danijel55 700 Posted June 9, 2020 (edited) Pozdrav. Problem delta 1.6mjet 120ks,ovaj zvuk u klipu. Do cega moze da bude? Vec bi bila u servisu, ali drugaru je auto ovih dana preko potreban. Edited June 9, 2020 by neshaoct naslov / formatiranje Quote Share this post Link to post Share on other sites
MS PK 7735 Posted June 9, 2020 Na sta ti lici? Quote Share this post Link to post Share on other sites
darkman14 5902 Posted June 9, 2020 jel turbina? Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 9, 2020 Fiju dobro to, nego ovo trokeljanje kad se pusti gas? Quote Share this post Link to post Share on other sites
MS PK 7735 Posted June 9, 2020 Pa to lici na turbinu ali moze da bude i neko crevo, rupica, dihtung pa da vara, pogotovo sa snimka. Skini creva i proveri da li.ima lufta turbina 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 9, 2020 Ili mozda jos bolje receno krkljanje. Dal moze da bude do egr? Ako ima značaja 4600km prešla od servisa, ulje nije pipnula. Uglavnom ide kod majstora cim pre Quote Share this post Link to post Share on other sites
dekirs 4819 Posted June 9, 2020 (edited) Nije to nista. Isti zvuk sam imao na Bravu a isao je normalno. Cak i posle zamene turbine ( zbog drugog razloga) je isti taj zvuk bio. Proveriti na dijagnostici u 4oj na 1500 obrtaja pun gas do ~4000, pratiti samo pritisak ako se poklapa sve je ok. To mi vise deluje kao neki blow off, jer cini mi se da slican zvuk ima i na 2.0 ( isti motori). Edited June 9, 2020 by dekirs 1 skile86 reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 9, 2020 U principu pogledace mehanicar. Proveriti pritisak i to je to. Ako nadju problem, a da nije turbina bice napisano ovde. U sustini ako je do turbine, a pritisak ok i ne troši ulje mislim da nece nista dirati, jer ionako planira da za godinu dana, promeni deltu, ako ne i pre. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 12, 2020 Turbina je. Iduce za 10 dana ce biti remont. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted June 12, 2020 Rekoh ti..jbgПослато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 12, 2020 (edited) Al zanimljiva stvar danas tog zvuka nije bilo. Edited June 12, 2020 by danijel55 Quote Share this post Link to post Share on other sites
darkman14 5902 Posted June 12, 2020 E onda nek petkom samo vozi Svakako i turbina je potrošna. Uzići su ti tu pod nosom, mada bih se ja raspitao i kod ovih što je @Quadrifoglio Verde servisirao Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 12, 2020 Predlozio je mehanicar sto mu odrzava deltu,kaze sa Tomicem saradjuje i on sredjuje,drugar otera auto kod njega i to je to. Inace bice delta ako ne za par meseci ,za godinu dana na oglasima.Kad se turbo odradi,uradio joj je poliranje ,bukvalno bez ulaganja.Razlog prodaje 1.6 slabasan je to motor za nju,hteo da ugradi multimediju nigde nije nasao da to izgleda fabrika,a da ne mora da narucuje od preko,planira i drugo dete pa nema mesta Verovatno e90 touring.Inace sam ga savetovao za twin turbo,al se plasio 2 turbine Quote Share this post Link to post Share on other sites
MS PK 7735 Posted June 12, 2020 E kad u delti nema mesta za jos jedno bebce od 4kg i nosiljku u e90 ce sigurno da ima i za vrtic Gde ode ovaj svet vise..Послато са SM-A307FN помоћу Тапатока 1 djomla reacted to this Quote Share this post Link to post Share on other sites
Quadrifoglio Verde 9319 Posted June 12, 2020 Ja bih pre rekao da je ovo do nekog creva bilo, ali ako je majstor rekao da je turbina... Inače, ajde da priznamo da je 1.6 slabašan, ali ova priča s drugim detetom malo ne drži vodu jer je meni sa dva odrasla bila više nego dovoljna. Jednostavno, oće čovek švabu i to je... šta ima da se pravda. 3 MS PK, djomla and alfini0507 reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted June 12, 2020 Meni uvek fascinantno kako ljudi kupe auto koji im je slabasan.Послато са Mi MIX 2 помоћу Тапатока 4 ISV_01, knezevic76, Woodoo and 1 other reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 12, 2020 Problem je gepek u kome treba da stanu, kolica, njihalica, plus stvari tj ranac. Pogledao je creva.Danas se nije culo, niti kad je hladan motor, niti zagrejan. 1 Quadrifoglio Verde reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted June 12, 2020 2 hours ago, danijel55 said: Al zanimljiva stvar danas tog zvuka nije bilo. Rekoh ti da nije. Ubacite u 4tu i izmerite pritiske, od 1500 obrtaja do 4000 ako se slaze i ne trosi ulje, gas samo. Quote Share this post Link to post Share on other sites
knezevic76 7021 Posted June 12, 2020 Ovi majstori danas ako nije turbina onda je zamajac... simptomatično, niko da krene od creva i benignih stvari. Послато са SM-A715F помоћу Тапатока 1 djomla reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted June 13, 2020 Das pare za turbinu, on zameni creva i kaze popravljena turbina Послато са Mi MIX 2 помоћу Тапатока 4 1 rkoma1986, djomla, ISV_01 and 2 others reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 13, 2020 Creva su dobra. Da je do creva non stop bi imao taj zvuk i verovatno auto bi isao pa nikako. Svakako bice proveren i pritisak turba. Pre ce biti tu da glavi geometrija. Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 13, 2020 Sto se majstora tice u krugu imamo dvojicu, kojima samo kapa dole. Cak je jedan kolega sa ovog foruma iz Bg dovezao auto da mu uradi motor. To vam sve govori. 1 Quadrifoglio Verde reacted to this Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 25, 2020 Uradjena, turbina. Problem bio, geometrija i nije lepo ulje provlacila, vec vise lepila ulje. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted June 25, 2020 Ko je radio, Uzice?Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
danijel55 700 Posted June 25, 2020 Tomic Uzice Quote Share this post Link to post Share on other sites
