deltist 1 Posted May 15, 2016 Pozdrav! Novi sam clan kluba vlasnik sam delte 1.9twin turbo mjtd executiv 2011g inace sam iz osijeka (hrvatska) 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted May 15, 2016 Uf jbt...Šteta samo još za panoramu. Quote Share this post Link to post Share on other sites
skile86 539 Posted May 15, 2016 Bas joj dobro stoji tabla u crnoj boji, jos opsivena. Quote Share this post Link to post Share on other sites
deltist 1 Posted May 15, 2016 Ima i panorama full oprema je Quote Share this post Link to post Share on other sites
deltist 1 Posted May 15, 2016 Slika je jos iz oglasa kad sam kupovao auto Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted May 16, 2016 ekstra! chipovana? Quote Share this post Link to post Share on other sites
deltist 1 Posted May 16, 2016 Jeste cipovan je! Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted May 16, 2016 Kako se ponaša sa tolikom snagom samo na prednjim točkovima? Biturbo je aždaja sam po sebi a još čipovan... Quote Share this post Link to post Share on other sites
marko.jovanovic 925 Posted May 16, 2016 Gde je grafik? Može i bez pečata Quote Share this post Link to post Share on other sites
deltist 1 Posted May 16, 2016 Problem je sto provrti i u trecij na 60km/h. graf od remapa nemam jer nisam na dino isao! Quote Share this post Link to post Share on other sites
marko.jovanovic 925 Posted May 16, 2016 Pa kako znaš da ima 245ks? Daj snimak ubrzanja na ravnom, i reci koliko ti laže brzinomer u odnosu na GPS. Nemam nameru da te zezam, al 245ks iz tog motora je skoro pa nemoguće bez izmena na hardveru. Quote Share this post Link to post Share on other sites
MS PK 7735 Posted May 16, 2016 Pa ima fabricki izmenjen hardver i plus sad softver A pokazuje mu ko i svima 'bo te gps Quote Share this post Link to post Share on other sites
deltist 1 Posted May 16, 2016 (edited) Druze hardver je izmjenjen ! Iz tog motora se izvlaci max 360ks 640nm ali su potrebne izmene na turbini tj na oba dve treba uraditi hibrid Sto mi je u planu sljedece uradit!!! Edited May 16, 2016 by deltist Quote Share this post Link to post Share on other sites
totti 13165 Posted May 16, 2016 Zašto bre? Ne skrnavi tako lep auto, nije on za to Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted May 16, 2016 Sta je uradjeno od "hardvera"? Video sam na yt 260-280 sa manjim modifikacijama tipa izduv i veci interkuler. Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted May 16, 2016 53 minutes ago, totti said: Zašto bre? Ne skrnavi tako lep auto, nije on za to +1! Quote Share this post Link to post Share on other sites
deltist 1 Posted May 16, 2016 22 hours ago, Bingodalton said: Sta je uradjeno od "hardvera"? Video sam na yt 260-280 sa manjim modifikacijama tipa izduv i veci interkuler. ne znam tocno sta je radjeno sa hardverom ali znam da nije od delte twin, navodno od saaba twin! Izduv je direktan bez i jednog lonca jedino je umesto dpf-a stavljena cev i oblozena limom kao da je lonac a u biti nije! Fejk dpf! Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted May 17, 2016 Složio bih se, dooosta je i tih debelo preko 200KS... mada, tvoj je auto, najbolje znaš, voziš ga svaki dan. Luksuza ima, brza je već sada...jedino ako ti je merak da bude još brža. Kako god, Delta je extra. Quote Share this post Link to post Share on other sites
deltist 1 Posted May 18, 2016 Merak brate merak me vuce! Quote Share this post Link to post Share on other sites
Zvezdo 991 Posted May 18, 2016 ok je to ali nekako mi ne priliči uz deltinu liniju škripa guma pri ubrzanju. Mada kako se kaže snage nikada dosta. Quote Share this post Link to post Share on other sites
gio46 0 Posted May 19, 2016 Odlican spoj luksuza i performansi, prelepa je! Quote Share this post Link to post Share on other sites
puki83 0 Posted May 19, 2016 Odlicna masina i to jos u full opremi, nema dalje Da nije mozda chip radjen kod Dejana u NS? Nesto mi je pominjao kada sam ja radio svoju kod njega, da je radio jednu twin turbo iz Hrvatske Quote Share this post Link to post Share on other sites
Čika MOMO 0 Posted May 19, 2016 divna je Delta! Quote Share this post Link to post Share on other sites
