited October 15, 2015 by francuz69 Quote Share this post Link to post Share on other sites
integralac 2566 Posted October 15, 2015 ok, znaci prava informacija, kupovina polovnjaka postaje vrlo zahebana cisto ako nekoga zanima ovim redosledom sutra gledam http://www.polovniautomobili.com/putnicka-vozila/7054870/fiat-croma-19-mjt-giugiaro http://www.polovniautomobili.com/putnicka-vozila/6175927/fiat-croma http://www.polovniautomobili.com/putnicka-vozila/6704083/fiat-croma http://www.polovniautomobili.com/putnicka-vozila/7116542/fiat-bravo-19mjet http://www.polovniautomobili.com/putnicka-vozila/7076072/fiat-croma-multijet Quote Share this post Link to post Share on other sites
@bane@ 102 Posted October 15, 2015 Jes ti to poredjao po autima kako ti se svidjaju ili geografski? Quote Share this post Link to post Share on other sites
bglion 401 Posted October 15, 2015 Ovako po slikama. Prva croma (fale samo lajsne na branicima i cep na zadnjem braniku)BravoPoslednja croma (lajsne :-) )Srecna potraga Quote Share this post Link to post Share on other sites
integralac 2566 Posted October 15, 2015 po ovom redu ih gledam,voleo bih da je ova prva ok jer ima najbolju opremu od svih na oglasima Quote Share this post Link to post Share on other sites
Dule 021 660 Posted October 16, 2015 Ova prva ako je ona u kojoj sam sedio je jako dobra i sacuvana a jedina mana joj je bila neispravna panorama.Otvorila se i nije se mogla zatvoriti.Tako je i ostao otvoren krov para dana dok je kisa padala a pokrili su krov samo kartonom.E sad da lisu ga popravili kako treba ili skarabudzili da se samo zatvori to je vec pravo pitanje.Inace motor i zamajc su bili odlicni.Naravno,sve ovo stoji ako je to ta Croma ali sa ovom kozom i bojom ne verujem da ih ima mnogo. Quote Share this post Link to post Share on other sites
Ticma 537 Posted October 16, 2015 Moj savet, ako vec mozes da biras neka bude sa bogatom opremom Sve sitnice se daju srediti ali opremu da nabudzis naknadno nema sanse, naravno ako su motor i menjac dobri. Quote Share this post Link to post Share on other sites
integralac 2566 Posted October 16, 2015 kroma kupljena, prosecna oprema ali motor polece, ne verujem jos uvek da ide ovako iskreno od koze sam odustao, toplo hladno, pregreva, prehladjuje, sta znam, lepo ali ne i mnogo korisno ostalo manje vise, na onoj prvoj nije popravljen krov a da imam a ne radi ne bi mi se svideloima jos neke mane koje se ne vide na slikama, recimo svi diskovi i plocice, gomila nekih plastika polomljeno, felne izgrebane dosta, ima i nekoliko limarijskih ulubljenja ona treca siva raspad, dao bih mu mozda 1800 i to posle 3 rakije bravo odlican, da je rekao jos jedno 100-150 manje uzeo bih njega (ko kaze da nema dobar za malo para) jos jednom zahvaljujem Duletu na saradnji i podrsci, svaka moguca preporuka za poslovanje sa njim Quote Share this post Link to post Share on other sites
Ivan BG 720 Posted October 17, 2015 Koju si uzeo od one cetiri sto si postavio? Quote Share this post Link to post Share on other sites
Martin 799 Posted October 17, 2015 Koju si uzeo od one cetiri sto si postavio?Ili neku drugu??? Ili nemoj da odgovoraš ovde - napravi temu!!!! Quote Share this post Link to post Share on other sites
