alfini0507 1653 Posted May 6, 2019 On 5/6/2019 at 4:28 PM, dellas said: Ne znam za slanje, prenosim utiske kad preuzmem auto sutra. Cena nije mala, ali nadam se da ce se bar opravdati kvalitetom. Cekamo utiske@dellas 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 8, 2019 (edited) Utisci su za svaku preporuku, volan je kao kod 0 km. Edited May 9, 2019 by neshaoct sredio sliku 5 neshaoct, alfini0507, neshtry and 2 others reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted May 8, 2019 Extra... Baci na pp cifru... Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted May 8, 2019 Ne treba na PP, nego na Forum pošto je svakome taj info značajan kako bi imao potpunu informaciju, tj. i kvalitet, i gde može da se odradi tako i sa kojom cenom. 4 1 Axic, Boris90, alfini0507 and 2 others reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted May 8, 2019 Kako ti kazes druže PreCedniče Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 8, 2019 Dzabe se ulizujes , popust koji ja mogu da sredim Nesa moze samo da sanja i za sebe licno cak 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 8, 2019 50 eur sa rucicom , 40/10 2 alfini0507 and Axic reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted May 8, 2019 15 hours ago, MS PK said: Dzabe se ulizujes , popust koji ja mogu da sredim Nesa moze samo da sanja i za sebe licno cak Quote Share this post Link to post Share on other sites
bglion 401 Posted May 9, 2019 Da li si skidao volan ili samo odvezao auto. Postavi sliku rucice Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 9, 2019 Odvezao auto, postavicu ovih dana i rucicu. 1 bglion reacted to this Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted May 9, 2019 Malo je mracna slika, ali ovo deluje bas dobro. Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 9, 2019 (edited) naibolje se uporedi pre i posle: Edited August 19, 2019 by neshaoct prebacio slike na FLCS server 1 Axic reacted to this Quote Share this post Link to post Share on other sites
S.V.E.T.A. 125 Posted May 9, 2019 (edited) Ova siva plastika deluje kao bruseni aluminijum, jel to neka folija nalepljena? Inace cena je sasvim OK za ovakav rad, a verujem da je koza kvalitetnija i od fabricke... BTW, Delta je pojam za vecinu automobila u klasi Pozdrav Edited May 9, 2019 by S.V.E.T.A. 1 silenci reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 10, 2019 Folija je bruseni aluminijum, a sto se tice koze i jeste fabricka samo je ofarbana nije menjana Quote Share this post Link to post Share on other sites
Ivan 17679 Posted May 10, 2019 Stvarno odlicno izgleda. Kada presvuku volan, jeste da je nova koza ali se iz aviona vidi da je menjano i uglavnom strci od ostatka enterijera. Na ovim slikama deluje kao fabrika, a ako je trajno kao sto dobro izgleda - i vise nego korektna opcija. Quote Share this post Link to post Share on other sites
bglion 401 Posted May 10, 2019 Odlično izgleda. Ček, da li je lepljenja folijana volan sada? Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 10, 2019 Bila je folija na njemu kad sam ga kupio Quote Share this post Link to post Share on other sites
S.V.E.T.A. 125 Posted May 11, 2019 19 hours ago, dellas said: Folija je bruseni aluminijum, a sto se tice koze i jeste fabricka samo je ofarbana nije menjana Sad tek vidim da si ti farbao kozu a nisi presvlacio, stvarno izgleda vrhunski kao nov iz fabrike... A folija je bas fin detalj, generalno su to trebali fabricki da odrade i na volanu i na jos nekim mestima umesto onih fake plastika-hrom-aluminijum detalja Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 18, 2019 (edited) beauty and the beast, slika je napravljena samo radi poredjenja dimenzija, neverovatno je da delta kao hatch ne izgleda uopste malo pored ogromne petice. Edited August 19, 2019 by neshaoct prebacio sliku na FLCS server 2 neshaoct and bglion reacted to this Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 18, 2019 To je zato sto mislis da je petica ogromna 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17679 Posted May 19, 2019 +10 cm medjuosovinskog rastojanja, za tadasnje standarde u klasi (2.7 m). Samim tim i nekih cca 15 cm vise duzine, tj. 4.51 m. Quote Share this post Link to post Share on other sites
dellas 1556 Posted August 19, 2019 (edited) Lepotica se priprema za more, trenutno je na servisu klime. Zamena freona i ulja kao i ciscenje hladnjaka, nakon toga ne bi smeo da se desava problem sa klimom, sve je ispravno. Jedna namrgodjena Edited August 19, 2019 by neshaoct prebacio sliku na FLCS server 6 Axic, bglion, darkman14 and 3 others reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4036 Posted August 19, 2019 A jest opako izgleda Quote Share this post Link to post Share on other sites
dellas 1556 Posted September 9, 2019 Da i delta izbaci neku sliku u kupacem Ovo je neki prvi ozbiljniji put sa njom i mogu reci da sam jako zadovoljan, tvrda sedista i nisu neki veliki problem na vecim distancama. Na auto putu dobro podnosi vece brzine u smislu buke, a i ljuljanja. Za svojih 1500 kg potrosnja korektna, a jos korektniji odziv na gas, cak iznenadjujuce dobar. Panorama naravno na moru ima neku draz bar meni, bar u onom popodnevnom vracanju sa plaze i voznji pored mora. 4 darkman14, Axic, bglion and 1 other reacted to this Quote Share this post Link to post Share on other sites
bglion 401 Posted September 14, 2019 Koliko je auto bio kod njih za reparaciju kože volana u real system? P. S. Pun ti je inbox pa moram ovde Quote Share this post Link to post Share on other sites
