mudri 63 Posted September 7, 2021 (edited) Trenutna Edited September 7, 2021 by Ivan Sredjene slike 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 7, 2021 (edited) U servisu podizača, na Vračaru, od 2000 - 3500rsd, servis podizača. I meni pukao plastični roler. Dok sam popio kafu, gotovo. Edited September 7, 2021 by Ivan Skinut nepotreban citat i TT potpis Quote Share this post Link to post Share on other sites
mudri 63 Posted September 7, 2021 (edited) Video sam da na KP ima nov roler za 800din ali me mrzelo da ga budzim pa sam uzeo kompletan ispravan. Kazu da nije lako sajlu namestiti da lepo otvara zatvara. https://www.kupujemprodajem.com/automobili-delovi-i-alati/auto-auto-stakla/podizaci-stakla-za-fiat-grande-punto/oglas/93658776?filter_id=1400250838#photoBig Inace kod mene u Arandjelovcu, lik na otpadu ti za 30e i zameni. Neko ga sam odradio vec pola posla pa cu sam i zavrisiti Edited September 7, 2021 by Ivan Dodat PrintScreen Quote Share this post Link to post Share on other sites
shuxx 10900 Posted September 7, 2021 Ima nesto i u DIY, zadovoljstva Sent from my SM-A525F using Tapatalk 1 mudri reacted to this Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 7, 2021 Ma ne radi se o tome, roleri i plastike nakon više sezona toplo-hladno, izgube svojstva i postaju krti. Ja sam menjao kad je, onomad, temperatira bila "38"°C, zapravo oko 50°. Servis ne može da se namenja tih rolera.Poslato sa JSN-L21 pomoću Tapatoka Quote Share this post Link to post Share on other sites
mudri 63 Posted September 7, 2021 (edited) Podizac namesten, radio namesten, mp3 sa usb u kaseti funkiconise bez greske, samo treba fles formatirati u fat32. Povezao sam mobiline preko bluetooth-a. Malo sam provalio da mi ne radi otvaranje gepeka iz auta, preko kljuca radi, da li je neko imao slican problem? Edited September 7, 2021 by mudri 1 silenci reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted September 7, 2021 Negde gubi kontakt verovatno, neka banalna stvar tog tipa. Quote Share this post Link to post Share on other sites
Ivan 17683 Posted September 7, 2021 56 minutes ago, mudri said: mp3 sa usb mobilini preko bluetooth-a Iliti "Blue&Me" , od korisnih stvari imas jos i glasovne komande . Proveri samo je li ti Setup na engleskom (ako ne parlas jos neki jezik). Quote Share this post Link to post Share on other sites
mudri 63 Posted September 7, 2021 Jeste prica mi na engleskom. Quote Share this post Link to post Share on other sites
Ivan 17683 Posted September 7, 2021 Samo sto treba ti da pricas njemu . 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
shuxx 10900 Posted September 7, 2021 Do you speak EnglishYes of coursePa baci kantuSent from my SM-A525F using Tapatalk 1 Grafit reacted to this Quote Share this post Link to post Share on other sites
Ivan 17683 Posted September 7, 2021 Vrsi poslic...: https://www.fiat-lancia.org.rs/forum/index.php?/topic/61292-fiat-nuova-bravo-update-blueme-greška-no-english/&do=findComment&comment=1412053 Quote Share this post Link to post Share on other sites
Dale 6811 Posted September 7, 2021 3 hours ago, mudri said: Malo sam provalio da mi ne radi otvaranje gepeka iz auta, preko kljuca radi, da li je neko imao slican problem? Cini mi se da na ypsilon ima podesavanje otvaranja gepeka u meniju. Ja sam mislio da ne radi dok nisam promenio nesto u podesavanju. Nesto kao "independent boot open". Mislim da ovde nije htelo od spolja na prekidacu gepeka, a htelo je na kljuc. Posle promene u meniju, radilo je i na dugme i na kljuc. Quote Share this post Link to post Share on other sites
mudri 63 Posted September 8, 2021 Odradjen mali servis, ulje i svi filteri. Sipao sam CASTROL MAGNATEC C3 5W40/4L. 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
mudri 63 Posted September 20, 2021 (edited) Juce sredio problem za zmigavcima koji sam imao od pocetka. Cak su radili cas ne. Mislio sam da je problem bio u ablenderu ali ipak ne, kod mene je bio problem u kablu, gubio kontakt kod dzeka. Sada bukvalno svaki prekidac, lampica radi u GP. Edited September 20, 2021 by mudri 2 horvat and dach@ reacted to this Quote Share this post Link to post Share on other sites
mudri 63 Posted October 5, 2021 Danas prodat Grande. Naleteo mi jeftino 500L sa 0.9 Twinair Turbo motorom, ima li ko iskustva sa njim? Quote Share this post Link to post Share on other sites
shuxx 10900 Posted October 5, 2021 E vala ako je , nesto naucismo. A sad cemo oko 500L a da ucimo. I tog cuvenog 0.9 L turbaka.Neka je srecna kupovina Sent from my SM-A525F using Tapatalk Quote Share this post Link to post Share on other sites
mudri 63 Posted October 5, 2021 NIsam ga jos uzeo, sutra idem da ga pogledam. Izbacicu slike ovde. Quote Share this post Link to post Share on other sites
shuxx 10900 Posted October 6, 2021 Jedini turbak 0.9 na ogkasimaKoliko je ova cena realna, za 2013godisteSent from my SM-A525F using Tapatalk Quote Share this post Link to post Share on other sites
mudri 63 Posted October 6, 2021 Bas ih malo ima sa tim motorem, zato se i plastim. Ovaj mogu da uzmem za ispod 5000e i to na rate. Quote Share this post Link to post Share on other sites
shuxx 10900 Posted October 6, 2021 Generalno taj motor hvale. Sent from my SM-A525F using Tapatalk Quote Share this post Link to post Share on other sites
shuxx 10900 Posted October 8, 2021 Sta napravi sa 500L.....Sent from my SM-A525F using Tapatalk Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted October 8, 2021 Odlican motor, kao sto sam vec pisao negde. U servisu odrzavamo neke sa preko 250 i 300 k na satu i odlicni su. Potrosnja ulja jedva primetna. Jedino sto im se desava je da kad crkne zamajac ( ako se zapusti ) osteti zvono menjaca. Inace motor kao motor odlican, redovna zamena ulja i pun gas! 1 horvat reacted to this Quote Share this post Link to post Share on other sites
Ivan 17683 Posted October 8, 2021 @MiloshBg Pricas za turbaka dvocilindrasa, tj. TwinAir Turbo 105? Svasta sam i cuo od par majstora, a i citao - em sto je na 2 cilindra, em sto takodje nosi MultiAir tehnlogiju varijabilnog usisa. Doduse, svasta sam cuo i za MultiAir , dok sam se raspitivao. Pa sam ga kupio i slatko vozim vec 4. godinu. Klasika za te egzoticnije motore svih proizvodjaca - npr. Fiatov 1.4 MA je bio motor godine 2010., a 0.9 TA najbolji novi motor 2011. godine. Pa kako se koji pokazivao u praksi, ima i neslavnih primera. 1 igor0511 reacted to this Quote Share this post Link to post Share on other sites
MiloshBg 1026 Posted October 9, 2021 (edited) Za TwinAir turbo od 105 konja, konkretno 500l. Uopste vezano za multiair smo imali samo 1 problem i taj problem je resen pranjem multiair filtera. Inace, radili smo i zamenu lanca, jer u ovoj firmi se bas arce i teraju, godisnje prelaze i 100.000km a ne izadju iz Srbije. Zamena lanca je uzasna, traje skoro pa duplo duze nego na 1.3 mjet. Edited October 9, 2021 by MiloshBg Quote Share this post Link to post Share on other sites
